Thread: GT3B Hack Question and Answer Thread
Old 01-21-2015, 10:28 PM   #3781
Default Re: GT3B Hack Question and Answer Thread
Originally Posted by losikid View Post
Exactly, back-ordered....as in you can still order them as I'm waiting on parts to come in.
And they're technically in stock now and I haven't updated my site yet.
Thanks for the clarification i'll be ordering one shortly
aftershock1 is offline   Reply With Quote
Old 01-22-2015, 12:11 AM   #3782
Hello. I need a mix between channels 3 and 4. Can I do it? And if it is possible, how could I do it? I need it because I´m building an excavator and I need for the movement of the chains.
Thank you!!!!
carcueza is offline   Reply With Quote
Old 01-22-2015, 04:37 AM   #3783
Yes, just the first step you listed.
That will cause the steering wheel to adjust the proportion between the two tracks. Plug 1 esc into channel 1 and the other esc into channel 2
You don't need to "map or assign" the steering wheel to the dig mix. It happens automagically.
The trigger still determines the speed
Oh WOW, I like this controller even more now....
Thankyou for the excellent customer support, I would of been lost with out it...
Well anyway I'm off to go do some testing and bragging to some forum buddies.... Lol
Phmaximus is offline   Reply With Quote
Old 01-22-2015, 09:40 PM   #3784
Hi. I've gone to tue Overkill website and found it not working properly. Are you they selling modded GT3C? I have found it impossible to contact them. I would like to purchase one. Can I get on the list please. Sapes23@Gmail.com. I live in Winnipeg, Manitoba, Canada. Thank you.
Sapes is offline   Reply With Quote
Old 01-22-2015, 11:24 PM   #3785
Got Worms?
Thank you!!!!
No, it can't currently do that...
It looks like it is working just fine
Flysky GT3C
losikid is offline   Reply With Quote
Old 01-25-2015, 07:42 AM   #3786
This is more geared towards losikid, but I would like to know if I can use this voltage regulator (I can source it close to me and not have to worry about shipping) in place of the recom one you supply. It's DE-SW050, a 5v regulator?
flyboy320 is offline   Reply With Quote
Old 01-25-2015, 05:28 PM   #3787
Got Worms?
Yea, you should be able to make it work...
Old 01-25-2015, 05:37 PM   #3788
bought the programming kit, vr and steering wheel bearing, installed and upgraded the sw in my gtb3. all went great! read though this thread along with the info on the overkill website. couldn't of been easier.
3sgte is offline   Reply With Quote
Old 01-26-2015, 11:26 PM   #3789
Just ordered the firmware for the gt3c can't wait to receive it
Old 01-26-2015, 11:45 PM   #3790
Got Worms?
Its boxed up and will go out tomorrow afternoon*
*Assuming I'm not working overtime tomorrow at my day job...
Old 01-28-2015, 08:32 PM   #3791
Ok so I ordered a gt3c from ebay and part # OK-GT3C-FW from rcoverkill all went well with install now im trying to look at the install guide no luck, just a small x in left top corner and cant download firmware, either any help would be grateful.
bbolden516 is offline   Reply With Quote
Old 01-28-2015, 08:56 PM   #3792
Got Worms?
It works for me. What links are you trying?
Old 01-28-2015, 09:34 PM   #3793
http://www.overkillrc.com/GT3C/Insta...anual%20v0.pdf
This is what I go to but only a small x top left corner same for firmware have ST tool but not the right programs im not sure but wont verify line 1 or line 5 issues.
I can save the stock file and re upload it fine but when I try to up load new firmware all I get is all zero's in the text no values. so then I just reload the stock file and everything is fine I must have something blocked that im not seeing or compatibility issues or something, ok so there mite be an issue with the patch st tool kit I installed but why dose the stock firmware load unload etc with no issue.
Old 01-29-2015, 03:13 PM   #3794
I added myself to gt3c waiting list with everything. Got a rough estimate on these?
soscary is offline   Reply With Quote
Old 01-29-2015, 04:00 PM   #3795
Gonna start on this as soon as my rx's arrive thanks again losi kid
Old 01-29-2015, 04:35 PM   #3796
So I know that the firmware is my issue every time I try and open it in ST tool kit to load the gt3b-0.6.1 file it goes to all zeros and I get this message.(FILE: line 5: Not in Intel Hex format!) if I leave that in the unit it is zeros and wont turn on or anything but if I load the stock firm ware it works fine, any help would be great. Ok edit here I reloaded the st tool kit and the firm ware gt3b-0.6.1 file on a another computer and it just worked zero issues sorry for the mix up but if any one is having the issues I was and you have multiple computers just try a different one.
Thanks to the losi kid and a bunch of different posts on this site as well as others.
Old 01-30-2015, 10:02 PM   #3797
Location: Turn the mayflower around.. it will never work
Issue may lie in the version of windows you are using. Back a ways we talked about updates and patches used to make it work. May ha e been ur issue
JokersWild is offline   Reply With Quote
Old 02-02-2015, 03:33 PM   #3798
Got Worms?
GT3C update.
The GT3C's got turned around at customs and sent back to my supplier. So it's gonna be another 2 weeks or so before I'll even have the lot of 20 GT3C's I ordered. But I also have a few coming from another company that should be here any day now.
Old 02-02-2015, 10:51 PM   #3799
Gotta love customs...... Two thumbs down.
Old 02-02-2015, 11:24 PM   #3800
Got Worms?
You edited it fast but not fast enough for subscription email
two things down...
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 12:49 PM
