![]() | #41 |
RCC Addict Join Date: Jun 2009 Location: Australia
Nice pics as alway's Like the idea of the revo balls under the delerin rear link mounts.... Seen that somewhete before ![]() |
![]() | #42 | |
Rock Crawler ![]() Join Date: Jan 2011 Location: At home
| ![]() Quote:
![]() ![]() Tomy has a drawing with some alternate pieces with added rows of holes, also a option with almost the height of your current setup. He is shipping me some when my additional wheelspacers are in ... | |
![]() | #43 |
| ![]() I had some freetime tonight and made some progress, I did up the links and shocks. I used another one of Team NCD’s optional parts for the SuDuOne chassis. Tomy offers some nice delrin lowerlinks at additional cost, they are meant to work wit revo rodends and come with M4 scrubscrews installed. Pics and further details below … Links & Shocks NCD delrin lowerlinks (front & rear) TRX revo rodends #5347 Axial SCX10 plastic shocks Losi mini-T silver springs (front) Losi mini-T green springs (rear) JeepinDoug springcups Mods: - external limiters ![]() Front lower links are only available in a “Low Clearance” (LC) version and measure 110mm e2e with revo rodends. ![]() For rear lowers you have two options, a “Low Clearance” version (first pic below) and a “High Clearance” version (second pic) and measure 128.5 mm e2e with revo rodends. ![]() ![]() For my build I am going to run the HC rear lowerlinks, upperlinks will be made out of CF tube and are going to be the next update … First I measured the needed length after installing the lower links and shocks and made some M3 all-thread mock-up links. As mentioned before, I already intended to use the SCX10 shocks over the bigbores, main reasons were preload adjustment and weight. When I compared both options closer, I also noticed the SCX10 shocks to be slightly longer as the #2660 bigbores (without capmod). Another factor in favour to start off with the SCX10 shocks … ![]() external limiters: front 7.5mm, rear 7.5mm shockoil (Losi): front 30wt, rear 50wt Pics of all parts together for the first time … ![]() ![]() When axles and chassis are bonded I always run in to problems fitting the rig in my foto corner, making it harder to get a good pic … Total weight right now: ![]() |
![]() | #44 |
Looking good. My high clearance links have not arived yet. They do look good. I started out with scx shocks then went to BB with shock cap mod. However i will soon be going back to the scx shocks as you have for similar reasons. Keep up the good work. Sent from my GT-I9300 using Tapatalk 2 |
![]() | #45 |
Thanks Oz ... you will like the HC lowers for sure ![]() |
![]() | #46 |
Rock Stacker Join Date: Feb 2009 Location: Amsterdam The Netherlands
Hi Ronald can you give me the length of the upper links in a mail to me,great pics als always Jan (SuDoOne clan Holland) |
![]() | #47 |
Jan, I send you a PM ... ![]() I will put the info down here also .... mock-up upperlinks as shown in the previous post are 110mm in front and 128mm in rear e2e length. |
![]() | #48 |
Hey Ronald there was a couple of reasons at. the time i swapped out the scx shock. The main one from memory is i didnt have good spring retainers buy as of the last order Tomi made me some from delerin. Also at the time had just litrerally taken the scx shock of a scaler and they needed a clean up. It was just easiet to use the BB's i had. The BB's work very well and i am happy with them but the scx shocks are a lighter setup so am going to give them a go again. Sent from my GT-I9300 using Tapatalk 2 |
![]() | #49 |
Shelf queen ![]() Join Date: Aug 2008 Location: Internet
Those are some beautiful lower links. they look almost organic.
