06-26-2009, 03:08 AM | #301 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Hey Harley, Thank you for all this info on 4PK. I have read every page now, and NOW I have to go get one. This is going to help me be a little better driver . I just can't seem to get the hang of my stick radio. Who do we get a hold of at Futaba to talk you up some more? |
06-28-2009, 11:46 PM | #302 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
HA HA Talk Harley up! He does enough of that himself. Just kidding Harley. We/Futaba are very aware of the AMAZING job he is doing for us. I just finished up at Axial West Coast Challenge and I was blown away how many people are running 4PK's now. Harley has done a great job of helping people understand all the capabilities of the 4PK. OK enough pumping Harley up, his head is going to explode. J |
06-29-2009, 11:00 PM | #303 |
Hey all you guys with 4PK's, you NEED this case Mine came in last week so I got to see how I liked it this weekend. The radio fits like a glove and all the extra spots are great for carrying other things like spare RX's, batteries, servos, some tools, etc. I used the foam from the slots as spacers in the larger areas. Here are some pictures for a little more detail and size reference. |
07-03-2009, 11:32 AM | #304 |
Nice to see you got your "CSI" case. LOL
07-03-2009, 11:51 AM | #305 |
07-03-2009, 02:11 PM | #306 |
I am sure that "Tyrone" will be more than happy to search all the cavities in the case/you. J |
07-05-2009, 09:47 PM | #307 |
Quarry Creeper Join Date: Mar 2009 Location: Fairfield, Cali
Thanks for the tips Harley. This thread has been handy in setting my 3PKS to work with my LCC. One thing I noticed is that upon power on the TX, 3rd Channel dig servo always defaults to -Value, not neutral/center. Did I missed something in the set-up?
07-05-2009, 11:30 PM | #308 |
| Do you have any button assigned as a 2 position switch? If so then the radio will default to either the + or - value. Go to your switch and dial menus and double check that.
07-06-2009, 06:15 AM | #309 |
For those of you looking to get a 4PK, check into this. http://www.futabarc.com/promos/fut-trade-up.html |
07-06-2009, 11:41 AM | #310 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
| Dual FXR's on my Bully Rig
I have a question about dual FXr's and the 4pk... I just got mine running...I have noticed that the rear ESC is not engaging as soon as the front.....the LED on the front ESC will show 1 LED while the rear shows nothing...once I goose it or give it more throttle the 1st LED will light up and the rear will turn the same speed as the front....now I know clod stall does happen...but this seems to be worse and excessive??? I wondered if I needed to back the drag brake down on the rear ESC so I went to 80rear and 90 front...but it did not seem to change much??? am I missing some adjustment?? I even tried bumping up the rear ESC % on the mixing and it still does it...although I did not back the front one down..just bumped the rear up to 110%.. thoughts? sorry if this had been covered...I still have not read this whole thread.. |
07-06-2009, 02:03 PM | #311 |
53 Willys, try reprogramming the throttle positions on both FXR's at the same time. Sometimes if they are not programmed together you will get that same problem. I believe on the Tekins you just hold down the mode button for a fedw seconds to enter the reprogramming mode. Try that and let me know. Make sure all your values are reset so both are just seeing 100% |
07-06-2009, 02:31 PM | #312 | |
now its all in sink and working beautifully......I have to admit I did not calibrate them together the first time....it did not even cross my mind cheers | |
07-06-2009, 03:23 PM | #313 |
07-06-2009, 09:27 PM | #314 |
| Reviewed my setup and found out that my Ch3 servo is on Reverse causing the TX to default to -Value upon power on. Setting the Servo to Normal will force the TX to default to 0/neutral position. Thanks for quickly answering my query.
07-10-2009, 03:32 PM | #315 |
By request of a few people here is a really quick wiring diagram. Sorry for the quality, when printing from CAD it screwed up my line weights. I will try and get a better one loaded up soon. Sorry for the ENOURMOUS size! I made the link clickable now. http://www.harleydesigns.com/images/wiring_4pk.jpg Last edited by Harley; 07-10-2009 at 03:49 PM. |
07-10-2009, 04:24 PM | #316 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
Dam that was quick. Thanks Josh you are the man |
07-10-2009, 04:42 PM | #317 |
07-12-2009, 05:06 PM | #318 |
Josh if i am using this wiring setup: http://www.harleydesigns.com/images/wiring_4pk.jpg what voltage should i have my ccBEC set to? Futaba 4pk Jpcustomrc R45T motor 2ea Tekin fxr esc 2ea ccBEC Futaba s9157 servo 3c lipo 2200mah/ 25c+ |
07-12-2009, 05:14 PM | #319 | |
6 volts is a very safe voltage to run. That is what I run and what I suggest. Quote:
07-12-2009, 07:04 PM | #320 |
Moderator Join Date: Jul 2007 Location: Texas baby!
6 volts is also the max voltage the 4PK receiver is rated at as well.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
