07-18-2016, 02:07 PM | #121 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
| Re: New Incision wheels coming.... |
07-18-2016, 02:10 PM | #122 | |
| Re: New Incision wheels coming.... Quote:
I don't have a candidate in the race. Personally I don't care who makes my parts as long as the alloy is good and the specs are consistent. I've fondled fakeuish and VP wheels plenty and honestly they aren't all that far apart in quality. Toss the fakeuish wheels in a media tumbler for a bit like VP and you'd be hard pressed to tell the difference. I run CI 6 bolt glue on wheels on everything anyway. Cheap, light and they get the job done. | |
07-18-2016, 02:17 PM | #123 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
Everything has always been VP this VP that. I wasn't able afford anything shiny from them. I purchased a set of 90mm limiting straps. $40 for 4 of them! I live in Sacramento, where VP is based. Soon after purchasing them I find the same exact thing offered at my LHS for half the price. Next I find out that they're both made by the same person. They look exactly the same, but the ones VP sells are twice as much. What happens next? VP stops selling them. Why? I can only imagine it's because the jig was up and they could no longer sell them at that outrageous price. Being from Sacramento I get to hear a lot of the inside stuff too. VP team drivers are always in the shop. Other local vendors too. People form their opinions based upon experience. My experience formed an opinion of VP as a price gauging front runner which is why I said what I said about the incision spool not coming with hardware. Sent from my SM-N910V using Tapatalk | |
07-18-2016, 02:35 PM | #124 | |
RCC Addict Join Date: Apr 2011 Location: San Diego
I hope they offer the 1.9 in a wider format also. It made mounting and willing up my BFG KO2s and TSL XLs and KLRs much nicer. | |
07-18-2016, 02:44 PM | #125 | |
Yup I run shift hubs exclusively. No more slop from the hub and hex allowing the wheel nut to come loose. | |
07-18-2016, 02:45 PM | #126 |
| Re: New Incision wheels coming.... I am currently awaiting shifts to get back in stock. I started to notice the slop in the SLW hubs recently on one of my rigs. Are you running the stock axial pins or gunnar pins?
07-18-2016, 02:48 PM | #127 |
07-18-2016, 02:51 PM | #128 | |
Basically eliminate another tolerance stack up. Still wondering the offset of these incision hubs and the center caps. | |
07-18-2016, 02:52 PM | #129 | |
They are pin drive like rc4wd uses. I've heard some people saying that the pin can get lost when you remove the hub. If the shaft is shimmed right the pin has a slight bit of tension on it so it won't move. | |
07-18-2016, 02:57 PM | #130 | |
07-18-2016, 03:00 PM | #131 |
Actually it was White Trash who started with the Bernie Sanders talk. It goes both ways too SCREAMER when approaching and commenting on something. Sent from my SM-N910V using Tapatalk |
07-18-2016, 03:09 PM | #132 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
I have the shift hubs sitting in a box per white-trash recommendation a while ago. Just waiting to buy some wheels. What hardware do I need? 4-40? To vary the width do you just cut the threads to fit the number of spacers you use?
07-18-2016, 03:11 PM | #133 |
You called me a Trump lover in another thread, that's what I was referring to. I'm sure you remember and you are absolutely right, it does go both ways. My first interaction with you was the infamous incision spool incident so I may have developed a bit of prejudice towards most of your comments. All I'm saying is try to help more than trying to be right or win.
07-18-2016, 03:16 PM | #134 |
I do try to help as much as possible, but sometimes can't help my hatred for VP when everyone else wants to ride their d!ck. That's all! As for the Trump comment, it's not in my nature to start with something like that so you must have said something political to me to have gotten that response. If you didn't then I apologize. Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 07-18-2016 at 03:18 PM. |
07-18-2016, 03:19 PM | #135 |
| Re: New Incision wheels coming.... They come ready to accept M3 hardware. You can tap the extra holes for 4-40 hardware.
07-18-2016, 03:21 PM | #136 | |
07-18-2016, 03:25 PM | #137 |
07-18-2016, 03:35 PM | #138 | |
As for the heads of the m3 hardware not fitting some wheels, yes that can be an issue. I have chucked a bunch of screws into a drill and ran the heads against my dremel a few times to mill them down. I've also tapped the pre drilled holes for 4-40 a time or two too. | |
07-18-2016, 06:05 PM | #139 | |
07-19-2016, 07:45 AM | #140 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Also glad to hear their new 2.2's are going to be a little wider, looking forward to seeing some.
New Incision wheels coming.... - Similar Threads | ||||
Narrowing Stock XR10 wheels to fit Vanquish Incision Knuckles | The gasman | Tires and Wheels | 8 | 01-13-2014 06:46 PM |
vanquish XR-10 Incision Steering Knuckles and wheels | bikeboy | Axial XR10 | 35 | 03-07-2012 09:51 AM |
VP Incision Steering Knuckles/Stock Wheels | Mysterious | Axial XR10 | 9 | 12-11-2011 05:18 PM |
New 1.9 wheels coming | Gozer | Losi Mini-Rock Crawler | 4 | 10-21-2008 02:59 AM |
