02-22-2013, 10:24 PM | #2601 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: GT3B Hack Question and Answer Thread |
02-23-2013, 03:57 AM | #2602 |
Rock Stacker Join Date: Mar 2007 Location: Australia
02-23-2013, 05:02 AM | #2603 |
One more question with 4ws I have front, front & rear or just rear but no crab unless I reverse servo for front&rear is there a way to have all four modes? I'm still learning how to use the hacked gt3c I'm sure there's a lot to learn. |
02-23-2013, 11:19 AM | #2604 |
Newbie Join Date: Jun 2010 Location: Brick
Does the controller come with a battery and how do you charge the battery?
02-23-2013, 01:32 PM | #2605 | |
| Re: GT3B Hack Question and Answer Thread Quote:
You could modify the TX to use a LiPO battery, I believe it's discussed in this thread. The GT3C comes with a rechargeable battery and a charger. Just plug it in to charge. | |
03-05-2013, 04:50 PM | #2606 |
Rock Stacker Join Date: Dec 2006 Location: charleston
I had a question i just switched to dual escs on my moa crawler, I got the gt3b with a hack kit i followed the template to the t, my problem is that when i hit the channel 3 switch to dig the rear it spins the motor pushing my crawler forward, my next problem is that my escs do not start at the same time, going forward it drags the rear a little till i get into the throttle a little more and vice versa going backwards, when i start to crawl something it stalls the rear, i went to dual escs to get rid of clod stall, what could be the problem im running dual brxls and have played with the start up times but does not make a differnce. Thanks in advance.
03-05-2013, 09:02 PM | #2607 | |
2-Your motor issue, I'm guessing you just "grabbed 2 motors" and installed them. Since one has to do reverse rotation, you have a timing issue. They are both timed the same direction, but one is advanced and the other is retarded. If you were to buy 2 motors from Holmes or Br00d and state, "To be used in a MOA", you would get 2 motors, each labeled for the end of the rig it's timed for. You could start with "0" timing to see how it goes. I use a little proportional (maybe 5%) to fix the clod-stall. | |
03-06-2013, 05:24 AM | #2608 |
I'm using the .6 firmware from overkill site, i understand the motor in reverse rotation and have not ordered my motors yet, but i still figured my escs would start at the same time, the led lights on top of them dont even blink at the same time so this would cause the motors to not start at the same time were my thoughts, i ran these same motors with one esc and had less stall than i do now.
03-06-2013, 05:27 AM | #2609 |
Also why when I hit the 3rd channel switch why does it send power to my rear motor causing it to move, also does it when I proportion 100 to the rear i was under the impression that 100 percent proportion is supposed to cut off the rear motor.
03-06-2013, 06:53 PM | #2610 |
Could someone tell me why when I hit my third channel switch my rear motor drives forward. And also when i bias 100 percent on the rear it still drives forward, i messaged and emailed losikid and no answer on either.
03-06-2013, 07:30 PM | #2611 |
a.) Calibrate your esc's to the radio...if they don't start at the same time, its a good indicator they need to be calibrated b.) There is a thing called patience...I don't do this full time, in fact i don't even have time this week todo anything overkillrc related. Large companies with dedicated customer support teams don't get emails answered within 24 hours most the time, so why expect rcc vendors to answer questions within a few hours of you asking? I have answered your question many times, you aren't the first to have these issues. If you are in that big of a hurry, use the search button and read. Your issue is a setup issue, not a radio issue... |
03-07-2013, 05:22 AM | #2612 |
Thanks for all the help I will search again and see if I can figure it out. Just thought someone could help that had the same issue, sorry for being unpatient.
03-07-2013, 06:22 AM | #2613 | |
03-07-2013, 10:21 AM | #2614 |
Pebble Pounder Join Date: Feb 2008 Location: Maybee
Instead of just putting the pin header on the back, has anyone thought of putting on a usb port?
03-07-2013, 10:42 AM | #2615 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
doable, all you need is a contact path, USB would be plenty good.
03-07-2013, 09:03 PM | #2616 |
RCC Addict Join Date: Jun 2010 Location: fort collins
Not sure if we are posting gt3c ?s here but here i go. I have looked for mods on how or even if you can add more switchs to the gt3c and havent found anything. Am i just looking in the wrong place? Im hoping to add a 2 pos and a 3pos switch or maybe 2pos and 2 3pos. I havent recieved my controler yet but im trying to think ahead. Thanks |
03-07-2013, 09:13 PM | #2617 |
They're already there. Just assign and done
03-08-2013, 09:23 AM | #2618 |
I guess i should wait and look at the thing before i ask. I thought there were only 3 plus throttle and steering.
03-09-2013, 09:08 AM | #2619 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
Ok, i have a question. My son got ahold of my rx and im not sure exactly what he did. Before i had it set so i can control my punk dig with the ch3 trim. I hade it set as momentary so one way was front, one rear, and middle 4wd. Worked great. Now after he got ahold of it the slider doesnt work anymore. I have full time front wheel drive, if i go to to e-point section on the main menu and go to ch3 e-point it activates the punk dig. At that moment forward throttle gives me front wheel drive, and reverse throttle gives me rear wheel drive. Im not sure what he did but i cant figure it out. Thanks in advance.
03-09-2013, 09:16 AM | #2620 | |
I'm assuming you mean "TX" not "RX". | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
