03-15-2009, 07:49 AM | #141 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
they are all that color coated now....once i have the pieces cut to size i chuck it in my drill and use plumbers sanding cloth to take it down to bare metal....then after that is done i sand it by hand from end to end with the cloth again....plumbers sanding cloth is like window screen with grit.............bob .... |
03-15-2009, 07:56 AM | #142 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
1st thing i thought of when he dropped the piece he worked on, a bucket of water to drop it into to allow it to cool off. other then that, now i can attempt to braze, cuz i never knew? thanks for the Vid man!! |
03-15-2009, 08:10 AM | #143 |
Pebble Pounder Join Date: Mar 2005 Location: Nebraska
Maybe it is the flux?? I just bought the cheap burnzomatic flux, because my local linweld didn't have the harris flux. So far i am having better luck just using brazing rod. Sould i go for the harris flux? |
03-25-2009, 02:56 PM | #144 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
Some great tips in this thread. Subscribed thanks. |
03-26-2009, 01:25 PM | #145 |
I've looked into this, but it seems in the UK our automotive brake line is copper or cupro-nickel whatever that is!). Am I right in thinking US brake line is steel and 1/4"?
04-19-2009, 01:38 PM | #146 |
Newbie Join Date: Apr 2009 Location: Canada
Great thread! Thanks to the info here, I think I'm all set to try brazing. I have the OX2550KC Cutting, Welding and Brazing Torch Kit and I have some brake line, steel rod, and aluminum tube. Now my question, I have some brazing rods that are coated, does this coating replace flux or do we still need flux paste? |
04-19-2009, 03:49 PM | #147 |
Rock Crawler Join Date: Jun 2008 Location: Naples
Yes the white or blue coating is the flux, works well. For more info on brazing: http://www.handyharmancanada.com/The...Book/bbook.htm |
04-21-2009, 12:27 PM | #148 |
Pebble Pounder Join Date: Jan 2009 Location: san marcos
Do you guys thunk i could braze zinc coated steel brakelines if i sanded all the joints?
04-23-2009, 08:47 PM | #149 |
Newbie Join Date: Apr 2009 Location: Chicago
You can solder zinc, so maybe you can solder zinc coated brake lines. If you get high quality solder like Bridgit, it should make fairly solid connections.
04-26-2009, 01:44 PM | #150 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
If for some strange reason you grab a spot you just brazed before it cooled, run to the kitchen as fast as possible and get an ice cube from the freezer and hold it between the fingers you just used to grab the hot joint with till it's completely melted.. It will remove the heat that causes your finger tips to blister. |
05-01-2009, 02:30 PM | #151 |
Newbie Join Date: Mar 2009 Location: Shakespeare Country (stratford)
Warning: Teenage UK resident (useless with imperial so this wont be im planning on bulding a super crawler with alum or steal tube (like from homebase) 6-8mm. which would be best 2 use and ive got an electric heat gun thats about 560oC. will that be hot enough? |
05-01-2009, 04:27 PM | #152 |
The heatgun won't be hot enough. You really need a gas torch and some 6mm O/D solid rod or tube.
05-02-2009, 02:55 AM | #153 |
cool. ill see wot i can find and hope it works!
09-06-2009, 02:29 PM | #154 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
I just created a .pdf file with all of the information on this thread that I found useful - or could find useful later. It's probably easier than going through all seven (?) pages. If anyone else wants to read it, then please tell me how to post a .pdf I'll post it or post a link to it. Photobucket doesn't allow .pdf files to be uploaded - where can I put a .pdf file so others can see it? Thanks, AR |
09-07-2009, 04:28 AM | #155 | |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
09-07-2009, 12:21 PM | #156 |
Adding to the supply list, I'd recommend the following: Hand files - small round, triangle files (Dremel's are great but there's always something more/better/easier you can do by hand) Metal clamps - remove the rubber tips: One or more of these: Last edited by Axial Rose; 09-07-2009 at 01:08 PM. |
09-09-2009, 04:22 PM | #157 |
Quarry Creeper Join Date: Sep 2009 Location: Bay Area
Sorry if this has already been asked, but while brazing do you keep the two rods that you want to braze slightly apart so the flux and silver can get through to the other side or do you just let them touch?
09-11-2009, 03:40 PM | #158 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
I have never had any luck using the above items, I mainly use blue painters tape to hold pieces in place- quick and simple. p!nK | |
10-01-2009, 01:15 PM | #159 |
Pebble Pounder Join Date: Jan 2008 Location: houston
on ebay they sell brake line that doesnt look color coated!!!! (it says zinc coated) yall let me know if yall find it. also brake line bends easly but what about aluminum rod? Last edited by FAT-T 88; 10-01-2009 at 01:27 PM. |
10-01-2009, 01:42 PM | #160 | |
Rock Stacker Join Date: Jul 2008 Location: Austin
You want a tight fight but not too tight. See this for more info | |
