Thread: Sensored Outrunner motors- Revolver S
Old 04-02-2015, 12:22 PM   #1001
Default Re: Sensored Outrunner motors- Revolver S
With the 56/16 gearing I am at 3.5:1, Im wondering if that was too high and it got hot? I am clueless on it. My slipper wasnt set super tight, running a Robinson Racing slipper unit for a wraith.
Wes
WesTX is offline   Reply With Quote
Old 04-02-2015, 12:25 PM   #1002
Can you send it in for warranty?
dezrik is offline   Reply With Quote
Old 04-02-2015, 12:26 PM   #1003
I already emailed Holmes to ask about that, will get it pulled out sometime this weekend.
Wes
Old 04-02-2015, 12:31 PM   #1004
MODERATOR™
EeePee's Avatar
Yeah go the other way. Volt up gear down. Don't forget that. Always start out small on the pinion and bring it up after you confirm everything is safe.
EeePee is offline   Reply With Quote
Old 04-02-2015, 12:36 PM   #1005
Yesterday with 20 min of bashing with even higher gearing (56/17) it was warm but I could still touch the motor. I brought the gearing down to 56/16 today as I knew it would still have the speed I wanted with 3S and crawl ability.
I started out with 56/13 the first battery pack, then went to 15T, then 17T, and finally settled that the 16T would be best.
Wes
Old 04-02-2015, 01:11 PM   #1006
MODERATOR™
EeePee's Avatar
I don't know what "bashing" a crawler really means, but crawling puts a higher strain on a motor than wide open throttle does.
Old 04-02-2015, 01:43 PM   #1007
Just more like U4 stuff. High speed with some jumps then mixed in with some crawling, sorry for the lack of clarification.
Wes
Old 04-02-2015, 01:49 PM   #1008
MODERATOR™
EeePee's Avatar
I would consider this then; inrunner instead of outrunner.
Inrunner for speed, outrunner for torque.
If you're gonna warranty it, maybe Holmes will allow you to swap.
Old 04-02-2015, 02:31 PM   #1009
Originally Posted by EeePee View Post
... crawling puts a higher strain on a motor than wide open throttle does.
Please expand on that!
In crawling you don't feed the motor even remotely as much power as you do while going fast. You also don't want the motor to deliver much power.
So where's the strain?
Olle P is offline   Reply With Quote
Old 04-02-2015, 02:45 PM   #1010
Stalled/bound up motors react differently than a free spinning motor.
Meatwad is offline   Reply With Quote
Old 04-02-2015, 02:45 PM   #1011
MODERATOR™
EeePee's Avatar
I can't, you're too sciencey for me.
My stuff always smoked or got hotter going slower than faster. Flooring it in binds or getting stuck instead of cruising always made more heat in my stuff.
Old 04-02-2015, 05:42 PM   #1012
This was more of an expirament than anything. The Outrunner was super cool with the torque plus speed combo. An inrunner will be next for sure.
Wes
Old 04-03-2015, 03:13 AM   #1013
... Flooring it in binds or getting...
I agree those situations will put heavy strain on the motor.
That's when we need to think of the limitations and not give the motor power for more than a second or so to prevent it from cooking.
Old 04-06-2015, 09:03 PM   #1014
The Revolver made quick work of the next upgrade, I didn't like the slop anyways.
Old 04-10-2015, 05:33 PM   #1015
Is the torquemaster 550 the same as the SX you posted a video of awhile back? And when will those be in stock?
fr8cture is offline   Reply With Quote
Old 04-20-2015, 08:29 PM   #1016
All this this does is spin my RRP slipper! Great job on the power, it's too much for a fully tightened GEN3, but I like it!
^^ it there a part that fixes this.^^
Alexander_0_1 is offline   Reply With Quote
Old 04-20-2015, 08:31 PM   #1017
Are you running the stubby?
Old 04-20-2015, 08:34 PM   #1018
Nope, I was lucky enough to score the standard size, but I wanted the larger one, even though it came with a hazardous to drivetrain components warning.
Old 04-20-2015, 08:35 PM   #1019
Haha I also have the standard. Going to see what 4s will do soon. Its probably the best brushless motor I've ran.
Old 04-20-2015, 08:44 PM   #1020
I'm with you on that, although so far this thing has already exhausted my current gear combinations, I'm at 54T/16 mod .8... Maybe I'll move up a ring/pinion size, before I start looking for some 4s packs.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html
Posted By For Type Date
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups This thread Refback 10-07-2011 12:03 AM
Sensored Outrunner motors- Revolver S - Similar Threads
are all sensored brushless motors work with any sensored esc? jebster Electronics 8 01-02-2012 10:47 AM
outrunner motors toka100 Axial SCX-10 1 07-05-2011 10:37 PM
Sensored Motors cyberdog Electronics 1 01-08-2010 01:33 PM
