Thread: GT3B Hack Question and Answer Thread
Old 11-15-2011, 01:44 AM   #761
The actual chrome rocker that pushes the microswitches broke. There are two tabs one for each micro and the one for the front trim cracked. A little CA and it's as good as new. I did switch it to the D/R rev for good measure. I guess I need to stop digging so hard
Kind of hard to get a good shot of it.
John-e Bravada is offline   Reply With Quote
Old 11-15-2011, 07:40 AM   #762
Or should I just put my ESC on channel 3 since I really dont need trim for that and put my rear steer on channle 2 so I have trim settings to center the servo? or is there a way to save my left/center/right values on the 3 pos switch when im driving because like I said it will work for two cycles through and then just zero out? Thanks Newbie Dan
Dhaydn53 is offline   Reply With Quote
Old 11-15-2011, 04:10 PM   #763
Got Worms?
There is trim for ch3, but its the sub trim not trim...Anyways just press and hold enter (about 1-2 second) when selecting trim. This will take you to the sub trim menu.
Make sure your step rate is 100. To get end points adjust your epa
losikid is offline   Reply With Quote
Old 11-15-2011, 07:58 PM   #764
Originally Posted by losikid View Post
well first, trims have NO effect once in dig mode on those channels
Second, why not just re calibrate esc's?
Well I figured it out. I did have to "recalibrate" my ESCs. Everytime you turn them on they find neutral but with the sub trims set to thier limits there was no more adjustment left and that screwed up thier auto neutral. With the sub trims set to 0 and the power cycled they are balanced again or at least close. The sub trims do set the balance on the mixed channels, to perfectly align them, my ESCs just try and adjust it out.
All is well again and the glue fix seems to be holding up. Time will tell.
Old 11-16-2011, 03:38 PM   #765
cartronicshn's Avatar
Everything in stock yet?
Can't get to the products page to order?
Edit: Got in there, but it seems you are out of regulators
cartronicshn is offline   Reply With Quote
Old 11-16-2011, 03:41 PM   #766
Got Worms?
Yes its all in stock...i just opened up the products page, works fine for me. Although it may not work on cell phones it doesn't on mine
Old 11-16-2011, 04:49 PM   #767
FYI got an Email today
HobbyPartz.com has 10% off radio gear till 11/18/2011 using code HPZTX10
RC Transmitters and Receivers
should almost cover shipping making it a few $$ cheaper
spoo76 is offline   Reply With Quote
Old 11-17-2011, 04:58 PM   #768
Hi Losikid,
I'm having a problem calibrating my AE-2 esc to the Flysky GT3B. I do get lights and steering but esc still blinks green,red and beeps. I have a cc bec on 2s. It works fine with the stock axial radio and receiver. I've tried everything in the manuel but still no luck. I'm also using this radio on another rc, works good.
Thanks
Erbing is offline   Reply With Quote
Old 11-17-2011, 05:02 PM   #769
Got Worms?
Try reversing the throttle channel
Old 11-17-2011, 05:13 PM   #770
the bearings and VRs showed up today
Ill crack both radios open and start the upgrades when my stomach isnt going crazy ughh
Old 11-17-2011, 06:59 PM   #771
Just tried it, still no workie.
Old 11-17-2011, 08:31 PM   #772
does your steering work???
squatch71 is offline   Reply With Quote
Old 11-17-2011, 09:15 PM   #773
Steering and lights works, esc just won't bind. keeps blinking and beeping.
Old 11-17-2011, 09:20 PM   #774
Got Worms?
Did you calibrate the esc to it?
Right after you power up the rc, pull trigger (green lights should blink) once it beeps push trigger to full reverse (red lights should flash) once it beeps let off to center/neutral. It should be beep again then after a second or so it should do the startup jingle.
Old 11-17-2011, 09:21 PM   #775
Not to imply you don't know what you are doing but maybe you aren't calibrating it right?
Axial AE-2 ESC Set-up and Programming
Old 11-17-2011, 10:40 PM   #776
After trying everything, my channel 2 isn't working on the receiver. I plugged in the esc to ch1 and it worked.
I guess I need a new receiver, good thing they are cheap.
Thanks guy's for all the help. Hopefully no more problems when I get the new receiver.
Old 11-18-2011, 04:37 AM   #777
At least you figured out what the issue is.
Charlie-III is offline   Reply With Quote
Old 11-19-2011, 06:40 PM   #778
flashed the 2nd GT3B tonight. I cant believe how much quicker and easier it is now that the virtual XP is sorted.
also installed both VR's and set the low voltage alarm to 6.2
I have a pair of 2S 1300mahs that should work well.
Once I pick up a 12mm reamer from the LHS I'll install the bearings.
so to recap...
2 GT3B's about $65
firmware flasher, X2 VR's & bearing mods $63.25.
total under $130 for 2 hacked and upgraded radios
Making your spektrum & futaba friends jealous because you have 2 radios that can do more for 1/2 to a 1/4 what they paid....priceless
Old 11-19-2011, 06:45 PM   #779
Got Worms?
so to recap...
2 GT3B's about $65
Set the alarm to 6.5. Anything below that the vr won't output 5 volts so the voltage reading will be inaccurate on the radio and your controls will go out of calibration settings because the pots will see less than the 5 volts. Only downfall of using 2s...
Old 11-19-2011, 06:48 PM   #780
thanks for the heads up
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 12:49 PM
