09-15-2009, 12:41 AM | #401 | |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Nice new Personalized skin . Looks good. Last edited by 70duncan; 09-15-2009 at 07:18 AM. | |
09-15-2009, 07:48 AM | #402 |
| Thanks for the clarification for sure, now I know. Oh and thanks on the skin too, I sat over at Neal's house and we tweaked it just how I wanted. Loving it now, won't be grabbing anyone else's radio again by accident.
09-15-2009, 03:28 PM | #403 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
09-15-2009, 03:33 PM | #404 |
09-15-2009, 03:38 PM | #405 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
I loved the radio, loved being able to hook it up via usb to program, loved the features, just the rx's were crap. | |
09-15-2009, 03:42 PM | #406 |
09-15-2009, 03:45 PM | #407 |
09-15-2009, 10:11 PM | #408 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
Thanks for the setups on the 4pk you saved me a lot of time, you also influenced me to return a spectrum and buy Futaba. Like many others I am glad I did. Just what the LCC MOA needed. Mike |
09-15-2009, 10:32 PM | #409 |
09-16-2009, 03:30 PM | #410 |
09-16-2009, 03:42 PM | #411 |
09-17-2009, 06:30 AM | #412 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
Harley the wrap looks sweet. "I had a nomadio react, after burning through like 10 receivers I got rid of it. The only thing that was worse that the receivers was the customer service." Jason our receivers don't burn up and we have excellent customer service. Maybe you should ask Badger to get you a 4PK for Christmas. "you also influenced me to return a spectrum and buy Futaba" Nice job Harley. You won't regret your decision Mike. Redneck21 That is awesome. You are going to love the radio. If your running dual esc setup it is great. I think Harley was a first grade teacher at some point. He has done an amazing job of walking through the setup of just about any configuration imaginable. J |
09-17-2009, 12:00 PM | #413 | |
Quarry Creeper Join Date: Aug 2009 Location: Palo Alto, Bay Area
Well, I have no idea how you brun through the rx's, but I haven't had the problem. I jsut checked their site, I was wong, its max input isn't 12v, its 17v. Again, What I am actually looking for is the differences in features, programmability and waht not. I don't care if some of you have had a bad experience with noamdio parts dying, becasue I haven't had the problem. I have been running nomadio for 3-4 years. I would like to know if the 4pk actually does anything the nomadio doesn't, other than carry the badge. I'm not going to blow $500 on something that is no better than what I have already, but with a different badge. | |
09-17-2009, 01:03 PM | #414 |
09-17-2009, 03:06 PM | #415 |
Rock Stacker Join Date: Jan 2009 Location: Aurora
| Always on?
Harley I was wondering if you knew or if you could ask your friends at Futaba if there is a way to set the controller up so that the 3 and 4 channel are normally on instead of off. Then you could use the switchs in "nor" as momentary instead of on/off and could switch between digs alot faster. Thanks for any help |
09-17-2009, 03:09 PM | #416 | |
Give me some exact specs on your setup and I will see if I can suggest something to fit exactly what you want better. | |
09-17-2009, 07:39 PM | #417 |
Ok so when you set it up with 2 esc's you set 1 switch up to turn on and off pre mix 1 in "alt" and 2nd switch to turn on and off pre mix 2 in the "alt" position. So when you push it it turns it on then when you push it again it turns it off as set-up like you use. But if you leave the switchs in the "Nor" position you have to hold them down to activate that channel and when you let off it is deactivaded. And what I would like is that it is in 4wheel drive all the time hence 3 and 4 channel on all the time and then when you hold down the button it would open the signal the that channel instead of closing it. So you could hold the button when you want dig (open) and then let off and it automatically closes the channel again. Does that make sense hopefully?:? Thanks |
09-17-2009, 08:42 PM | #418 |
09-17-2009, 10:07 PM | #419 |
09-18-2009, 05:43 AM | #420 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Would also love to have Futaba make a reasonably small receiver. These receivers are huge compared to any other big brands out there. That is my only real complaint so far.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
