![]() | #2341 |
![]() | #2342 |
![]() | #2343 |
So, how'd the winch control get "stuffed up"
![]() | #2344 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| ![]() Quote:
x2 this is how mine is set up and I love it. BTW (by the way) Im still running the old program..... I left for too long and now im all freaked out by updating my radio to the new program!!! I need to just bite the bullet and program it, just not looking forward to re programing all these models again. ![]() | |
![]() | #2345 | |
| ![]() Quote:
![]() There may be a new firmware soon though, so it may be good idea to wait awhile....i'm not sure how long it'll take to get the new feature(s). Nothing to serious though. | |
![]() | #2346 | |
| ![]() Quote:
explain to me how the timer works? Count down or up? How easy to set to use for a course timer? buzzer at ending? Thanks for any info Austin.... you have been great support. Not like a jock strap but close ![]() | |
![]() | #2347 | |
| ![]() Quote:
The can start with throttle movement, or the push of a button. And they can be paused/reset with a button I'm trying to get it so when using Momentary, the center/default value is arbitrary and can be adjusted while your in the momentary state. And let Multi-Position be able to operate all functions (trims, expos, mixes, etc) | |
![]() | #2348 | |
Newbie Join Date: Nov 2012 Location: SoCal
| ![]() Quote:
I'm trying to understand the programming part. So to get front only I would choose 100 and for rear steer -100 like in dual esc template? | |
![]() | #2349 | |
| ![]() Quote:
4ws template is identical to dual esc, except choose "4" instead of "d" in the e.point menu and choose "4WS", instead of "DIG" in the rev menu | |
![]() | #2350 | |
| ![]() Quote:
Just helping out, not picking. ![]() My oldest is likely not too far behind you. ![]() | |
![]() | #2351 |
| ![]() Awesome ill check it out. On another note. When I first install the electronics and plug everything up before programming the tx, the rear wheels would turn one direction all the way. Left it like that while trying to program the tx for less than 5 mins and I smell burning from the rear servo(stock rtr). Getting a 7954 in the mail soon so no biggie but is expo suppose to be at -100 on channel 3 and cannot be changed? That's what I'm getting... Ch 3 -100 after enter-long on expo.
![]() | #2352 | |
Rock Stacker Join Date: Mar 2007 Location: Australia
| ![]() Quote:
![]() Last edited by revo au; 12-03-2012 at 01:08 AM. | |
![]() | #2353 |
RCC Addict ![]() Join Date: Sep 2010 Location: Apollo Pa
Wow! Austin your customer service is top notch, I've just finished reading every post in this thread and I can't believe how many times the same questions were asked and you took the time to answer over and over, just awesome! I just ordered a hack kit a day or so ago to reflash a 3b I got that wasn't working, anyhow I think it was a connection issue with the battery tray, I wired up a 3s lipo and it works great so I'm gonna reflash with the latest firmware, do the vr mod, and the bearing. I'm gonna do another order soon for another bearing and vr but do you happen to know when the 3c's will be available?
![]() | #2354 | |
| ![]() Quote:
I'm not sure when i'll have gt3c's | |
![]() | #2355 |
I've got two GT3B's that can ship in afew days (pre-hacked) vs my normal 1-2 week lead
![]() | #2356 |
I found 3 1300mah batteries for the gt3c in the bottom of a box...besides my personal stash this is all i have left, and they are no longer being manufactured Products - OverkillRC |
![]() | #2357 |
![]() | #2358 |
![]() | #2359 |
WooHoo I soldered the antenna back on! Losikid I put the center of coax on middle tab and the outer winding wire on the outside tab of the daughter board is that correct? Needed a giant magnifier to do it but got it done!
![]() | #2360 |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
