08-06-2012, 11:25 AM | #161 |
Rock Stacker Join Date: May 2011 Location: Northglenn, CO
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_*
Placed order last night for a 2 pairs of Double Deuce 6 inch foams, heard great things so far so I gotta give them a shot.
08-08-2012, 12:14 PM | #162 |
Pebble Pounder Join Date: Nov 2011 Location: Sweden
Last year I bought some CI DD foams for my XR whith stock wheels (1,4" wide) with white compound Rovers. I then read lots of build threads with recommendations to get the 5,5" DD foams for that wheel/tire combo. I have ran the CI Double Deuce 5,5" from last year (open cell inner foam) in my Rovers since then. They work very good for me. Now I am planning to buy another set of White Rovers for my AX10 with stock wheels (1,25" wide, I think). On the CI website the Rovers are sold as a combo with 5,25" DD foams. I understand this combo as a recommendation. My question now is: Has the recommendations changed with the change from open cell to closed cell inners? Or did i miss something else? |
08-11-2012, 06:36 AM | #163 |
Anyone? What size DD closed cell foams are you running in your HB Rovers? |
08-11-2012, 07:42 AM | #164 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I am amazed on what Eddie's foams have done for my Scaler. They support the rig and still have a great foot print. They allow the tire to act like it should. My rig has improved in ever way. It climbs better, turns better, sidehills better, DAMN it even parks better. The 1st hop-up I would do on any rig, would be to install Eddie's foams. Little video Eddies foams - YouTube |
08-14-2012, 02:23 PM | #165 |
Rock Crawler Join Date: Apr 2009 Location: bend
Just placed a order for my wraith 5.5 med with tuning ring weight about 8lbs used for crawling to fit in 5.75 iroks can't wait !!!! |
08-15-2012, 11:34 AM | #166 | |||
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Quote:
New product, made from new materials, in new sizes, Yes, the system and recommendations has changed. Quote:
Recommendation for you based on your post: 5.25" Double Deuce Pair Wide / Soft - Front Wide / Med - Rear Quote:
WW Ricky! Thank you for the awesome feedback and great video. I am glad you are enjoying the new design more than the original. Thank you for your order, it has shipped. | |||
08-17-2012, 06:01 AM | #167 | |
With 1" wheel width (narrow inners) and a front heavy rig can't it be that soft is too soft/unstable at the front and medium too firm at the rear (while not going up steep slopes)? I consider buying 5.0" foams with medium outers and soft tuning rings for all four wheels instead. (In effect triple stage foams...) Does that seem smart or am I way off in my thinking? | |
08-18-2012, 11:39 AM | #168 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
I ordered 4 5.5 double deuce foams on Tuesday, had them in my hands Friday. Eddie-o also gave me 2 tuning foams for free because he is just that type of awesome. The closed cell inners are fantastic. |
08-19-2012, 10:43 AM | #169 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* |
08-19-2012, 10:47 AM | #170 |
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* Closed cell inner foams need to be vented if you vent the wheels and not the tires. I use a 1/4" drill bit and drill 4-8 holes around the inner foam.
08-20-2012, 06:44 AM | #171 | |
As the designer and user of my product, I make my recommendations based on weight of the rig, width of wheel, etc. I vent the tire. A leather 1/16" hole punch is cheap and makes nice small holes. I put three to four holes in the tire depending on it's size. The closed cell inner is water proof. The outer foam will absorb water, but with holes in the tires you can squeeze 90% of it out by hand or by spinning the tires fast enough to sling the water out the holes. I do not bother with modifying the closed cell inner for air venting. In the past the inner has shifted on the rim closing the vent hole and air could no longer flow freely. I have also wondered if removing foam from the inner for air venting weakens or softens the inner foam. | |
08-20-2012, 07:44 AM | #172 | |
With the SLW's being channelled, vent holes in the foam and vent holes in the wheel don't have to be lined up to keep the air flowing. Air flow is reduced if the holes don't line up perfectly but air still flows. And the newer carbon/plastic wheels that dont have an inner wheel surface, only spacers to separate the rings, airflow is not an issue with inner foam vent holes. You crazy guys and your holes in your tires! I haven't noticed any softening or weaking by venting the inners. I assumed since the hole is on the same "plane" as the downforce, that it wouldn't matter. But I am not a foam scientist either! | |
08-20-2012, 08:49 AM | #173 | |
