10-21-2019, 10:20 PM | #401 | |
Pebble Pounder Join Date: Jun 2008 Location: Modesto
| Re: New Axial scx 24 deadbolt Quote:
And I agree… It’s pretty powerful! I have it in my GEN two. By the way, also with old man email! https://youtu.be/KNVZ_ZiNeas | |
10-21-2019, 10:24 PM | #402 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Same as the weevolver, you could get it to work as they are similar in size, probably not ideal for a crawler though. His puller setup is a beast though Sent from my Pixel 3 XL using Tapatalk |
10-21-2019, 11:18 PM | #403 | |
Check out the low-end torque. Again, it’s all in testing I suppose. I have plenty of the 24s now so I can stand to break some parts! In the video I just set the throttle trim so it would just get moving. https://youtu.be/CsWVink9bZE | |
10-21-2019, 11:30 PM | #404 |
Throttle curves? I'm not saying it's not a good motor I'm saying the size and weight are might hurt it's center of gravity and stability. Keep in mind in addition to the extra size and weight of the bigger motor with Gamys mount because of the motor size it will be mounted on top of the transmission instead of along side it like stock. I'm sure it will have more than enough torque and smooth throttle though Sent from my Pixel 3 XL using Tapatalk |
10-22-2019, 06:44 AM | #405 |
Rock Stacker Join Date: Mar 2013 Location: Orlando
Yeah, I thought the extra weight up top would be an issue but once I swapped the stock battery pack for a 350mah battery which I placed right behind the trans it actually made it about the same as stock form since the stock battery sits so high and is so big. If the frame rails were a bit sider the motor couldve been placed lower its just theres not much to work with. The side mount motor plate just doesnt allow for anything lower than 17t pinion so higher front mount was the only way to go down to 11t to keep super slow crawl. :/
10-22-2019, 03:34 PM | #406 | |
10-22-2019, 03:37 PM | #407 |
I don't think those skid plates are his. Not sure he's allowed to post his links here if he's not a vendor, but I can... https://www.shapeways.com/shops/gamyrc Sent from my Pixel 3 XL using Tapatalk |
10-22-2019, 04:22 PM | #408 | |
10-22-2019, 04:23 PM | #409 |
No need to delete IMO. Everyone has a typo now and then haha Sent from my Pixel 3 XL using Tapatalk |
10-22-2019, 05:33 PM | #410 |
| Re: New Axial scx 24 deadbolt |
10-22-2019, 05:55 PM | #411 |
Pebble Pounder Join Date: Dec 2013 Location: NorCal
How much weight dies that add up top? Almost 2x the size of the oem.
10-22-2019, 05:58 PM | #412 |
I don't think the 70c will make a difference with the stock motor and ESC, but it won't hurt. I've been using value hobby for about 8 years with no problems. I really like this 500mah pack because it's 150mah more than stock, but the exact same size. They also have a 3s version that's also the same size, just thicker. (In picture) and the factory ESC will work on 3s http://www.valuehobby.com/power-syst...h-2s-lipo.html http://www.valuehobby.com/power-syst...ah-3s-jst.html Sent from my Pixel 3 XL using Tapatalk |
10-22-2019, 08:36 PM | #413 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
Another option. Made an adapter. Sent from my Moto G (5) Plus using Tapatalk |
10-22-2019, 08:52 PM | #414 | |
Sent from my Pixel 3 XL using Tapatalk | |
10-22-2019, 09:51 PM | #415 | |
Sent from my Moto G (5) Plus using Tapatalk | |
10-23-2019, 09:34 AM | #416 | |
And spoo, I’m running the sidewinder micro now. Don’t really know if that makes a difference either? Last edited by CaliCrawler; 10-23-2019 at 09:37 AM. | |
10-23-2019, 09:39 AM | #417 |
Newbie Join Date: Oct 2019 Location: Birmingham
What size nut driver do these use for the wheel nuts?
10-23-2019, 11:02 AM | #418 |
10-30-2019, 05:59 PM | #419 |
Been honing my light building skills and I think this is how axial should’ve done it… If anyone is interested in me building them one, Or just some info, let me know. Not a vendor, just a side project! Last edited by CaliCrawler; 10-30-2019 at 06:04 PM. |
10-30-2019, 06:53 PM | #420 |
Nice work Sent from my Moto G (5) Plus using Tapatalk |
New Axial scx 24 deadbolt - Similar Threads | ||||
SCX 10.2 Jeep XJ Body on SCX 10 Deadbolt? | sacsmitty | Axial SCX-10 | 5 | 08-15-2018 12:16 PM |
My new Axial SCX-10 Deadbolt | KA7EII | Axial SCX-10 | 4 | 05-21-2016 09:24 PM |
New scx 10 deadbolt | BigCountry11 | Axial SCX-10 | 8 | 07-25-2014 10:00 AM |
