01-09-2011, 12:05 PM | #121 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
A fender is a permanent part of the actual body. A fender flare is an add on used mainly for wider tires and to help contol splatter where a mud flap would aid in this on a normal fender. Im not on the rules committee, but I will say judging from the picture that the fender is more than 50% missing since the normal factory fender of that version caps down and front. It sometimes comes with flares as an accs. Package. But if you include the addition of the frame rail along the fender line, I would say that makes up for it. Look, it is a hard description to pin down since it is left up to the event judge. In my opinion this rule needs to be cleaned up so the rule will stick no matter what event you go to. You wont beable to only allow it for jeeps. Because then you'll have why this and not that issue. I think the best way to cure this issue and make it so it fits the respect of the class to allow more than 50% as long as the frame rail or manufactured part is added to keep the appearance and look and fit the rule specs. I applause you all for your working together on the rules, but rest assured these rules will need a bit more ironing out. Maybe next year these rules will be altered, but as far as this year goes. Everyone should build the trucks to the rules |
01-09-2011, 12:41 PM | #122 |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
Maybe a simple fix to the rule would be Must have 7 of the following: 50% of the production style hood 50% of the production style fenders 50% of the production style Roof/Roll Cage Windshield and Frame Rear Quarter Panels Doors/Half Doors Bed/Cargo Area |
01-09-2011, 01:33 PM | #123 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Rule says fender ... flare is not a fender. Although it is somewaht vague, "50%" is the best we have unless yall want to start whipping out scales and/or calculating surface area. I don't think anyone wants that. An easy solution to the problem: instead of trying to get it right at 50% and pushing the limit, leave a lot more so there is no question. |
01-09-2011, 01:36 PM | #124 | |
-Rule says grill ... nothing about headlights. -If you are concerned that your rig may be illegal, I'm sure that would be appreciated by the judge. But remember, unless we actually start calculating surface area ... there is some gray area. the best thing you can do is leave more than 50% so there is no question. Every headache rack I have seen has mesh or slats. Otherwise it may be a utility rack (or part) .... not sure though. Have never seen one with just a bar. Got any pics? | |
01-09-2011, 01:50 PM | #125 | |||
DOOH!!! Join Date: Feb 2007 Location: AZ
Can you (Rules Committee Members) please make a final decision on this together. Internal vote maybe? and, with the class 2 rigs allowing the bumpers and stingers as part of the measurements it might not be a bad idea to add something like "and not be overly exaggerated in size in order to distort vehicles legal measurements". Probably only a matter of time before you see a 6" stinger/bumper. This could also aide in the restraint of 2" light bars to reach the height requirement if you so deem they are allowed, (as mentioned in a post I forgot to quote). Thanks, keep up the great work.. | |||
01-09-2011, 02:26 PM | #126 | |
01-09-2011, 02:41 PM | #127 |
01-09-2011, 02:48 PM | #128 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
Yes, as MTHead, I think allowing up to a certain height for an --integrated-- as in not removable light bar should be considered. This still prevents the dreaded 2" tall light bar, and those that remove the lights for clearance would not be able to include that in the chassis measurements.
01-09-2011, 02:53 PM | #129 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
01-09-2011, 03:15 PM | #130 |
Pebble Pounder Join Date: Oct 2006 Location: Maple Valley
So this is my thaught on this.If you can pinch the nose on a truck cab you should be able to cut the fenders on jeep style bodies.Its pretty much the same thing.the jeep fenders are more horizontal than vertical.If I start with a new bodie and leave the thin top of the fender or not it really makes no differance.Just a week spot to break off the bodie. |
01-09-2011, 04:37 PM | #131 | |
01-09-2011, 04:43 PM | #132 | |
01-09-2011, 06:53 PM | #133 | |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
I still don't agree with the tire rules but that's just me and i'll need to deal with it. Quote:
The Willy's i build a while back is a good example The front fenders are integrated into the chassis but the original fenders were never removed from the body as i built it without them. I believe the line needs to be drawn at the face value of the vehicle, if the fenders have the look of the real vehicle they are representing it shouldn't matter what they are made of or what they are attached to. | |
01-09-2011, 07:04 PM | #134 | |
On a Jeep, the grill is already narrow and when you cut off the front of the fender ... you essentially get the same benefit as a pinch front truck... and it's a lot less work. Lots of guys that run trail Jeeps go with a tube fender that keeps the "flat" top part and beef it with tube. Doing that in this case will most likely keep you good for class 2. So if you are insistent on being in class 2, flat fender it (add tube if you are worried about strength). If you are insistent on building a replica of that black 1:1 Jeep that you should plan on it being in class 3. Last edited by Locked Up; 01-09-2011 at 08:02 PM. | |
01-09-2011, 07:10 PM | #135 | |
On a scratch built body, I'd base my assessment on what the 1:1 vehicle would have looked like. The green parts you have there replace the fenders and although I cannot see the side of that, probably are enough for me to pass if for class 2. | |
01-09-2011, 07:31 PM | #136 |
[QUOTE=Locked Up;2850036]When you pinch the nose of a truck you are narrowing the front grill and front of the fenders. On a Jeep, the grill is already narrow and when you cut off the front of the fender ... you essentially get the same benefit as a pinch front truck... and it's a lot less work. So because I choose to run a jeep bodie I don't get the same benifits as a Truck bodie. |
01-09-2011, 08:01 PM | #137 |
01-09-2011, 09:01 PM | #138 |
Hey Locked up, I can see this is going nowere.I'm just gonna let it go.Thanks for all your input on the subject. I may not agree with it,but I get it. |
01-09-2011, 09:35 PM | #139 |
I wanna be Dave Join Date: May 2006 Location: akron
01-09-2011, 09:57 PM | #140 |
Hey sloppy, Thanks for letting me know that.I'll sit back and see what comes of this subject. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/scale-comp-rules/290744-sorrca-competition-rules-release-class-specs-scale-points.html | ||||
Official new scale rules 2011 - Nostr Forums | This thread | Refback | 10-07-2011 06:20 AM |
