03-20-2012, 10:35 AM | #1341 |
Newbie Join Date: Jan 2010 Location: santa cruz
| Re: GT3B Hack Question and Answer Thread
finally got it working! thanks losikid! turns out the answer i was looking for was right in front of my face the whole time.
03-20-2012, 10:42 AM | #1342 | |
Moderator Join Date: Jan 2004 Location: chicago
| Re: GT3B Hack Question and Answer Thread Quote:
is there any chance to add one (8 spoke) to my existing order? i placed it on march 6th, order 392. | |
03-20-2012, 06:51 PM | #1343 | |
03-20-2012, 06:54 PM | #1344 |
Hey guys, i forgot to mention, the recent hack kits sent out was sent with a little sticky thing with the headers, this is so you can cut a small slice off it, put it on the bottom of the header, and stick it to the board so you don't have use hot glue or something...i'd recommend plugging your 4 pin cable into the header before soldering, so you know its level with the board
03-20-2012, 09:12 PM | #1345 | |
I am using the dual-ESC as posted before, the buttons work well, may try the locked dig to see how that is compared to the momentary. I will also try it on the M2 again to see if reversed channels help. | |
03-21-2012, 11:45 AM | #1346 | |
03-21-2012, 03:48 PM | #1347 |
I joined the Band! Join Date: Feb 2012 Location: bay area
I got my radio to work and I love it! Although I'm still trying to figure out if i can set the steering mix like my old Lansu radio. The Lansu had the crab/ 4ws/front only/rear only. I also ordered a flysky 8ch receiver and I will be setting it up with dual esc dig and a few custom suspension functions. |
03-21-2012, 04:49 PM | #1348 | |
03-21-2012, 05:42 PM | #1349 |
right now the little chrome thumb button just switches from crab to 4ws.... Maybe I missed something in the directions? |
03-21-2012, 06:20 PM | #1350 |
| Re: GT3B Hack Question and Answer Thread |
03-22-2012, 01:57 AM | #1351 |
Newbie Join Date: Feb 2012 Location: On earth
Hello peeps, will someone kindly please put up how to set: Ch3 trim = dig D/r = 4ws Thumb button = crab Oh And i have them fitted in the reciever like so Ch1 steering Ch2 throttle Ch3 need dig Ch4 need 4ws Ch5 need crab Thankyou everybody |
03-22-2012, 04:25 PM | #1352 | |
also crab and 4ws will be the same channel...rear servo | |
03-22-2012, 11:13 PM | #1353 |
| Re: GT3B Hack Question and Answer Thread I can't recall what the settings were... I'm on to new modifications. The stock rx that came with my Exceed Maxstone 1/8 is a 4ch 2.4hz and I just got 2 esc's. I Installed the 6ch firmware but I cannot get the radio and receiver to bind. Do you know off hand if this 4ch receiver is compatible? Also, how should I wire the second esc? Can I run dual batteries separately to each esc or should the dual batteries be wired parallel to the esc on ch2? |
03-22-2012, 11:50 PM | #1354 | |
run one battery to both esc's | |
03-23-2012, 12:00 AM | #1355 | |
Ch1 steering Ch2 throttle Ch3 need dig Ch4 need 4ws / crab Ok so crab and 4ws is one channel but will be assigned to different buttons i guess? Thanks in advance Last edited by fire_king; 03-23-2012 at 12:21 AM. | |
03-23-2012, 11:27 AM | #1356 |
03-23-2012, 03:25 PM | #1357 | |
Direct 2s is far more power than a bec can give you | |
03-23-2012, 03:37 PM | #1358 | ||
CH3 trim: Dig tranny Long Click REV scroll to 3, enter scroll to CH3, enter scroll to NOL, enter scroll to 100, long enter go to the epoint menu, set ch 3 epoints to 0% both left and right (turn steering wheel to change) Activate 4WS mix Long click E.Point scroll to 4, enter scroll to CH4, long enter D/R: 4ws mix Long click REV scroll to d, enter scroll to 4WS, enter scroll to NOL, enter scroll to 100, long enter CH 3 Button: Crab Long click REV scroll to c, enter scroll to 4ws, enter scroll to swi for non momentary, or mom for momentary...long enter Your done...now set your epoints for the dig slowly. When your in the epoint menu it will turn the servo to full, limited throw, move the steering wheel to switch direction of throw ^^^i went off my brain, i think its all accurate though, report back to confirm or deny it working^^^ | ||
03-23-2012, 03:39 PM | #1359 |
12+ lbs worth of 1/8 scale Exceed with dual 45turn Holmes motors 33.9:1 gearing on RC4WD Mudslinger tires that are 7-5/8" tall with 4ws and a lead foot= 7 minutes runtime |
03-23-2012, 03:57 PM | #1360 | |
that 5000mah battery should run 2 45t's for at least 30 hard minutes. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 12:49 PM |
