06-04-2018, 04:52 PM | #521 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: 3d printer for rc parts
My second printer is an A8, I just got a second one I enjoy it so much . I'm very cheap.
06-04-2018, 06:30 PM | #522 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Re: 3d printer for rc parts |
06-04-2018, 07:30 PM | #523 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Time to get a kennel, the printer pooped on the floor... |
06-04-2018, 07:56 PM | #524 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
06-05-2018, 06:55 AM | #525 |
So I got my CR10 mini going and have been working on test cubes. These are the first 2 off the printer, I think they look pretty good to my noob eye. The first (cube on the left) was printed at recommended settings in Cura. 200C extruder 60C bed .1 layer height 30% infill The gaps and thin spots on the top of the cube need some work. Based on my research, I guess it is either not enough top layers or undexstrusion. So I up the top and bottom layers from 6 to 8 and change the filament diameter from 1.75mm to 1.72mm (since the average filament diameter I measured wasn't quite 1.75mm) for the second cube. It came out better but I can still see thin spots in the same places. Decided to look at the layers in Cura and it turns out Cura is creating the gaps with the tool paths and not filling them in. Apparently, Cura 2.7 would take care of this but not so much in the 3.3 version I have. Maybe I am missing a setting here? Running the same model through Slic3r seems to eliminate the gaps in the preview but I haven't tried printing through there yet. The bigger issue I seem to be having is my 20mm cubes aren't quite 20mm. They come out 20.01mm on the Y (fine), 19.92mm on the X (not so good), and 19.64mm on the Z (pretty bad). Creality locks the firmware so the steps/mm can't be permanently changed through G code so how do I dial in the travel? Is there a setting that can be used to get these things to print in the proper dimensions? |
06-05-2018, 12:11 PM | #526 | |
| Re: 3d printer for rc parts Quote:
In the newer versions of Cura you may have to enable scaling: Access the Plugins menu > Browse Plugins > click on the Manage Tab, scroll down to the Scale Tool and make sure it is Enabled. You may need to restart Cura for it to take effect. I would try dropping the infill to 20% and try changing the layer height to .2 to see if that makes any changes to the tool path in Cura. You may need to calibrate the e steps for the extruder to fix the under extrusion problem. It is a lot easier to do calibration prints in silver gray filament since it will show up imperfections and is a lot easier to get a good photo of it. | |
06-05-2018, 12:47 PM | #527 |
Cura can insert gcode before the start of the print, it's how they do the nozzle wipe/etc. I wonder if you could add the steps change In that section?
06-05-2018, 01:14 PM | #528 | |
Great info for almost anyone | |
06-05-2018, 08:44 PM | #529 |
Tried my 1st print using PET-G today and this was the result, when I noticed this I cancelled the rest of it. Extruder temp 216 Bed temp 75 Had the fan on Auto 20%-100% Sliced in Slic3r PE 1.4.0 Solutech 3D PET-G When previewing it it sliced fine. The strange this to me was that it looks like it slid apart but when I checked it was still printing the circle even though it had slid off the lower portion. Other than the section that slid the adhesion on the other layers looks good. Checked the troubleshooting page at Simply 3D it appears that it could be a speed issue. I did up the travel speed to 5000. I think it was Makers Muse that said to set it high as the printer will only go as fast as it is capable of, I think the top speed on my Power Spec Duplicator i3 Plus is 70. I'm going to change it back and see what happens. Last edited by Gramps; 06-05-2018 at 09:31 PM. |
06-05-2018, 09:58 PM | #530 | |
Layer shifting is often caused by a slipping belt or pulley on an axis. I recommend checking the belt tension and that the pulley isn't slipping on the shaft. | |
06-06-2018, 03:30 AM | #531 |
06-06-2018, 03:41 PM | #532 | |
Found the issue or maybe I should say it found me. Changed the travel speed to 70 mm/s which I think is the max for my printer & set the fan speed to 20-35. Started the print looked good (4 hr print) so after an hour or so without any issues I went to lunch with some friends. When I returned there was filament everywhere, the hot end had fallen out of the aluminum block. When I went to fix it the set screw hole that holds it was stripped. Took it back to Micro Center and exchanged it for another one, as they had no means to fix it. Nothing like starting from scratch, well sort of :-) | |
06-06-2018, 04:13 PM | #533 |
Yep, your hot end was slipping and hitting the parts, causing missed steps. No feedback stepper systems are finicky.
06-07-2018, 10:00 PM | #534 |
My printer sits on a wooden desk. I have some fatigue mat and thought about cutting a piece to set the print on. Good or bad idea?
06-07-2018, 11:29 PM | #535 | |
If you want to protect the surface of the desk, you can use a melamine shelf board like this: https://www.homedepot.com/p/3-4-in-x...2297/202089063 | |
06-08-2018, 06:32 AM | #536 |
Theres things in life you wish you done earlier and wonder how you did things before you got them ...... this auto level sensor is that thing for me lol. Clean my glass with some alcohol, let it run its 9 point level and away I go. Its so nice now just watching the brims lay down and not worrying if the first layer is gonna go down right. The round part is .90'' by design, pretty impressed that 4 Ive printed have all been within .001 of themselves. (still tweaking my retraction settings for the stringies) Last edited by Robbob; 06-08-2018 at 06:50 AM. |
06-08-2018, 03:56 PM | #537 |
Is there a collection of driver figures on thingverse? Their search is really bad... |
06-09-2018, 02:04 PM | #538 |
My new PowerSpec Duplicator i3 Plus seems to have more temperature swing that the old one. The old one would only swing a few 10ths up or down. The new one swings maybe 2 degrees up or down. Doesn't seem to be effecting the prints but I've only done 2 test cubes and a sink strainer. Should I be worried about this?
06-09-2018, 05:38 PM | #539 | |
Search how to do a PID tune, I had a few degree swing on my printer and this settled it out for me. | |
06-09-2018, 05:44 PM | #540 | |
https://www.thingiverse.com/thing:116571 70 points of articulation | |
3d printer for rc parts - Similar Threads | ||||
Can your printer do this? | CREEPERBOB | Chit Chat | 19 | 10-14-2011 07:33 PM |
Are you a printer in OH or know someone who is? | Phatmac | Ohio | 5 | 02-20-2009 02:14 PM |
