07-24-2016, 12:18 AM | #241 |
| Re: New Incision wheels coming.... |
07-24-2016, 10:08 AM | #242 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
07-24-2016, 10:13 AM | #243 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
Boom! Like it.
07-24-2016, 10:19 AM | #244 |
Very nice ITG, I think this is going to be a very popular "mod" to these wheels. Even if people don't try it at first, after a couple weeks in the rocks and some good rash, it'll be a great way to clean them up again. If I ever manage to get a set of these, it'll be the first thing I do.
07-24-2016, 11:01 AM | #245 |
Moderator Join Date: Jan 2004 Location: chicago
07-24-2016, 11:41 AM | #246 |
Pebble Pounder Join Date: Jan 2010 Location: CA
What kind of mods would be needed to get these to work with Pro-line XL tires?
07-24-2016, 12:01 PM | #247 |
Not a big fan of the method design myself but sanding the edges definitely makes them look much better.
07-24-2016, 12:42 PM | #248 |
| Re: New Incision wheels coming.... Thanks for backside pic. Little wider, but still not as wide as they ought to be for 2.2s. Would you post dimensions like SSD RC does? Overall width between inner and outer "lock rings", distance from rear lip of wheel bead to center where wheel hex seats? |
07-24-2016, 01:00 PM | #249 |
07-24-2016, 03:16 PM | #250 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
Well I ordered RPP's last two sets of 2.2 Black 307s for my CXT. I like the more budget friendly options VP is offering. Not thrilled about non-SLW hubs but hopefully the included ones are close enough to the 475s on the truck already.
07-25-2016, 08:35 AM | #251 |
After seeing all of the photos I am impressed. They look very nice for the price. I will be buying a set at some point.
07-25-2016, 10:30 AM | #252 |
hub looks bulkier than an slw to me. other than the change in harware im still not really seeing the need. will an slw fit if it was drilled and tapped for the new bolt circle? not bitching but it may lead to a neat jig somebody could make that allows us to drill existing slw hubs to the new hub design. |
07-25-2016, 10:32 AM | #253 | |
| Re: New Incision wheels coming.... Quote:
07-25-2016, 10:45 AM | #254 |
The hub is way smaller and a lot simpler. Bolt pattern seems very close to the 1.7 rc4wd Raceline wheels I have here. Harley already stated the new hubs were to bring it in tighter on the 1.9s and for sake of cost the whole line uses the same hubs. It's really not a huge deal, I have a ton of slw hubs here, but they don't work on a lot of the wheels I have, gearhead, rc4wd, mayhem etc. Sure they crated the standard, but now that I have these wheels here, I'm glad the hub is smaller, they were able to spread the design of the wheel out quite a bit. If I remember when I get home I can post a picture of the hubs together. It is substantially smaller, and lighter than it would have been if it were the slw pattern. |
07-25-2016, 12:00 PM | #255 |
smaller and lighter i get, just curious if a slw CAN fit with a new bolt circle drilled. just curious for no other reason than being curious. |
07-25-2016, 02:48 PM | #256 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Im curious why they didnt just drill the rims for slw, and sell it without the hubs for even cheaper? I really hope the rims can be drill out to fit 4-40 and run slw instead.
07-25-2016, 03:11 PM | #257 |
07-25-2016, 04:11 PM | #258 |
07-25-2016, 05:49 PM | #259 |
| Re: New Incision wheels coming.... No matter how many times I read it the answer still sucks. I imagine some industrious fellow will come out with a better solution to the hub issue than what is currently available before long. Not really a big deal. |
07-25-2016, 06:31 PM | #260 |
You are right.. It really is not a big deal.
New Incision wheels coming.... - Similar Threads | ||||
Narrowing Stock XR10 wheels to fit Vanquish Incision Knuckles | The gasman | Tires and Wheels | 8 | 01-13-2014 06:46 PM |
vanquish XR-10 Incision Steering Knuckles and wheels | bikeboy | Axial XR10 | 35 | 03-07-2012 09:51 AM |
VP Incision Steering Knuckles/Stock Wheels | Mysterious | Axial XR10 | 9 | 12-11-2011 05:18 PM |
New 1.9 wheels coming | Gozer | Losi Mini-Rock Crawler | 4 | 10-21-2008 02:59 AM |
