06-18-2012, 11:03 AM | #141 | ||
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Thank you for your business. Quote:
5.5 Double Deuce Pair Narrow / Medium Front Narrow / Firm Rear | ||
07-07-2012, 02:51 PM | #142 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Recently did a comp and found the following. Running my Bully at 4.84lbs with 55/45 bias and soft/medium 5.25. White Rovers. All wheels are 1"SLW's and narrow inner foams. The rear gave little traction on side hilling. Swapped ends on slippery side hill. The 5.5 soft outer foam feels quite a lot softer than the 5.25 soft foams. Subsequent testing showed the following. The soft 5.5 soft foams gave better side traction and also feels softer by the touch installed. Soft 5.25 showed better tyre side ways deflection but less traction than 5.5 soft. Conclusion. Running rig at under 5 lbs and better than 55/45 bias, soft/soft and 5.25/5.5 is the way to go for optimal traction. |
07-09-2012, 12:20 PM | #143 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Pm sent.
07-09-2012, 12:41 PM | #144 |
Invoice paid |
07-11-2012, 11:45 AM | #145 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
Which DD's would you recommend for 2.2 Pitbulls, DNA 1" wheels, rig weight about 2,6kg Thanks, Heido |
07-11-2012, 11:52 AM | #146 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* |
07-11-2012, 12:28 PM | #147 | |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
I was thinking of 5.5's. What will happen if I use those? My rig is a comp crawler... We have a lot of small sharp edged rock, a lot of holes to bind the wheel. (not my rig on the pic) | |
07-11-2012, 01:08 PM | #148 |
Pitbull Tire Height is 5.25" Tall (roughly) and very wide, yet you want to stuff that tire with a 5.5" tall foam? Why? Especially on a competition 2.2 truck weighing 5.7 pounds? Just like my signature says: - Give 20 people the same chassis & axles, & they'll build a crawler 20 different ways. - It's no different with tires, foams and wheels. Every terrain, crawler, and driving style is different. The 5.5 inner is taller and uses a taller outer foam compared to the 5.25. A 5.5 Double Deuce is going to stiffen the overall tire, in your case over stuffing the foam beyond the need of your 5 pound 2.2 comp truck. Now if you had a 7+ scale truck, then yes, the 5.5 Double Deuce would have been what I suggested because the over stuffing of the tire would have been necessary to compensate for the heavier weight. Both my 2.2 Pro & 2.2 Sporstman competition trucks use the 5.25 Double Deuce. |
07-11-2012, 01:16 PM | #149 |
Thanks again. Will order the 5.25's later tonight |
07-11-2012, 05:02 PM | #150 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
07-11-2012, 06:33 PM | #151 |
Got my order today, damn fast shipping. Thanks!!!
07-11-2012, 07:38 PM | #152 | |
Control in the rear. When the weight shifts to the rear on a climb, the soft outer and rear tire will collapse down to the closed cell inner. The tire will feel more like a bias ply (spongy) instead of a radial (controlled & more predictable). Thank you for your business. Last edited by Nova's Ark; 07-11-2012 at 07:39 PM. Reason: spell check | |
07-12-2012, 02:23 AM | #153 |
Newbie Join Date: Jun 2006 Location: Van BC
Hey there, just placed an order for some 5.5", but realized I should have went with the 5.25" with tuner's instead. Fired you off a PM with the details and order number, hope it is easy enough to change the order. Can't wait to try these out-thank you. Vanquish 1"/Sedona combo, sorry don't have the weight just yet, rig is still in the work up, but XR w/CF chassis is the short of it. Thanks again....... |
07-12-2012, 10:12 AM | #154 | |
07-18-2012, 09:31 PM | #155 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Please use this format when asking for which foams to buy: Truck Weight RTR? Truck usage (bashing (fast) or rock crawling (slow)? What brand manufacture tire, compound, any tire mods? How wide are the bead locks? |
07-18-2012, 09:36 PM | #156 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Eddie, in case I didnt tell you before. Thank you very much for an awesome product. Im very happy to be a custoner of yours and the fians are increadable. My foams helped the trucks perfirmance massively. Thanks again. |
07-19-2012, 11:30 AM | #157 |
Thank you, Eddie. Received my foams yesterday, was that fast Hope my tires arrive soon, can't wait to try them. Heido |
07-23-2012, 01:10 PM | #158 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
Uber fast shipping as always....thanks Eddie!
07-25-2012, 03:00 PM | #159 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
Looking to change the foam set up i am currently running. Using the stock BC memory foams. Seem to do pretty good so far but know that is going to change once the weather here in the Northwest heads south!! As in rainy and $h!tty!!! 4lbs 10oz. Crawling Boss Claws shaved sidewalls with every other row removed. Width is 0.78" Dlux carbon fiber wheels We run on some epic mono but were i practice and have comps on is large riprap boulders. The pic is a little dramatic, but a rig will get swallowed up in a hole really quick!!! Was thinking of going 5.25 Front - Narrow/Soft Rear - Narrow/Medium |
07-25-2012, 06:57 PM | #160 |
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
