Thread: Sensored Outrunner motors- Revolver S
Old 04-29-2015, 12:24 AM   #1041
Olle P's Avatar
Default Re: Sensored Outrunner motors- Revolver S
Originally Posted by LoneRanger View Post
I drove it for 20 mins today and it did get warm however. Is that normal?
For my Stubby that's normal, if "warm" is defined as "cosy to hold when your hand is cold".
That means it gets warmer than my previous 17.5T 2-pole inrunner but nowhere near hot. It's no wonder this motor gets warmer since it's smaller and I also get a little more power out from it.
Olle P is offline   Reply With Quote
Old 04-29-2015, 02:32 PM   #1042
New home for my Stubby. This should be perfect.
Angus_Beef is offline   Reply With Quote
Old 05-02-2015, 03:38 AM   #1043
Originally Posted by Crawl Space View Post
If you're running a MMP, make sure it's set to smart sense mode with normal timing. Cheat mode will heat it up and significantly reduce efficiency. I can't speak to Tekin or other ESCs.
Why cheat mode should hear it up?
slimfire is offline   Reply With Quote
Old 06-05-2015, 07:38 PM   #1044
Has anyone come up with a solution for keeping debris out of the endbell? I like the fact that the Revolver is a like an Ak47, full of mud and dirt and doesn't even notice. But I don't want it to suck up a pebble and rip a magnet out. I wonder if fine metal mesh could be used on the vent holes in the front or something.
CreepyCrawlyWraith is offline   Reply With Quote
Old 06-06-2015, 06:45 AM   #1045
What about an outerwears?
http://www.outerwearsracing.com/products.asp?cat=12683
novarider is offline   Reply With Quote
Old 06-06-2015, 11:08 PM   #1046
snapon boy's Avatar
That looks to be a good solution there products are very nice. Will the new Holmes hobbies brushless esc drive the revolver motors? Also how well do they do if your pulling a trailer etc.
Thanks
snapon boy is offline   Reply With Quote
Old 06-07-2015, 03:52 AM   #1047
Thanks
Holmes' new controller and a Revolver make and excellent combo. Super quiet, smooth, and mid-range torque that needs to be experienced.
Old 06-08-2015, 07:53 PM   #1048
When do you think you will have more of the 540s in stock?
paintchip31 is offline   Reply With Quote
Old 06-08-2015, 11:46 PM   #1049
Yes, I could also do with another, I pulled the one I have out of my BMRC IF/RS wraith, just so I could test it out on my ascender.
Alexander_0_1 is offline   Reply With Quote
Old 06-16-2015, 02:24 PM   #1050
I too am curious when they will be back in stock
idaho is offline   Reply With Quote
Old 06-16-2015, 02:46 PM   #1051
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Have some parts on the way to test a new winding pattern, it will get rid of the alignment issues but we have to standardize with the factory for future batches. Still going to be months of waiting because of the time between batches, but they are top priority. We will get 540 size motors back in stock first.
JohnRobHolmes is offline   Reply With Quote
Old 06-17-2015, 11:38 PM   #1052
Yes!........so what can I get to tide me over......
Old 06-18-2015, 07:29 AM   #1053
Any way to get an email when they are back in stock? Or just keep checking every day?
Old 06-20-2015, 09:11 AM   #1054
If you subscribe to our newsletter, we will send one out when they are back in stock.
On this batch of protos, I'm getting 3 turn and 4 turn versions to test the KV and back EMF. Should be about 1800kv and 1300kv.
Old 06-20-2015, 09:39 PM   #1055
Oh man 1300kv would be perfect for me I'll definitely subscribe to the newsletter, I'd love to have revolverS motors in all my rigs.
Old 07-16-2015, 10:34 PM   #1056
Positive testing on protos so far!! I love my 4 channel scope, makes aligning the sensors super easy. My changes to the assembly worked like a charm. SUPER snappy forward to reverse operation now, we should have zero timing issues in the future as the new layout gives about 8 mechanical degrees of "wiggle room" VS 0.5 degrees of the previous.
Downside is that our samples were not supplied with the proper laminations so we can't properly test the RPM and wattage limits. But I do have more on the way right now.
3 turn 540 version friggin rocks! Although admittedly I'm spoiled by the speed and smoothness of the 3300kv Puller Pro Stubby. But when it comes to brute torque and predictable wheelspeed through different conditions, the Revolver is absolutely unmatched. The rotor inertia really smooths out small throttle jitters and makes me feel like a better driver
Old 07-20-2015, 10:32 AM   #1057
Can't wait =)
Shinjari is offline   Reply With Quote
Old 08-07-2015, 04:36 PM   #1058
I just picked a revolver S and need a idea where to gear my Ascender at to start out?
Old 08-07-2015, 10:13 PM   #1059
Start at stock gearing....always start at stock gearing, after you take a temp reading, and the temp is still within acceptable tolerances, then start changing the gearing., that is if your not getting to performance your after....
The ascender is easy, there are less gearing combinations to work with...
Old 08-13-2015, 09:21 AM   #1060
JRH,
Sorry if this has been asked before but 50+ pages is a lot to read through but is it possible to get a Revolver S 540-S Stubby made with a 20mm motor mount pattern?
Thanks
fleckofly is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html
Posted By For Type Date
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups This thread Refback 10-07-2011 12:03 AM
Sensored Outrunner motors- Revolver S - Similar Threads
are all sensored brushless motors work with any sensored esc? jebster Electronics 8 01-02-2012 10:47 AM
outrunner motors toka100 Axial SCX-10 1 07-05-2011 10:37 PM
Sensored Motors cyberdog Electronics 1 01-08-2010 01:33 PM
