12-17-2011, 05:32 PM | #861 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Re: GT3B Hack Question and Answer Thread
fix expo Not sure what your asking here fix the epa saving Make sure when you have the EPA set to what you want short click (enter) then press the back button, will get you back to the main screen (with the model you have selected's name) I think this is what what your asking 45 second backlight at the main screen (with your models name) long click, model and name will flash back and forth, f should be the first thing you see-this is the firmware you have, mine says 041, at this point its the latest like LosiKid says to upgrade to this firmware. Rotate the enter button clockwise to the L, short click (press enter once fast) this is the time, rotate till it says 45S, short click again, then long click..should be back to the main screen. epa to 150 same as 45 second backlight but rotate till you see E.POINT light up, short click, set your desired epa max...short click, then long click to get back to main screen low voltage at 8v same as 45 second backlight but rotate till you see LOW POWER!!, short click, rotate to the desired voltage...short click again, then long click and you will be at the main screen. and trims to 99 and -99 not sure hows that?!?!?! Last edited by squatch71; 12-17-2011 at 05:36 PM. |
12-17-2011, 05:36 PM | #862 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: GT3B Hack Question and Answer Thread I think this person found these specs somewhere and simply wants this radio. its all the same kit. all the things listed are basic things done in the first firmware i believe. the new firmware does this and more so just buy the kit, flash the firmware and you will have those options
12-17-2011, 05:39 PM | #863 |
Yeah, you know what Spoo..I didn't say that mine is hacked and flashed...not sure if the shorts radio is hacked or flashed...and not sure if these steps work with non hacked radios....
12-18-2011, 09:12 AM | #864 |
Newbie Join Date: Dec 2011 Location: usa
mine is not hacked but i have program card
12-18-2011, 07:11 PM | #865 |
Rock Stacker Join Date: Jul 2008 Location: tulsa
After doing alot of research about which radio to purchase i choose to get the gt3b cause of price and the ability of numerous upgrades once i decide to hack the radio. My first uprage will be the steering wheel mod. I searched but could only find people using the lipo's batteries as a upgrade, could i get a recharchageble nimh battery pack and use it instead with out having to use the 8 AA's with the radio stock? OR would i need to upgrade the voltage regulator. Now i won't be using this radio every day or for multiple cars yet so is that some thing i should even worry about or should i just stick to the 8 AA for now?
12-18-2011, 08:35 PM | #866 |
LosiKid said somewhere in this thread that even the 8 AA's the VR gets hot. ITs really easy to chage out. And yes, you can just do a Nimh pack upgrade. look for one that is flat, 4 and 4. You will still have to take the battery case out for this to put in. I have a 2S lipo in mine, think its a 2100mAh. you can do what you want, but why the first mod is the bearing in the steering wheel?? I would flash it with the hack software, and put a new VR in it. I will look for a battery pack like I'm thinking of and post it. like this Last edited by squatch71; 12-18-2011 at 08:44 PM. |
12-18-2011, 10:05 PM | #867 |
Honestly, not sure i really need to flash it at this point. My truck right now is only two channels, throttle and steering. I only got this radio for just in case I upgrade to a dig or get another truck that requires more than one channel. From what I have read, the radio will work great out of the box with hour the hack for what I want/need at the moment. I can do the steering wheel mod very easily but the vr mod requires soldering and i have no experience with. Plus he said the stock Vr gets hot after hrs of use in one day, mine would only see an hr or two at the most when i get the truck out.
12-18-2011, 10:12 PM | #868 |
VR gets warm within 10 minutes, gets to be hot after about an hour, and after a few hours of being turned on its toasty. Seriously, put in 8 fresh AA's and turn it on, let it sit for couple hours, pop the cover off and set your finger on the vr. But its fine as long as you keep your bash sessions under an hour. However, the new VR doesn't just run cooler (no gain in temp) its also very efficient, it'll make your radio's batteries last twice as long. Which is the main benefit |
12-18-2011, 10:15 PM | #869 | |
| Re: GT3B Hack Question and Answer Thread Quote:
Walmart.com: Rayovac 4pk Platinum Low Discharge NiMH Carded AA Batteries: Household Essentials | |
12-19-2011, 08:27 AM | #870 |
Ok what does the 4.1 fw have and what can it do and how do u change the vr and what is changing the vr for
12-19-2011, 09:32 AM | #871 | |
LosiKid has directions, with pictures, on his website. Hacks info.... FlySky GT3B Info and FAQ for hacks - OverkillRC VR instructions.... http://www.overkillrc.com/GT3B/GT3B%...all%20v1.0.pdf | |
12-19-2011, 09:46 AM | #872 |
What does the 0.4.1 fw do for the controller will it make expo work and fix the saving epa when u switch models and will it let me change low voltage and will it let me change the trims to 99 to -99 and change backlight
12-19-2011, 11:29 AM | #873 | |
I believe it states everything the firmware changes. I don't need to know, thus I didn't read it......you should........[sigh] | |
12-19-2011, 11:58 AM | #874 |
Ok I c all the stuff it does now how to install and use and setup
12-19-2011, 08:24 PM | #875 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
so how hard would it be to make this happen? modified fs-gt3b to 6 channel - YouTube |
12-19-2011, 08:33 PM | #876 | |
Buy the firmware programmer this thread is about install header pin & PC software flash firmware Bind to a 6ch RX done or if you dont have a GT3B you can order one from LosiKid with the firmware already flashed and a 6ch RX | |
12-19-2011, 08:45 PM | #877 |
you can even get 8 channels out of these POS's Spoo!!!! Course you new that. Honost Charlie..I don't know how you don't reach through the screen and type the answers on the screen for them..... another way to get these questions answered is check out LosiKids website....all the info is right there, just like Charlie pointed out. on a side note.....has anyone flipped there screen film yet??? I started to peel one corner and a little piece of dust landed on it....so I blew it off and stopped...my question is once its up, can you touch any part of the screen or lens with F'n in up?? Did you read my post....I said I had the 41 firmware, and answered these questions...well all but the trim question....BTW, why do you need to do that?!? Last edited by squatch71; 12-19-2011 at 09:00 PM. |
12-19-2011, 08:57 PM | #878 |
ok thanks guys and sorry for the stupid question i have just not seen anyone have vids of proof of concept.
12-19-2011, 09:01 PM | #879 |
It works man...pretty cool, for a 35 dollar controller...well 50 when you done. There is a couple of vids on utube on this hacked controler.
12-19-2011, 09:06 PM | #880 |
Rock Stacker Join Date: Jan 2008 Location: Southern IL
I just got mine today, looking forward to taking advantage of it. Thanks Losi! A.D. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
