01-04-2016, 12:38 PM | #781 |
Newbie Join Date: Jan 2016 Location: Lake Tahoe
| Re: exceed rc maxstone 16 upgrades and tuning? |
01-04-2016, 03:41 PM | #782 |
Newbie Join Date: Jan 2016 Location: hinckley
I have a question on maxstone 16(battery-7.2v 1100mAh). I want to wire up two 3.7v 650mAh lipo batteries in series. Would that not give me 7.4 v and 1100mAh? Will this harm anything? Is the extra .2v going to mess anything up? Thanks |
01-04-2016, 05:30 PM | #783 | |
Newbie Join Date: Sep 2014 Location: Victoria, Australia
| Re: exceed rc maxstone 16 upgrades and tuning? Quote:
I have 20mm widners in mine with mudslingers and easily misses the lower links. So yours may be a little closer but I don't think they should rub | |
01-04-2016, 05:34 PM | #784 | |
I run a 7.4v 2s lipo in mine with no issues so that should be fine. Just remember that the stock esc does not have Low voltage cutoff for lipos | |
01-04-2016, 06:03 PM | #785 |
| Re: exceed rc maxstone 16 upgrades and tuning? Thanks. I read something about that earlier, I ordered a cheap alarm to plug in when ordered the batteries. I like the idea of two 3.7, fits so nice on top of the servos
01-04-2016, 06:47 PM | #786 |
01-04-2016, 07:07 PM | #787 |
anyone convert to 4wheel steer with the Redcat 3channel? Amazon.com: Redcat Racing 3 Channel 2.4GHz Crawler Radio with Receiver: Toys & Games looks legit and for $55 seams like a good TX/RX combo for the price. looks like out of the box its already good to go as well. |
01-04-2016, 07:22 PM | #788 |
Well, the six cell it comes with is no picnic. Sitting up so high. At one time I thought about buying two 3 cell and putting them on the servos, but they were kind of spendy. These lipos are cheaper and should be better |
01-04-2016, 07:24 PM | #789 |
01-04-2016, 07:34 PM | #790 |
| Re: exceed rc maxstone 16 upgrades and tuning? haha yeah well i didnt use the six cell for very long. You will definatly notice a power difference when running lipo and run times as well
01-05-2016, 01:04 AM | #791 | |
Pebble Pounder Join Date: Jan 2008 Location: Indy
2 parallel gives you 3.7v 1300mAh. It'd take a 2s2p pack to get to your batteries up to 7.4 v and 1300mAh, which would just be easier to get bigger packs and stay with a 2s. | |
01-05-2016, 07:50 AM | #792 |
Wow, appreciate your input. First things first, 650+650 is of course 1300 not 1100. Little brain fart of mine. And yes I have to rethink. Now Im thinking wire two in series, the other two in series. I'll have two@7.4 and 650. Then wire these in parallel, and I should get the 7.4 and 1300 I so desire. Why use 4 small instead of one large with the same numbers? The rig is so small, its nice to have small packages I can move almost anywhere, Im shooting for top of servos. I think I've got this right now. Let me know. Thanks!! |
01-05-2016, 09:20 AM | #793 | |
Newbie Join Date: Dec 2015 Location: Central Ohio
Also, as it relates to batteries, I did order 2 Lipos from Hobbyking that I think should fit. One is a 1000 mah and the other a 1500. I'll get some pictures up once I get them fitted to see how they look/fit. @CJP_8_7 What wheel wideners are you using? | |
01-05-2016, 11:32 AM | #794 |
Newbie Join Date: Dec 2015 Location: Canton Ohio
These little batteries are perfect and shave off 100 grams: http://www.amazon.com/gp/aw/d/B00LZK...VX97CM90PVCPGS I now have an ecx and redcat and find the redcat motor handles bigger tires better than the ecx. +1 which wheel wideners are you using? |
01-05-2016, 11:54 AM | #795 |
The ecx has a standard servo and mount, the redcat has a smaller one. I upgraded the redcat servo to standard, but only have a temporary mount. Since the ecx mounts are on extensive backorder - is the exceed or maxstone servo mounts full size? Thanks |
01-05-2016, 04:52 PM | #796 |
| Re: exceed rc maxstone 16 upgrades and tuning? I bought some cheap ones off ebay 4pcs Metal 20mm Thickness Enhanced Mount 12mm Wheel HEX Drive Adaptor Black | eBay have had them for over a year now with no issues what so ever The price has gone up on these since i bought them i bought them for $9 aus |
01-05-2016, 06:37 PM | #797 |
| Re: exceed rc maxstone 16 upgrades and tuning? do you mean a full size servo?
01-06-2016, 06:07 AM | #798 |
Are the exceed or maxstone servo mounts standard size?
01-06-2016, 10:40 AM | #799 |
The Exceed Maxtone and Redcat Everest 16's are both NOT standard size servo mounts. The ECX Temper mount however is, but it's on a giant global backorder, I haven't been able to find it anywhere. The Redcat/Exceed servo mount will only hold a servo that is 36mm wide. I'm using the Turnigy TGY-MG930 ($15 from HK) up front and the stock Redcat servo in the back. I haven't been able to find published specs on the Redcat servo, but assuming its the same as the Exceed servo, it's a 2.5 KG unit, which seemed to be fine for the stock tires, the TGY-MG930 is rated at 3.6 KG which is why I put it up front. |
01-06-2016, 03:14 PM | #800 |
ok sorry i didn't understand but now i do (i think ). i got an aluminium standard size servo mount for a 1/10 crawler and drilled the holes to match the mounts on my hsp kulak (exceed/ maxstone same thing). this meant that i can run a standard size servo and it is mounted properly and much more neatly.
