Thread: Dual Dingo build thread-My first build thread
Old 10-02-2012, 06:01 PM   #81
Default Re: Dual Dingo build thread-My first build thread
Originally Posted by FORDROX97 View Post
That looks pretty cool!
Thanks looking forward to getting some of the lights on.
juswin24 is offline   Reply With Quote
Old 10-02-2012, 07:09 PM   #82
Got the driver side bezel glued in place. I drilled three #19 drill holes in the body and applied Shoe Goo from the inside through the holes. Once I glue the light bucket in it should add some more strength.
I think it looks better than the decals that were there.
Old 10-04-2012, 06:47 PM   #83
Finished gluing the grill and bezels.
[IMG][/IMG]
Old 10-05-2012, 10:35 PM   #84
Looks great, awesome work.
maxxdrive is offline   Reply With Quote
Old 10-07-2012, 12:19 PM   #85
Got the light buckets glued in. Also added the re-enforcement around the front body mounts, rear has been done already.
Old 10-07-2012, 02:09 PM   #86
Looks great man! Too bad no one else is lookin...
mitchr97 is offline   Reply With Quote
Old 10-07-2012, 02:53 PM   #87
Well, the count goes up but comments are here or there. That's Ok. I hope it inspire's some! I don't comment a lot but I do read a lot of the threads.
Thanks for hanging in! I've been watch'n yours too.
Old 10-07-2012, 02:57 PM   #88
I'm thinking of adding a badge. I know it is smaller than the one on the original decal. It's 1/2" in diameter. I'll paint it black and will be adding one of the decals from the sheet. The other could be the square one. The color would be black and the decal looks like it would show just fine since white is in it already.
What do you guys think?
Old 10-08-2012, 05:30 AM   #89
What do you think of the idea of the badge on the grill? Any suggestions? Thanks!
Old 10-08-2012, 07:53 AM   #90
i prefer the clean grill without badge
of the 2 badges i like the round one better
Nelanzor is offline   Reply With Quote
Old 10-08-2012, 03:58 PM   #91
I'm not really sold on either one yet. The styrene is too thick for one thing and I don't want to spend $3-4 on more right now.
Old 10-08-2012, 07:16 PM   #92
It would make a killer trail video!
MX4141 is offline   Reply With Quote
Old 10-08-2012, 07:19 PM   #93
Did you see one of my trailers? I made three and just wondering if saw them.
Old 10-09-2012, 05:43 AM   #94
This is the third Trailer video I made. Last one for now. I'm working on a trail video now.
Old 10-09-2012, 07:14 AM   #95
Great build. Awesome video. I can't wait to see more
DudeWalker is offline   Reply With Quote
Old 10-09-2012, 04:11 PM   #96
Get'n ready to start making the LEDs wiring setup. Layed the parts out to see if I have what I need.
Old 10-09-2012, 04:17 PM   #97
For power I plan on pulling 6V from my Castle BEC which it is set at. I'm using a servo Y harness to split off the power. The amp draw is minimal, milliamperes is what we will pull from the BEC. You can figure that using LED series parallel array wizard.
Old 10-09-2012, 04:25 PM   #98
These are the mini DPDT toggle switches I will be using. Got these off of eBay. I pack the toggle opening will dielectric grease. I'm going to use servo extensions wired to the switches so I can disconnect the body. I might need to plastic dip just for the fact the body needs to get washed. Not sure if its needed or not.
Old 10-09-2012, 04:42 PM   #99
I made some wiring diagrams to guide me along. If I'm right, all the negative wires can be tied together along the way back to the negative tap from the BEC. the positive wires have to lead back to the outter taps of the switch. The center tap will be the positive power from the BEC. The left diagram is for the headlamps and tail lamps only. You can see I'm using the left side of the switch terminals. I'm connecting the positive to both out taps so if the switch forward or back, the lamps will be on. The diagram on the right is to power the large lamps on the bumper. They are wired on the right side of the switch and only to the front taps. When switch is back main lamps and running are on. Switch forward and main, running and large lamps of bumper are on. This is what you should be able to do with a DPDT switch.
Update:
Just noticed on the diagram, I left the headlamps off the left diagram. I've decided to have main lamps and running lights on at the same time. I originally planned on the running lights and then switching on headlamps. Doing this leaves switch 2 with one side open in case I add a light bar.
The plan is for three stages:
1- main lamps and running lamps
2- main, running and lamps on bumpers front and rear
3- rock lights on the Dingo with fender wells
4- OPEN, might be for light bar
I will draw up new diagrams tonight.
IF IM WRONG ON ANY OF THIS, PLEASE CORRECT ME, thanks.
Old 10-09-2012, 05:10 PM   #100
Really digging the detail!
rainbuhdrawp is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/398956-dual-dingo-build-thread-my-first-build-thread.html
Posted By For Type Date
I don't want to grow-up, 'caus if I did... DINGO Build - RC Rock Crawlers & Scalers @ URC Forums This thread Refback 03-06-2013 09:58 AM
Dual Dingo build thread-My first build thread - Similar Threads
Dual dually project thread... truckerbuddy2 1.9 Scale Rigs 20 07-10-2013 11:38 AM
Axial scx10 dingos in the sun crazycrawler94 Videos! 3 04-10-2012 02:03 AM
Axial scx10 dingos in the sun crazycrawler94 Scale Videos! 0 04-01-2012 03:26 PM
Axial Dingos with GOPRO Hero2 crazycrawler94 Scale Videos! 4 01-28-2012 09:40 PM
Axial dingos having some fun! crazycrawler94 Videos! 9 01-18-2012 12:41 PM
