Thread: GT3B Hack Question and Answer Thread
Old 02-08-2012, 12:00 AM   #1141
Default Re: GT3B Hack Question and Answer Thread
Originally Posted by BELADOG View Post
if the glue stays on the film or the glass on the lcd you can use goof off. It takes a bit but it will come off.
In my case on the second radio, it actually delaminated rather than just leaving a bunch of sticky glue. The first one went well, I got cocky and wasn't as careful with the second radio.
monkeyracer is offline   Reply With Quote
Old 02-08-2012, 02:16 AM   #1142
Ooh! The film is attainable, I found a cheap source once. I will try to dig up the link.
Most places, for the size we need, it costs more than the radio
I was amazed how stable the film was. I was scraping with a plastic chisel and goof off for like an hour Amazingly enough, no damage.
Edit: I did fold the film at one point while bashing on it. That left a small crease that is just barely visible when the power is off.
BELADOG is offline   Reply With Quote
Old 02-08-2012, 07:42 AM   #1143
New wheel arrived today, Many thanks.
Small issue with it as some of the screws supplied are too small a diameter.
Less of an issue for me as I intend to use some different ones anyway.
Pete.
Pete Attryde is offline   Reply With Quote
Old 02-08-2012, 11:56 AM   #1144
Pete.
X2 I put my wheel on other day a.d notice screws don't tighten as too small. Gonna put diff screws in also.
skinner is offline   Reply With Quote
Old 02-08-2012, 11:57 AM   #1145
Back on film topic...you fella's saying pull radio apart and film is on back? Trying to understand better before I attempt it.
Old 02-08-2012, 04:30 PM   #1146
Got Worms?
Pete.
Yea the screws are not really ideal, gotta be real finese to get a good snug fit. I'm working on getting some new ones...
On another note (since i'm thinking about right now), does anyone want to pre-order a gt3c, as i have to get my order in any day now when i get word of final price and availability. I don't know if its hackable or not at this time
losikid is offline   Reply With Quote
Old 02-08-2012, 04:32 PM   #1147
Got Worms?
Its on the screen itself, its a clear plastic piece thats stuck to the top of the screen.
Old 02-08-2012, 10:16 PM   #1148
Losikid! Just ordered one of your radios. 6 channnel version.
Very exited. I love hacked RC stuff, I have a Turnigy9X that I flashed with an AVR. This sounds equally as exiting.
Quick question for you: Is it possible to install a pot on one of the channels so I can pan a camera mounted on a servo inside my truck for FPV use?
Cheers,
magellan is offline   Reply With Quote
Old 02-08-2012, 10:57 PM   #1149
Depending on the price, I'll try a GT3C.
erikblank is offline   Reply With Quote
Old 02-08-2012, 11:02 PM   #1150
Cheers,
I think you would be better off saving your third channel for dig or rear steer and just using a Y cable from servo for panning. You are going to want to look where you are turning anyway, and you can pretty much always turn the wheels. This feels natural and looks cool as hell for scale still.
Thats how I'm gonna run my FPWraith.
Old 02-08-2012, 11:08 PM   #1151
The Polarized film is already on the lcd
You peel it off. Its a PIA to get off (just really slow)
Dont worry too much about the sticky residue. I spent about an hour with goof off then realized you dont see it anyway.
turn the radio on and hold the film over the lcd. You can flip it over and see the difference. It's pretty incredible. Looks like the Futaba 10C once flipped.
Then you can either just set it on top of the LCD and put the case back on, or, if you are worried about it sliding, just use some clear Scotch tape to hold it down.
not sure what part you did not understand but for sure We could walk you through it no prob.
Ill link ya to the original thread via PM.
feel free to ask for help if ya need it.
Old 02-08-2012, 11:14 PM   #1152
Well asking do I take radio apart to access the film ? From top of radio I see 4 Philips screws ?
Old 02-08-2012, 11:29 PM   #1153
I just figured you had already been in there for the firmware mod.
sent you a pm with these directions.
there are four screws on top face. Pull them.
Pry off the round dial and use a quarter or plastic chisel to pop the top off.
use a small sharp blade to lift the thin layer of film (sticker) from the lcd face. start at a corner.
Try not to crease it too much as you peel it off.
Once you get it off turn your radio on and hold it over the screen. Then flip the film over. You will see it magically reverse the colors. Its pretty cool.
Just lay it back over the screen the way you like it best (opposite of stock is easier to see in the daytime) and refit the top. If it slides around you can tape it down. or fit it to the bottom of the case's top plastic protector window. Whatever is easier.
Its easier than it sounds and totally worth it.
do the button mod while you are in there.
Pull the power button off the switch and shave about 1/4" off the inside edge. Then remake the notch in one corner like I described a page back and push it back on.
replacement is reversal of removal.
Old 02-08-2012, 11:33 PM   #1154
[QUOTE=BELADOG;3556607]I just figured you had already been in there for the firmware mod.
Check your pm.[/QUOTE
Man thanks for pm. That's what I kinda figured how was done. Just got lost on top case as awful tight with screws out.
Me firmware? Naw lol I brought the pre hacked version and doing lipo mod when lipo comes.
Thanks again .
Old 02-09-2012, 05:25 AM   #1155
If I have 6 channels, I can keep 3 for dig but if I stop and want to look around, left or right, it would be nice to have a pot to swing the camera left or right. If it's not possible, I guess I can use a 3 position switch but I would prefer a pot if it`s doable.
Old 02-09-2012, 07:11 PM   #1156
Six channels, but limited by available buttons.
If you want to retain trim buttons and d/r switches like most, than you still have a three channel radio : )
You can absolutely add a pot and the radio will understand it w/o any firmware updates. But...before you do that you may want to try it first.
Im pretty knowledgeable when it comes to FPV and have built many set ups for others in the past. If there is one thing I can tell you its that everybody has a different idea about how they Think they want theirs set up. Usually we all end up with pretty much the same systems in the end. The reason for this is that until you try it, many "issues" that once seemed important fall wayside to issues that actually are. For example you may think you need a 3dbi whip on the TX, but, in actuality, the stock dipole works far better on ground based systems.
Another example is switch or dial activated panning.
Most think they want this until they actually try to point the car straight and then try to pan with a switch or pot activated servo. It is very easy to get disoriented. And finding center is not always as easy as you think when using a pistol radio w/only one free hand to control with.
I would say a better hack would be to find a way to pipe in a head tracker for a fourth channel!
now the camera looks where you do.
Im looking into the 4pk for this very reason. Because I think it offers a trainer port that would allow a head track gyro injection )
Old 02-09-2012, 07:19 PM   #1157
Got Worms?
Wrong,
The stock radio is 100% worthless on anything past channel 2
The new firmware let an a/d port act as either a button or analog channel. If you wanted a pot you could get one pot in there by replacing the channel 3 button
Old 02-09-2012, 07:32 PM   #1158
Originally Posted by losikid View Post
Wrong,
Yes on the ch 3 button of course.
I see the flaw in my answer. Should have said "No further f/w udate required.
Old 02-09-2012, 08:56 PM   #1159
Losikid, Bekadog, thanks for your input.
I will definitely go for the pot on CH3 and give it a go.
I am wondering what kind of Pot I should get?
What K Ohm? I imagine 10K would work?
Old 02-09-2012, 09:56 PM   #1160
Ill let Losikid field that one my man. He is the hands down master of this radio.
I only answered up till this point because I have made the backlight mod personally and have seen the dial hack done.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
