10-05-2012, 08:37 AM | #1961 |
Newbie Join Date: Jun 2011 Location: Wi
| Re: Futaba 4PL Setup, Tips, Tricks & Help
Thanks for the quick reply. I am finishing a build on a super class crawler, but I still need a 4ch radio and escs. I'm just trying to decide which ones. It already has dual servos for 4ws, and I need to add the escs, I was just wondering how dig works with a set up like this. Thanks for the info, I'm still learning. Is the 4pl much different then the m11 as far as setting up a crawler like this? I do like the size of the 4pl, but haven't decided between the two yet.
10-05-2012, 08:44 AM | #1962 | |
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
10-05-2012, 09:26 AM | #1963 |
Alright, I guess the only thing I liked about the m11 was the cability of a specktrum module. I will likely go with the 4pl then, thanks.
10-09-2012, 01:49 AM | #1964 |
Quarry Creeper Join Date: Sep 2011 Location: On PayPal trying to make funds appear.
i read through much and did not find my answer and i searched lol QUESTION... can i setup a button to return bias to neutral or 100/100. obviously i can just click it back the number of times i clicked it the other way, but sometimes i forget how many times. example. i clicked bias 5 times forward and i am unsure how many times to click for neutral and cannot hear the beep well because of a rushing stream. i want to be able to click a button to return mixing trim back to normal or 0 bias. i have tried to find this and cannot, so any help would be appreciated. |
10-09-2012, 01:54 AM | #1965 |
Pebble Pounder Join Date: Jun 2011 Location: Irvine
I'm not shore a button to return it but what I do I put my radio on the screen that shows the wheels at the bottom. It will show you which dig you are in and then up at the top will show you're bias. Don't know if this will help but its what I do so I know.
10-09-2012, 10:36 AM | #1966 | |
10-09-2012, 10:56 AM | #1967 | |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
im having the same problem, end points and duel rate is all the way up. is there a difference between the two radio's. i like the 4pl a lot better, and i would like to keep using it if i can. | |
10-09-2012, 11:33 AM | #1968 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
I've got DT4 set as front/rear dig on/off. DT2 as rear proportional in 20% steps. Might move this to DT3. Is it possible to do the same proportional dig to the front say on a spare DT switch? Rear then stays at 100%. | |
10-09-2012, 11:49 AM | #1969 | |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
10-09-2012, 12:05 PM | #1970 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help No, the biasing is adjusted by the rear motor only. I don't suggest ever touching the front motor bias even on the 4PK where it is possible. It is one more thing to get mixed up with on course. Overdriving the rear is almost always enough. Haven't really had any of the top drivers disagree with me on that setup. So when we developed the 4PL programming it was not something that was included.
10-09-2012, 12:15 PM | #1971 | |
Using DT2 as bias trim works quite well and quick too. | |
10-09-2012, 05:04 PM | #1972 |
thanks for the replies guys
10-10-2012, 12:47 PM | #1973 | |
RCC Addict Join Date: Mar 2011 Location: Way out there!
10-10-2012, 12:59 PM | #1974 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
10-12-2012, 05:34 PM | #1975 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
Any tips for getting smoother downhill control? I messed with expo and neutral width, but I don't really know what I'm doing. Other people's rigs are much smoother. Mine picks up speed faster and jerks to a stop when I back off the trigger. Causes the car to tip rear-over.
10-12-2012, 05:52 PM | #1976 | |
10-12-2012, 07:27 PM | #1977 | ||
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
Has anybody done the momentary toggle yet? I'm looking to do this for my winch. The static 3-way makes it difficult to be real precise. -Brian | ||
10-13-2012, 08:34 AM | #1978 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
finally traded the spektrum for a 4pl... this guide has saved me all sorts of headaches! |
10-13-2012, 02:07 PM | #1979 |
10-15-2012, 06:40 AM | #1980 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
Can anyone explain why you'd want to do what this guy did with his mix? Don't need a 4pk!!! - YouTube |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
