12-07-2019, 09:52 AM | #201 |
RCC Addict Join Date: Apr 2008 Location: Singapore
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy
Narrow Track Width Vanquish Portal Axles Advantage: The Narrower track-width may manoeuvre between tightly space path between rocks. 1.9 Ottsix 4.75" Tires does NOT Bind with the lower links at Full Left and Right Steering Tighter Pin Turns with Dig Function That said, some might totally disagree or have a much better idea based on their Experience. PEACE! SUGGESTIONS Only: Please Ignore if you do not agree. Thanks! Need at least (12) narrow or Vanquish Ball-Link to fit slightly narrow Vanquish Portal Axle Upper and Lower link and Shock Mounts. No need to adjust length of Link to clock Portals Axle Angle to increase Max Clearance, Straighten Driveshaft Angle and Drivetrain Geometry. Please Use "Top-Most" Link Mount Skid-Plate side, for all Lower Links Use f/r upper shock mounts closest the axle. Used Option Upper Front Links included in the Vanquish Portal Servo Mount Set Thanks for your Interest and Patience. ENJOY Last edited by Siggy; 12-07-2019 at 10:13 AM. |
12-07-2019, 11:19 AM | #202 |
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy And yeah, the Hobbywing XERUN XR10 Pro 160A + Xerun V10 17.5T G3R combo is not just for 1/10 Racing. It can work GREAT with a 9T Motor Pinion, sensored cable, and 2S 7.2V. Ir Honestly WORKS Fine. But if your are planning to GO HobbyWingV10, the 21.5T and 25.5T is the Manufacturer's recommendation or Rock Crawlers. My idea of a Racing PowerPlant is something like the MGM 80063-3 (800A Continuous/1000A Burst) + NEW LMT 30100 (53 HP) @ 15S 48V Sometimes we Like to GoSow and Sometime to Go GoFast. ENJOY! Last edited by Siggy; 12-07-2019 at 02:14 PM. |
12-07-2019, 11:54 AM | #203 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
That looks like a very serious rock crawling machine, nice!
12-07-2019, 02:12 PM | #204 |
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy |
12-07-2019, 04:55 PM | #205 |
12-07-2019, 04:58 PM | #206 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy Quote: TOOOOOO much chrome in those wheels. It's blinding me. ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
12-07-2019, 05:17 PM | #207 | |
My Sincerest Apologies! PEACE! SSD 1.9 Champion Beadlock (Black Wheel + White Beadlock Ring) Team OTTSIX Racing Voodoo 1.9 KLR X4 1.9 (Red) Crawler Innovations Lil Nova 4.75" Crawler Dual Stage Foam w/Comp Cut Inner (Soft Outer) | |
12-07-2019, 05:49 PM | #208 |
Now, from that angle, I can see the wheels are mostly black. From the other angle, they really liked like 100% chrome finish. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
12-07-2019, 06:06 PM | #209 |
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy Re-Assembled and Running! Last edited by Siggy; 12-07-2019 at 06:11 PM. |
12-08-2019, 09:24 AM | #210 |
A Good Discussion about the Axial Racing 1.9 Capra. Please Ignore if you think inappropriately off-topic. An Thanks for your Patience and Interest |
12-08-2019, 09:35 AM | #211 |
I think it's 'good'...not "inappropriate". Tho, I will admit, sometimes my thoughts/opinions don't 'mesh' with the forum rules (I'm NOT saying your post goes against forum rules...it's probably within the allowed rules). Personally, I've been wondering/pondering the same questions mentioned in the 'discussion'. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
12-08-2019, 09:39 AM | #212 | |
12-09-2019, 12:09 PM | #213 |
