08-14-2009, 07:18 AM | #361 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
I use the AT-Start (engine cut) function on my 3PK for my boat with an RCMK. Basically when you push a button it puts the servo to a preset location that is not dependant on the EPA's. That way you can adjust the EPA's so you don't kill the engine by accident. | |
08-14-2009, 03:16 PM | #362 | |
Newbie Join Date: Jan 2009 Location: Netherlands
BUT this morning I took some time alone with my 4PK and I think that I've got it!! The boat is currently under construction but in the 'servo view' things are working so I guess it will also work for real. If anyone wants to know HOW... then I'll look up what I did and write it here?.... | |
08-19-2009, 10:27 PM | #363 |
Quarry Creeper Join Date: May 2008 Location: Grande Prairie, Alberta, Canada
I picked up the 4PK a little over a week ago but just now found this thread. While the tread is amazing for getting me set up I am having an issue with the receiver. I thought I had in bound but now the receiver gets an error about 20 seconds after powering up the truck. I tried re-binding it but it didn't seem to work. I am hnestly a bit of a newbie to 2.4 radios so if you have asuggestion please help me out.
08-19-2009, 10:58 PM | #364 | |
If you still can't get it to work then sending it into Hobby Services is your best bet. They will get you turned around quickly. | |
08-21-2009, 09:35 PM | #365 |
Opps, I had it set to digital servos and it was shutting down on me. No that I have it set to normal mode it works amazing. Your set-up tips are perfect also. I followed everything and set it up in about 10 minutes. Nice work.
08-22-2009, 12:32 AM | #366 |
| Glad to hear it. If you need anything else let me know if I can help |
08-26-2009, 12:57 AM | #367 |
Look whats coming for my 4PK! Should be printing tomorrow Freq E will be doing some other 4PK skins too, watch out for them or drop him a line for a custom one. Good work isn't free though |
08-29-2009, 12:56 PM | #368 | |
Rock Stacker Join Date: Jun 2009 Location: cali
08-29-2009, 03:05 PM | #369 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| The buttons are 2 pos. the dials can do about anything. Either of the three dials around the wheel make nice 3 pos switches. You can also turn the wheel mount to put the switch/dials where ya want them.
08-29-2009, 04:43 PM | #370 |
ya I understand that part, I wanted to make my dig on a momentary switch-press and hold it activates the dig and when I let it go it shuts it off..is this possible for both front and rear dig?
09-13-2009, 01:07 PM | #371 |
Quarry Creeper Join Date: Mar 2009 Location: Fairfield, Cali
I have a 3PKS and want to upgrade to 4PK. I have a MOA LCC 1. Can i still use my 3chnl RX? 2. If yes, can i assign chnl 4 for throttle and chnl 2 & 3 for f & r escs? 3. If yes, will i loss functionality compared to 4 chnl RX? |
09-13-2009, 01:17 PM | #372 |
| Yes you can still use the 3ch RX but you can only use channels 1, 2 and 3 on the 4PK then. If you want 4ch control you need the 4ch rx.
09-13-2009, 01:19 PM | #373 |
| Wait, 3PKS. So are you usinga Spektrum RX? If yes than NO you cannot use the RX. If it is not the FASST RX then it will not work.
09-13-2009, 01:20 PM | #374 |
Check out the table here for what RX's will work: http://2.4gigahertz.com/modules/modules-receivers.html |
09-13-2009, 01:52 PM | #375 |
Quarry Creeper Join Date: Jul 2006 Location: pnw
hey harley i need your help on my rig here what i have 4pk duel fxrs and a winch i had it set up like your thread 3 and 4 ch was escs mixed but i add a winch and could not opperate it on the 2ch so i switched escs to 2 and 4 and winch on the 3 ch but cant controle my escs like i did when they where on 3 and 4 need your help thanks |
09-13-2009, 01:56 PM | #376 | |
And then setup the winch on Channel 4. You will not be able to use rear dig like you did before because that setup required all 4 channels (even though nothing is plugged into channel 2 it is still being used to control 3 and 4). Use this to setup your winch on channel 4: 4PK Setups, Tips, Tricks and Help | |
09-13-2009, 02:11 PM | #377 |
do you have a thread on it to show how to ? on that setup
09-13-2009, 02:18 PM | #378 |
| Sorry grabbed the wrong one: 4PK Setups, Tips, Tricks and Help |
09-13-2009, 02:44 PM | #379 |
is there one for rear dig?
09-13-2009, 02:53 PM | #380 |
| Huh, I guess that wasn't the setup I was thinking it was. With your setup now you will have to control the rear dig with the steering wheel. Just set your PMix 2 up to have the master as ST and the SLV as CH3. Set the values to +100 right and -100 left. This is so that the rear wheels spin forward no matter what way you turn. If I have time tonight I will do a full write up and video of the 4PK with dual ESC and winch. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