They are cheaper than rims. And if you run the CF sexiness, its a non issue. Last edited by BEELZEBOB; 08-20-2012 at 08:51 AM. | |
08-20-2012, 01:05 PM | #174 | ||
| Re: *_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* I bet you wouldn't mind selling me a dozen different alternatives, but I do mind spending that much money... Quote:
I've read other posts in different threads that most users want better grip (softer foams) in the front tires and higher ride (firmer foams) in the rear. But what's "soft" and "firm" is relative to the load, right? With ~4 lbs on the front axle and <2 lbs on the rear you'd get the desired effect by using the same foams for all wheels, right? Quote:
To me it seems better to make holes, if any, in the side walls of the tire. I will use SLWs, and will consider this option too. | ||
08-20-2012, 01:42 PM | #175 |
I bet you wouldn't mind selling me a dozen different alternatives, but I do mind spending that much money... Its darn good practice to have more than you need, rather than SOL with less. And @ $25 a set of 4, way not have 2 or 3 full sets? And to me it seems strange that the wheels that carry the brute of the load should have the softer foams. It depends on weight and tires, but you want your front tires to grip and pull you over, while it is advantageous to have the rears slip a little and not flip you on your lid. Same kinda concept that makes proportional dig so popular I've read other posts in different threads that most users want better grip (softer foams) in the front tires and higher ride (firmer foams) in the rear. But what's "soft" and "firm" is relative to the load, right? With ~4 lbs on the front axle and <2 lbs on the rear you'd get the desired effect by using the same foams for all wheels, right? You're basically spot on, but understand more can be accomplish along the same lines with a bigger difference between your foams. And with new truck in the sub 3.5lbs range, the larger that difference can be. So you punch holes in the outer surface, normally in direct contact with the ground? Seems like a sure way to get dirt and grime inside... To me it seems better to make holes, if any, in the side walls of the tire. Most people put holes in the sidewalls? Either way with holes in your rims, or tires, in any position, shits gonna get in there. Foams are not white for long. I will use SLWs, and will consider this option too. I just spent $180 on 4 SLW's, now you like me, want CF wheels instead. |
08-20-2012, 02:45 PM | #176 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
Sure, the front weighs more sitting flat & level. But we don't have much crawling challenge on flat and level. When you're at maximum climbing angle, the front is so light it eventually lifts off the rock. Now it's the rear that supports the vast majority of the weight.
08-21-2012, 11:59 PM | #177 | ||
The one set of foams I just ordered will cost not just $25, but also $15 shipping (the cheap option, not the $40 alternative with tracking) plus $10 sales tax plus $15 customs handling fee. That's $65 for one set! Quote:
I'll go with SLWs because they seem to best combine quality, plenty of room for knuckle weights, the offset I want and (relatively) low cost. CF (Carbon Fibre?) wheels are not for me. Too light and too expensive. I might spend $2 on a CF look-alike sticker sheet to cover the aluminium rims if I want the look of CF though... There's always sidehill and downhill. Too soft tires bend sideways in sidehilling, and I don't like going downhill with flat tires on the wheels supposed to do the steering. | ||
08-23-2012, 09:17 PM | #178 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
well, I did ordered tons of foams two weeks ago, and also got some free Outer Tuning Ring...lol I really appreciated Eddie |
08-24-2012, 03:52 PM | #179 |
Rock Crawler Join Date: Jun 2009 Location: vacaville
I just want to give my thanks and appreciation to Nova's Ark and Co. I ordered 2 sets of foams the other day and already have them and they came with all kinds of great swag!!!! I'm stoked I got a bumper sticker and a bunch of mini sitckers along with free tunning ring samples!!!!! Thank you so much for the great products and free swag and beening a great vendor here on RCC. James. |
08-26-2012, 05:37 PM | #180 | ||
As for the swag and free samples, it's what I can, as I can, to give back to the RC Crawler community that keeps C.I. viable. Without a great customer base, C.I. would not exist. As always, I'm extremely grateful for the customers and their support. Thank you | ||
*_* C.I.'s Double Deuce Closed Cell Competition Ready Dual Stage Foams *_* - Similar Threads | ||||
Double Deuce foams for HB Rovers on XR10? | Rock Spider | Axial XR10 | 6 | 06-01-2011 04:49 PM |
Deuce Nova's and Lil Nova's Dual stage foams! | bigflex | Tires and Wheels | 6 | 10-06-2009 10:50 PM |
