Thread: GT3B Hack Question and Answer Thread
Old 07-24-2012, 05:41 PM   #1801
cartronicshn's Avatar
Default Re: GT3B Hack Question and Answer Thread
Kid you have pm
cartronicshn is offline   Reply With Quote
Old 07-26-2012, 06:57 AM   #1802
OK Sorry for this but i read this post but cant find it
I'm looking to make CH3 trim switch to run my rear steer, i was thinking i had it but pushed something and lost LOL.
i want to pull back on the switch for rear steer only, when the switch is let go and it goes center its front steer only. and when i push it forward its 4ws.
and i would like to have crab mode too is i can on some other channel/ switch. I have 0.6.1
Thanks for the help
claycity is offline   Reply With Quote
Old 07-26-2012, 12:58 PM   #1803
Got Worms?
Interesting request...i need to think about this abit and see if my idea will work.
losikid is offline   Reply With Quote
Old 07-26-2012, 09:21 PM   #1804
So I totally just screwed the pooch on this thing. Voltage regulator posts burned off and I can't find a way ti get it to work. Naturally I need this thing next weekend. How fast can you ship these? Oh yeah, do you do repairs too?
gottwins? is offline   Reply With Quote
Old 07-26-2012, 11:12 PM   #1805
Got Worms?
what do you mean the voltage regulator posts burnt off?
Old 07-26-2012, 11:49 PM   #1806
I must have heated it too much tryi to solder them together and the pieces that were left from when I cut the old one off, they're gone. No idea what happened.
Old 07-27-2012, 02:01 AM   #1807
Got Worms?
Take some servo wire. Strip and tin one end of the wire (3 leads), then heat the hole on the board, stick one of the wires into the molten solder through the hole (not very far), and repeat for the other 2 holes.
Now cut the wire to an inch long or so, strip and tin those leads, then solder them to the vr. Heat shrink would be a good idea, or hot glue. But it should be fine w/out it
Before you turn the power on, take an ohm meter, or a continuity tester, and make sure none of the wires are shorted
Old 07-27-2012, 10:49 AM   #1808
Has anyone ever compared the battery voltage indicated by the radio against the voltage checked with a multimeter? My GT3B started showing "LOW POWER" after what seemed to me not a lot of use so I decided to check the actual battery voltage with my Greenlee CM 750 multimeter and also a old Radio Shack multimeter. The radio was showing 9.2v, the Greenlee 10.1v and the Radio Shack 10.3v. So I decided that the Greenlee should be the most accurate. Thanks to all that have put all the hard work into the new firmware (running 0.6.1) I was able to recalibrate the voltage reading on the GT3B to match the Greenlee. Considering how long it took to go from 10v to 9.2v before I should have a good deal of run time to go again making the GT3B seam a lot better on battery consumption. To make maters worse I just tried a new set of batteries and the radio now shows 14.1v and the Greenlee 13v. So I recalibrated the GT3B to 13v, then put the old batteries back in and the radio shows 9.3 and the Greenlee 10.0v so it seems the GT3B is wildly inaccurate in reporting battery voltage. I'm going to calibrate to the lower setting so as to get everything out of the batteries and live with high new battery readings. Sorry for the long post.
Fast1Guy is offline   Reply With Quote
Old 07-27-2012, 10:17 PM   #1809
losikid,
So on step 9 of the V2.1 manual, I use the file which is in the email you sent with the hack manual, correct?
If I get the following message, does it mean verification is complete?
Log activity is OFF
> Loading file C:\Users\\Downloads\ecwid_egood_593_1705002.s19 in PROGRAM MEMORY area ...
< File successfully loaded. File Checksum 0x26C9BC
EDIT:
I rebooted the computer and followed the step by step a few pages earlier in the thread and got this:
rogramming PROGRAM MEMORY area...
< PROGRAM MEMORY programming completed.
> Verifying PROGRAM MEMORY area...
< PROGRAM MEMORY successfully verified.
It is programmed right? Now I just bind to the RX and should be ready to go, correct?
