Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: RC's Bully2 / SuDu 3D Build
Old 07-25-2016, 08:34 PM   #81
LeePin's Avatar
Default Re: RC's Bully2 / SuDu 3D Build
It's all Grbl to me.
LeePin is offline   Reply With Quote
Old 07-26-2016, 05:53 AM   #82
NEO is the one
stankulas is offline   Reply With Quote
Old 07-26-2016, 06:52 AM   #83
Lmao G-Code
Originally Posted by stankulas View Post
NEO is the one
Follow the White Rabbit, take the green one, no really take the green one Mr. Anderson.
ROCKCRUISER is offline   Reply With Quote
Old 07-26-2016, 06:56 AM   #84
My name is Neo
crawlinghulls is offline   Reply With Quote
Old 07-26-2016, 03:41 PM   #85
Originally Posted by crawlinghulls View Post
My name is Neo
They call me Smith, Mr. Smith!
Old 07-28-2016, 07:40 PM   #86
Shock update! Onto Rev. B ok so I added a 3 pack replaceable o-ring pack. The bottom screws in up against a inner stop that captures the inner sleeve that's interchangeable to control the flow rate. Put two together no leaks. Next I'm going to add an o-ring to the bottom to remove the need for thread seal and then finally I'm going to make some Ti shafts for them.
Old 08-03-2016, 12:40 AM   #87
DravTech
Dravpnir's Avatar
There is so much awesome stuff going on in this thread. I cannot wait for more
Dravpnir is offline   Reply With Quote
Old 10-19-2016, 11:22 AM   #88
Hey just wanted to let you know, 3m makes panel bond that is a 2 part epoxy and it's great! I do paint and body work for a living and we use it a lot and on everything, metals plastics and cf too and it bonds great and holds up great! You have to use the slow cure one though, the fast curing version doesn't bite as well. The part number is 08115 and it is very good stuff! Awesome build also!
CEEJRC is offline   Reply With Quote
Old 06-19-2017, 09:27 PM   #89
did you change anything with the vvd's in the front axle and are you making the Ti rear shafts for sale? If you are please pm me
barberton crawler is offline   Reply With Quote
Old 06-19-2017, 10:57 PM   #90
Creeperbob makes Ti rear shafts for B2.
Originally Posted by ROCKCRUISER View Post
HERE'S A LITTLE TEASER, WHATS THAT!
You never mentioned what these are?
84yoda is offline   Reply With Quote
Old 03-09-2019, 12:04 PM   #91
What ever happened to this build ? This is a awesome thread!!!
santa cruz crawler is offline   Reply With Quote
RC's Bully2 / SuDu 3D Build - Similar Threads
Dlux/sudu build FLOKI-81 EnRoute Berg 162 06-17-2016 12:28 PM
Hustler's Sudu Build stankulas Axial AX-10 Scorpion 13 05-09-2015 07:11 PM
Looper's Bully2 Build Looper RC4WD Bully 19 10-10-2014 07:35 PM
Papabash's Bully2 Build papabash RC4WD Bully 54 05-16-2011 08:54 PM
