12-07-2011, 06:30 PM | #841 |
Pebble Pounder Join Date: Oct 2011 Location: Fountain
| help with 4ws
I need a bit of instruction help on setting up 4ws on my Redcat Rockslide 1/8, I have the GT3B set with the 8 channel firmware, followed the direction on page 26 of this thread, I have the 3 channel button on the grip workiing for switching between crab and no crab. What I want to do is set a couple of additional things. I would like to set the D/R 3 pos switch to somehow switch between rear, front and 4ws modes (EDIT: I got this figured out now). I also want to program the ch3 trim to move the rear steering servo (connected to ch3 of the receiver) in steps left and right, I think I can do up to 8 steps but maybe 100% each side, 50% each side and center. (EDIT To have independent control of the rear steer, I think I need to set it up as another model without 4ws then setup the ch 3 switch to control the rear steering in steps but not sure how to do that.. Any help is appriciated and I did read through the manual a couple times DJ Last edited by soutthpaw; 12-07-2011 at 09:32 PM. |
12-08-2011, 12:07 AM | #842 |
As of right now, you can't mix a mix and independent channel control together. To set up independent control, just map your ch3 trim switch to CHn(n=3- as a NOL and set your step rate to like 25 (25%) |
12-08-2011, 03:14 PM | #843 |
ive had my 3 channel FLYSKY for awhile now and trying to use the 3rd channel for my winch. i know its just an on/off switch but i cant even get it to do that. what am i doing wrong ? i thought just pushing the chn3 button on the handle would activate it, is this correct? thanks rb |
12-08-2011, 03:38 PM | #844 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
follow the directions in this thread and it will be fine | |
12-08-2011, 03:55 PM | #845 |
didnt get the hack kit yet , just playing around with the new winch and cant get the 3rd channel to work. not sure what im missing.
12-08-2011, 04:16 PM | #846 | |
right now the button is just an on/off switch. you need a 3 way switch. fwd/neutral/rev get the hack kit, you wont regret it. it will do so much more than you need you might find yourself building a rig just to try out features haha | |
12-08-2011, 05:46 PM | #847 |
Newbie Join Date: Mar 2007 Location: Utah
I setup the gt3b with 6ch 0.4.1, and followed the dual esc dig template, calibrated the fxr's, but when I push the ch3 button or the ch3 trim either the front or rear motor starts slowly turning. Is there an adjustment that will stop a motor from turning? I has tried recalibrating the esc's and adjusting neutral and endpoints with no improvement. Your help is greatly appreciated |
12-08-2011, 05:57 PM | #848 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| that is the truth.....I'm dreaming one up now with 5 channels used....trying to think up what I can use on the 6th channel!!
12-08-2011, 06:34 PM | #849 | |
12-08-2011, 06:45 PM | #850 | |
12-08-2011, 07:01 PM | #851 | |
so far its currently steering,throttle,winch,2 Speed Summit trans but adding 4WS with R-1 Portal axles and a LCC trans used as a transfer case giving me front and rear disconnect I'm considering flashing the 8CH firmware on one of the radios to add remote lights and a rear winch for the hell of it lol Id love to also use dual ESC mixing and build a tank treaded vehicle, I have a dual stick HK-T6A heli radio that uses the same RX's and would probably work but the GT3B would be cooler hah | |
12-08-2011, 07:02 PM | #852 |
12-08-2011, 07:10 PM | #853 | |
I adjusted both channels 2 and 3 subtrims, works perfect Thanks so much. Last edited by SlickZR2; 12-08-2011 at 07:14 PM. | |
12-08-2011, 08:25 PM | #854 | |
In mix, both channels run off trigger, when you go into dig one channel is mixed with the trigger and one channel isn't mixed with the trigger and it sends out a 0% signal. If the trigger isn't calibrated correctly then your esc isn't seeing 0% from it when it calibrates it's neutral point. What the sub trims are doing is simply moving where the channel goes when not mixed to the trigger, so its like a patch, not a true fix. I'd recommend calibrating the radio, reset all your trims back to zero, then re calibrate the esc's. | |
12-14-2011, 08:30 AM | #855 | |
12-14-2011, 04:25 PM | #856 |
| Re: GT3B Hack Question and Answer Thread |
12-16-2011, 09:32 PM | #857 |
Newbie Join Date: Dec 2011 Location: usa
is there anyone out there that has the fw for fsgtb3 with these specs fix expo fix the epa saving 45 second backlight epa to 150 low voltage at 8v and trims to 99 and -99 |
12-16-2011, 09:49 PM | #858 |
are you asking how to set your radio with those settings??
12-17-2011, 12:14 AM | #859 |
| Re: GT3B Hack Question and Answer Thread no, the original "hacks" were reading the program off the radio, modifying afew digits then reload it back into the radio to fix its issues...but since then a new firmware was written. So to answer the original question, no i don't have that type of firmware, but i'd recommend just using the new firmware, 0.4.1 |
12-17-2011, 06:57 AM | #860 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