Thanks,
Jon D.
spankbomb is offline   Reply With Quote
Old 07-28-2012, 12:46 AM   #1810
It's alive! Thanks LK!!
Old 07-28-2012, 01:25 AM   #1811
Spoke too soon. Now it won't power up at all
Old 07-28-2012, 09:27 AM   #1812
So I redid the program this morning. I suggest not drinking and programming. Works now! Now I just have to figure all the key mapping
Old 07-28-2012, 01:58 PM   #1813
For 0.4.0, and 0.3.2
Alright, just wrote this up in a PM...to setup 4ws and winches
ST trim buttons will work 4ws
-the it will give from rear only, even mix, front only...just cycle through the postions with the two buttons, you don't have to hold it)
D/R will work the rear winch
-(switch must be pressed for winch to wind.unwind)
and CH 3 Trim will work the front winch
-(switch must be pressed for winch to wind/unwind)
4WS -Ch1&3-ST Trim Buttons
Front Winch-CH4-CH 3 trim
Rear Winch-CH5-D/R switch
Activate 4WS mix
Long click EPA
4
3
NOC
Long enter
Map the 4WS mix to ST trim Buttons
Long Click REV
1
4WS
NOL
100
NOR
NOO
Press and hold enter
back
Map CH 3 Button to turn crab on/off
Long click REV
C
4WS
SWI
NOR
NPV
OFF
back
Map CH3 Trim switch to control Channel 4
Long click REV
3
CH4
MOM
back
Map D/R switch to control Channel 5
Long click REV
D
CH5
MOM
back
From the above part, I am having the following issues:
Long Click REV
1
4WS
NOL - Gives me the following options: BAR, BMO, BRS, BEN, BNL. I stop with the mapping process.
100
NOR
NOO
back
Long click REV
C
4WS
SWI - only gives me "MO0 or MO1" as options. I stop the mapping here.
NOR
NPV
OFF
back
Any suggestions on how to proceed? Thanks!
Old 07-28-2012, 03:11 PM   #1814
hi losikid,
I've done the setup for dual esc (this one : GT3B Hack Question and Answer Thread) after having reseted my radio and it's not ok.
When I put the DIG button (CH3. Trim) front : the crawler goes forward (like throttle) and when I put it rear the crawler goes rearward (like a reverse)
What can be wrong?
Thanks
Bergm@n is offline   Reply With Quote
Old 07-28-2012, 11:20 PM   #1815
Well I've tried several times to no avail to set this third channel. I'm trying to make the d/r mom for channel 3 winch, ch3 trim to be the trim for channel 3. Also trying to find out how to reset a model. I am at a loss.
Old 07-28-2012, 11:32 PM   #1816
Originally Posted by Bergm@n View Post
Hi LosiKid,
I've done the setup for dual ESC (this one : GT3B Hack Question and Answer Thread) after having reseted my radio and it's not OK.
What can be wrong?
Thanks
My guess is you didn't scroll to "DIG" about 1/2 way down the template.
What firmware are you running?
I run the same template you linked (I set the "steps" to 5% instead of 20%) with no issues.
I also have a template that makes the dig a locked function instead of a momentary.
Charlie-III is offline   Reply With Quote
Old 07-28-2012, 11:40 PM   #1817
Everytime I post up that I can't get something to work, I figure it out 5 minutes after I posted!
Old 07-29-2012, 01:49 AM   #1818
f0401 in the global settings of the radio so firmware 4.01
don't understand why it's working like that
Old 07-29-2012, 09:08 AM   #1819
can some one tell me how to set this up until losikid figures out my request. Thanks sorry edit 0.6.1 firmware
Hacked FS-GT3B with 4ws - YouTube
Old 07-29-2012, 09:10 AM   #1820
Sounds like the firmware I have. Maybe start a new model & try again.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html
Posted By For Type Date
RoboSavvy Forum :: View topic - SAM-3 Servo teardown This thread Refback 03-05-2013 01:49 PM