![]() | #50 |
| ![]() I agree ... they look natural indeed ![]() Well … I am in the waiting room here, I had to order some parts before I can really proceed. I was hoping to make use of some reinforced stock AX10 driveshafts but I didn’t have enough driveshaft parts to get to the desired length for the rear. So being obligated to get parts I decided to go with the WB8 shafts instead . Also ran out of 2mm spacers, so those are on order as well. I mocked up the upperlinks using Axial rodends (6mm) and they touch the chassis only a little bit on the rear when articulating. Revo ends have a 7mm diameter so in order to run them free I will have to space out the sidebraces a bit ![]() While waiting for the parts I will get to making the CF upperlinks and work on rims and tires … Some random pics of current state … ![]() ![]() ![]() |
![]() | #51 |
Good to see those rims on your rig ![]() Sets everythig of nice. Are they your own design or Douwe's? |
![]() | #52 |
Rock Crawler ![]() Join Date: Mar 2010 Location: Happy Top
So dang clean. ![]() |
![]() | #53 |
RCC Addict ![]() Join Date: Oct 2008 Location: Finland
Very nice, Ronald!
![]() | #54 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Whow Ronald!!! Nice work.. Now for some nice, shaved, tires!! Then electronics time!! Any plans on what electronics you are going to run? |
![]() | #55 |
Rock Crawler Join Date: Oct 2009 Location: Brussels
These rims are very cool ![]() |
![]() | #56 | ||
| ![]() Quote:
![]() Thanks man .... Can't help it, it is compulsive and the way I like it ... ![]() ![]() Thanks Tomi, all parts are great finished ![]() ![]() Quote:
I got all electonics sorted out, noting fancy or unfamiliar .... details will folow when ready ![]() Thanks Alex ![]() ![]() Last edited by Haastnooit; 04-05-2013 at 05:07 PM. | ||
![]() | #57 |
Nice design Ronald, you're the third wheel designer in the SuDoOne Team 1.Douwe,2.Ben.3.You. you guy's make it difficult for me to choose the right wheels Jan(SuDoOne Clan Holland) Last edited by vovo; 03-28-2013 at 03:27 PM. |
![]() | #58 |
Thanks Jan ... It is fun to make wheeldesigns, I made these special for this build ... But I also gave the template's of my design's to Tomi ... so far I did about 10 I think. But you know what, I bet we all haven't seen all of Douwe's en Ben's designs yet ... ![]() |
![]() | #59 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
This build is coming along great! I like all the wheel designs also.
![]() | #60 |
| ![]() Thanks 63comet my pace is good and everything is falling together nicely ... ![]() I was able to get some more work done tonight, I got the CF upperlinks done. I was talking with TotoRax about his CF upperlinks before. I really like his way of constuction and the good results he has with it. Pics of testing them to failure convinced me easy … If I would do CF tubelinks it would be TotoRax’s way …. So here is my first go at it ... CF upperlinks Axial rodends TRX revo balls CF tube 4x0.75mm Mockup links are done with Axial rodends, which makes it possible to space out the sidebraces with just revo balls. Additional spacers are needed for using revo ends, cause they will bind on the chassisplate while articulating. The smaller diameter of the Axial rodend is helping there, no binding … BUT … also made me nervous there was enough meat left when drilled out and tapped … I decided to just try it and go for the Axial rodends ![]() How to make CF tubes “The TotoRax way” :
![]() To make sure they are the correct length I made me a quick “linkboard” to glue them up. Poor hand drilling skills resulted in only one hole available for making the 90* rotated rodend frontlinks. I will let them cure overnight and install them tommorow … |
Tags |
axr10 axle, sudu, suduone, xr10 mod |
Haastnooit's YTC Secret Agent 3.5 | Haastnooit | Axial XR10 | 85 | 04-24-2022 12:04 PM |
Team NCD Su Du One | Oz Bruiser | Axial AX-10 Scorpion | 132 | 12-21-2013 04:34 PM |
NCD SuDu one crawler | douwe | Videos! | 2 | 11-28-2012 02:36 PM |
Mini AXR10 Axles?... | justinart24 | Tools, and Procedures | 6 | 10-15-2012 09:28 AM |
Haastnooit's Old Skool YTC BJ4 | Haastnooit | Axial XR10 | 15 | 09-02-2012 06:57 AM |
