04-13-2018, 12:38 PM | #321 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: 3d printer for rc parts Quote:
04-13-2018, 04:42 PM | #322 | |
You can check reviews / videos for D7 to get a good idea how the MP Mini SLA works. With the low cost SLA printers you don't have a cleaning station so you end up dealing with liquid resin and having a place to cure your prints. However, it is really good the low end of the market is dropping so that a SLA printer is affordable. | |
04-13-2018, 05:06 PM | #323 | |
I'll definitely check out the review. And, yes, it's awesome that resin printers are dropping in price! | |
04-13-2018, 08:12 PM | #324 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
I printed this for my wife, she collects pigs. For the most part I think it came out fine except for the top of the back and the top of the ear. It also felt rough when running your finger over it as opposed to the rest of it. |
04-13-2018, 08:49 PM | #325 |
Might be under extruding or fan cooling is off of wheee it should be Hang up and Drive |
04-13-2018, 11:27 PM | #326 |
| Re: 3d printer for rc parts What layer height did you use for the print?
04-14-2018, 08:53 AM | #327 |
| Re: 3d printer for rc parts 0.2mm I was thinking that it might not have been square on the table so I loaded the gcode in the slicer to look at it. To my surprise the object look very close to what it printer. changed the layer height, number of top layers and it looked pretty much the same. Printed something else & it was fine. I'm going to guess it's the stl file that it the issue. |
04-14-2018, 12:23 PM | #328 | |
You can reduce the effects by a using a lower layer height but that will increase the print time. More layers make the steps smaller. With some slicers like Simplify 3d, the slicer can make the upper layers thinner making a smother print. The latest version of the Slic3r Prusa edition has layer smoothing that uses variable layer thickness which adjusts the layer thickness based on the slope of the part. | |
04-14-2018, 06:51 PM | #329 |
| 3d Print Troubling Shooting
Found this 3d troubling shooting guide, read through parts of it and looked like some good reference information. https://all3dp.com/1/common-3d-print...rinter-issues/ |
04-15-2018, 01:20 PM | #330 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Does anyone dabble in vinyl cutting too? I picked up a craftwell ecraft a couple years ago. I've had decent results, but it has issues with small details for RC use. |
04-15-2018, 01:47 PM | #331 |
You might try 3dprintingcult.com for an audience well versed in vinyl cutting. Its a new forum, dufunct facebook group that migrated off recently. Smart group of folks.
04-15-2018, 02:21 PM | #332 | |
Wifey got a Silhouette Cameo a while back. I can do some things with it. No multilayering or printing colors yet. Anything with a single color I can do. | |
04-15-2018, 03:03 PM | #333 |
Octopi is setup. No more SD card BS |
04-15-2018, 03:20 PM | #334 |
| Re: 3d printer for rc parts |
04-16-2018, 03:08 PM | #335 |
I first I was all Then I was all Day 2 with the octopi, already getting a webcam... |
04-16-2018, 03:24 PM | #336 | |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Back on topic. I'm with Mike. ZI have better luck with SD card. I need to get Octpi up and running. Soon will have my over engineered enclosure cabinet done. Sent from my SM-N950U using Tapatalk | |
04-16-2018, 03:39 PM | #337 |
04-16-2018, 04:10 PM | #338 |
Watched the first few layers without issue, then left for work. It looks like it FUBARed about 10min after I left. 'preheated' the tip to 280c, pla just boiled off. cleaned up everything a bit and it's back to printing now. |
04-16-2018, 04:32 PM | #339 | |
In addition to the camera, you might want to consider a smoke detector above the printer. A plastic ball like that can catch on fire. The one I am using has a strobe that you can see the flashing in the web cam video stream. | |
04-16-2018, 04:37 PM | #340 |
Its why I print on the stove Lipos get stored in it, 3d printing and lipo charging on top The joys of being a bachelor |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