10 years ago, a DIG was purchased separately for the AX10 Rock Crawler The Capra Transmission is with a built-in Dig. Some disengage the Dig function, swap for the OG AX10 Tranny/SkidPlate, or Go 4WS. I HONESTLY got NO idea WHY?! Anyways HERE's some of my own ideas regarding installing. Again if you violently disagree, please kindly ignore. PEACE! I used the recommended SX107 to make installation easy. I wish I can a bigger Servo as tiny ones will be less tolerant to Failures in making proper EPA Setting - Overheat leading to a Premature Failure! Please check Internal BEC settings to be at 5.5v or 6.0v -- especially if your powering the SX-107 via RX. Make sure the Servo is Centered via Radio Setting (Sub Trim) Install the Dig Servo/Servo Saver Horn mid-way position between 4WSD and Dig. Using Futaba 7PX Transmitter. Use your preferred Radio Set with the 3 position-switch capability. Adjust EPA at a starting point of 20 left and 20 right. Increased steering end points value in small increments, making sure 4WD, 2WD, and Dig properly engages and disengages. I assigned DT4 at 100 (3 way switch) for channel 4 4WD-2WD-Dig *do not over-tighten screw that secures horn to the servo ** Do not over tighten screw that secures hood to the dig shifter *** I think, a little "play" is ok BEST to Test 4WD + 2WD + Dig Functions before installing tranny into the model. Thanks for your interest and patience. Enjoy Last edited by Siggy; 12-12-2019 at 01:58 PM. |
12-09-2019, 10:17 PM | #214 |
12-09-2019, 11:07 PM | #215 |
Axial Racing 1.9 Capra Unlimited Trail Buggy HobbyWing Xerun XR10 PRO ELITE G2 160A HobbyWing Xerun V10 G3R 17.5T Tamiya Buggy Champ Internal Shock Springs 9T 32P Motor Pinion Team Vitavon Racing Transmission Spektrum SX107 Dig Servo Futaba HPS A700 Steering Servo Futaba Servo Horn Clamp-Type SSD 1.9 Champion Beadlocks Team Ottsix Racing Voodoo KLR X4 1.9 Crawler Tires (RED) Crawler Innovations Lil Nova 4.75" Crawler Foam w/ Comp Cut inner (Soft Outer) Team Vitavon Racing Real Carbon Fibre Panels Vanquish Products Portal Axles Vanquish Products Portal Axle Servo Mount SSD Steering Links Traxxas 4-LED Fog Lamp Futaba 7PX System Thunder Power 7.2V 400mAh RX Spektrum Smart 3S 2200mAh 100C |
12-10-2019, 12:56 AM | #216 |
2.2 Rock Beast II + SSD Rock Racer You'll need Wider Offset Wheel Hubs. The 2.2 Rock Beast II BIHNDS with the Lower Links. Last edited by Siggy; 12-10-2019 at 12:58 AM. |
12-11-2019, 07:15 AM | #217 |
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy 3 Rock Racers |
12-11-2019, 11:16 PM | #218 |
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy KUDOS SuperShafty! Simply Totally AWESOME News for FULL Competition 2.2 Axial Racing Capra Unlimited Rock Crawling Team Drivers! Of Course 1.9. as well. PEACE! Last edited by Siggy; 12-12-2019 at 04:42 PM. |
12-12-2019, 11:22 AM | #219 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
I'd just like to say here that YOU are almost solely responsible for what's coming my way on my birthday in a couple weeks! When the Capra hit the shelves, I had no interest... I would work on my trx4's and my other crawlers without a care in the world... happy to have what I have. But like a kid playing with fire, I watched some Capra vids and although impressed... I was still content without one. Then one day like a big ol' dummy, I opened up this thread. Well... that's where the seed began to take hold. Now I open this thread every time there's new activity... salivating, oohing & ahhing, helpless to rid my mind of this truly inspiring build. Hope you know... You're a dangerous dude to follow around! |
12-12-2019, 11:31 AM | #220 |
Pebble Pounder Join Date: Oct 2019 Location: Kula
Is there an ETA on the SS axles? Sent from my iPhone using Tapatalk Pro |
Siggy's Capra 1.9 Unlimited Trail Buggy - Similar Threads | ||||
💥IN STOCK NOW💥 NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! | RPP Hobby | RPP Hobby | 0 | 09-27-2019 09:29 AM |
PRE-ORDER NOW the NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! | RPP Hobby | RPP Hobby | 0 | 09-12-2019 10:43 AM |
Class-3 W.E. Rock Unlimited Buggy build | kona_joe | 2.2 Scale Rigs | 12 | 12-06-2015 09:05 PM |
Siggy's RC4WD Trail Finder 2 | Siggy | RC4WD Trail Finder 2 | 21 | 02-21-2012 10:51 AM |
