09-18-2009, 09:00 PM | #421 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
i am trying to set up my losi crawler. I have the 3 pos dig set up right now on the DT3 as suggested but is there any way to set up PS2 as front dig button then when the button is released it goes back to 4WD? I tried but when I release the button it goes back to rear dig automatically. Thanks |
09-18-2009, 10:03 PM | #422 | |
09-19-2009, 07:42 AM | #423 | |
Rock Stacker Join Date: Jan 2009 Location: Aurora
09-21-2009, 10:02 AM | #424 |
| that's what I want it to do, but I can't get it to go back to 4wd when it is pressed the second time.
09-21-2009, 11:24 AM | #425 |
| Did you set up the pmix1 as one direction and pmix2 as the other direction and then set your switchs in the "alt" mode and switch one to control pmix1 and the other pmix2? Hopefully that makes sense?
09-21-2009, 12:48 PM | #426 | |
It seems possible to do it by mixing channels 3 and 4 but I need channel 4 for winch down suspension. i guess I could see how much I use rear dig and possibly just reduce the endpoints, and use the servo reversal trick. | |
09-21-2009, 02:19 PM | #427 | |
09-21-2009, 02:46 PM | #428 | |
I'll give it a try, can you give a better explaination of the settings? (pmix master and slave, etc.) Thanks | |
09-21-2009, 03:06 PM | #429 |
| You will set pmix1 and pmix2 as channel 3 as master and slave as channel 3 also. Then on one of them will be somewhere around 0 and -39 and the other @ 0 and +39. The only thing you need to be careful of is if you turn both switchs on at the same time it will want to swing the servo to a 78 endpoint position and use your 3 channel subtrim to make sure is centered before setting end points |
09-23-2009, 07:44 PM | #430 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
ok...got everything up and running tonightmy next task is setting up the dig (punk) switch...how? i want to set up front dig on PS2 and rear dig on PS1...
09-23-2009, 09:40 PM | #431 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
My 4pk is on the way, I have read this entire thread forward and backward several times. This is one of the first RC things I have really looked forward to getting in a long time. Harley I hope your phone is turned on when I get it... |
09-23-2009, 09:51 PM | #432 | |
You got my number, feel free to use it. I can walk you through the initial setup if you want. | |
09-23-2009, 09:54 PM | #433 | |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
I was not on the phone with him 10min. and my truck was going. Thanks Harley Jason the hardest part was pushing the select button straight down and those little points that are on it are sharp | |
09-23-2009, 09:54 PM | #434 |
09-23-2009, 10:03 PM | #435 |
Many of you may have seen my newest SCX-10 build but some of you may not have. The build is here: Harley's RubberBelly Racing Build Anyway, it is just one more demonstration to the versatility of the 4PK. This is an amazing scale radio too! I am using the radio to control steering, throttle, ON-BOARD CAMERA PAN!, and 3Racing winch. The camera pan servo is mixed with steering, and I can use the adjustable mixing to adjust how far the servo turns with respect to the wheels. I can shut the mixing on and off with PS1 and I have independent control of the camera pan programed on the DT1 buttons. It is actually incredibly easy to use! Check out these two videos to see what the footage looks like: http://www.youtube.com/watch?v=CpTDDqp67Js http://www.youtube.com/watch?v=MFssjsUEx-8 And here is a video showing how it was created as well as the test footage: http://www.youtube.com/watch?v=_XiKyQ33jzg http://www.youtube.com/watch?v=t1u7MO0Btsk |
09-23-2009, 10:05 PM | #436 | |
I better get one of those telemarketer headsets then | |
09-24-2009, 08:49 AM | #437 |
Thought this was cool. Check out what transmitter he is using to drive a 1:1 truck! http://www.traxxas.com/email2/090917...ndon-PR-RC.pdf |
09-24-2009, 10:05 AM | #438 | |
Rock Crawler Join Date: Aug 2005 Location: Illinois
Those sharp points are annoying for the first week but after that they wear down enough that you don't even really notice. Harley wanted us to pay for a new manicure after his first week using the radio. Diva! Nice to see you running the radio Joe. J | |
09-24-2009, 10:56 AM | #439 |
RCC Addict Join Date: Aug 2008 Location: Charlotte, NC
Should have mine in hand tomorrow. Thanks for the help Harley!
09-24-2009, 11:08 AM | #440 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
