12-02-2014, 05:33 AM | #121 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Re: Papa's BWD Nightmare S
Got my 32 pitch gears in so I was able to install the Holmes Puller 500 13t motor. In order to keep the COG as low as possible, the Delrin chassis brace gives just enough room to fit a 540 size motor between it and the skid. I like to run my BW Motor Sav'rs on all my motors, but the extra thickness put the Delrin brace in a bind. At first I just cut a chunk out of the top of my Motor Sav'r, which did the job and removed the binding: This was an easy fix and worked fine, but it looked kinda ghetto to me, so when I installed the new motor, I stuck the brace on my mill and removed about 1/4 the thickness of the brace just over where the motor sits like so: Now the brace sits level with no binding and my Motor Sav'r is intact. The material could easily be removed by a Dremel, and the result looks much better than hacking the Motor Sav'r IMO: Another view showing the new gears, BW motor plate, etc: Last edited by papabash; 09-15-2017 at 11:14 PM. |
12-02-2014, 10:11 AM | #122 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
OH YOU FANCY Sent from my iPhone using Tapatalk |
12-02-2014, 05:00 PM | #123 |
| Re: Papa's BWD Nightmare S |
12-02-2014, 05:04 PM | #124 |
Lol Sent from my iPhone using Tapatalk |
12-02-2014, 05:05 PM | #125 |
Obsessive crawler disorder ... Or in troys case obsessive crawler dremeling Sent from my iPhone using Tapatalk |
12-02-2014, 05:13 PM | #126 |
Yeah, I have that too! Not the excessive Dremeling, though... |
12-02-2014, 05:32 PM | #127 |
It's not excessive.. To have to take a dremel to Everything! Sheesh.. Lmao.. My worst one is, obsessive crawling disorder... :thumbsup: |
12-03-2014, 08:31 PM | #128 |
Didn't take long to get tired of my old beater body being zip-tied on for testing, so I finally took the time to make some proper body mounts. The Delrin chassis brace has 3 holes for body mounts; the front one was perfectly positioned for the body, but the rear ones need to be further back. Don designed the brace with 2 rear holes so that a mount could be made to the appropriate length and attached to both holes for lateral strength. I fabbed a mount out of some G10 I had lying around. This one is temporary until I'm ready to mount my good body, then I'll adjust the length accordingly and make a new one. Anyway, here's a shot of my rear mount: I'd much rather mount my body this way instead of to the round chassis brace. This way it stays put and doesn't rotate with the brace and jack your body. Last edited by papabash; 09-15-2017 at 11:16 PM. |
12-03-2014, 08:42 PM | #129 |
Ooooohhhhh oooooooohhhh I want one Sent from my iPhone using Tapatalk |
12-04-2014, 02:19 PM | #130 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
I like the mount but I wanna do a gunnar style, shouldn't be too hard - I HATE body pins.
12-04-2014, 07:36 PM | #131 |
| Re: Papa's BWD Nightmare S Actually, I was going to put Gunnar style mounts on, but I only had white screws and wanted to wait till I can pick up some black ones. It'll be super easy to change it out later. For now, body pins will be fine while I'm testing and tuning. In the past, I have always used locking body pins and have never lost one.
12-04-2014, 08:55 PM | #132 |
I have black ones if you need some Sent from my iPhone using Tapatalk |
12-05-2014, 04:42 AM | #133 |
12-05-2014, 07:39 AM | #134 |
I'll see what I got and send them out Monday ... Sent from my iPhone using Tapatalk |
12-05-2014, 08:47 AM | #135 |
If PURPMART doesn't have any, I have some stock in them.. I use them to make similar body mounts to the custom Dlux one's I run. Prefect to get rid of the Gunnar clip from rolling ur body around. The body post acts as a set screw and tightens down on the cross brace.. |
12-05-2014, 08:14 PM | #136 |
12-05-2014, 08:17 PM | #137 | |
| Re: Papa's BWD Nightmare S Quote:
12-05-2014, 08:17 PM | #138 |
I have like 20 how many and how long you want Sent from my iPhone using Tapatalk |
12-05-2014, 08:26 PM | #139 |
A couple of 2" ones should do.
12-06-2014, 04:30 PM | #140 |
Aye aye captain Sent from my iPhone using Tapatalk |
Papa's BWD Nightmare S - Similar Threads | ||||
Papa's Wraith Re-Build | papabash | Axial Wraith | 72 | 04-17-2014 07:31 PM |
Papa's BrATMOBILE | papabash | 1.9 Scale Rigs | 48 | 03-01-2014 03:34 PM |
Papa's BWD G10 Sporty | papabash | Axial AX-10 Scorpion | 62 | 06-17-2013 10:14 AM |
Kratos Bwd "Nightmare" build | Kratos | Axial XR10 | 31 | 06-10-2013 03:24 PM |
