![]() | #1821 | |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| ![]() Quote:
hey man, got a question. i am trying to setup a the ch. 3 DR switch to act as a 3 pos. winch controller. I have a heyok 3 pos. winch controller wired into my servo. when going through the REV menu following your steps above i do not get the same options you outline. i will list, in order the options i get. and let me know anywhere it doesnt seem right to you. 1. long click on REV (now blinking small 1, and showing TR1) 2.i scroll to small 'd' and CH3, with the 'd' flashing. 3. short click with Enter and 'd' is solid with CH3 blinking. 4. short click Enter again. and it goes to the d BMO, (with MO flashing) so pretty much at step 4 i get a completely different string of options, and am not sure what to do next. I just want either the dr CH3, the CH3 trim to be my 3 pos. winch controller. I did just read some of the past pages, but having a hard time following. do you mind typing the clicks up for me man? thanks again. loving the new radio | |
![]() | #1822 | ||||
| ![]() Quote:
![]() Quote:
![]() | #1823 | |
| ![]() Quote:
NOL=BNL because before in 0.4.1 NOL is an option is the "buttons" step, to help be more user friendly it now says "B" for buttons, and "NL" for No Long keys SWI should be MO0 i think.....MO means momentary, 0 means off, 1 means on. Check out the manual http://www.overkillrc.com/GT3B/GT3B-...NUAL-0.6.1.txt | |
![]() | #1824 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
Question can you have 4ws and dig at the same time, I have a xr10 with 4ws right now and I'm looking at the flysky remote. I'm wondering if you can control the rear steer independtly from the front and still use dig Sent from my DROIDX using Tapatalk 2 |
![]() | #1825 |
| ![]() yes, it'll do this with no issues
![]() | #1826 | |
Newbie Join Date: Oct 2011 Location: Canada
| ![]() Quote:
alarm prematurely so they are changing the batteries before they should. I have a stock GT3B that I will test to see if it is the same. Thanks for the help. | |
![]() | #1827 |
![]() | #1828 | |
| ![]() Quote:
![]() | #1829 | |
Quarry Creeper Join Date: Jan 2010 Location: Clover
| ![]() Quote:
When I play with dual rate, it's ok except when I put the reverse. For example I go to +20, my rear wheels turn only at 80% front, it's ok, but when I put reverse they are very fast and my front wheels are slow (running 2 fxr's) | |
![]() | #1830 | |
| ![]() Quote:
![]() | #1831 | |
| ![]() Quote:
What I want is for when you are doing small to medium amounts of steering you get less rear, then when you crank it all the way, then the rear catches up. It should be doable, just don't have receiver out of a vehicle to test. Yours is already setup so should be easy to test. | |
![]() | #1832 |
Now that I read that, you probably don't need expo on the thumb switch. Expo is probably just fine in the menus. I'd probably set the rear at 50-75% and be done with it. Then set the thumb for front,rear, both and the other for winch control (Wraith).
![]() | #1833 |
![]() | #1834 |
![]() | #1835 |
Newbie Join Date: Feb 2012 Location: newy
hi i am having trouble with this setup i go thru all the steps get to dig press enter then i have these choices brs ben bnl bar bmo not mom i chose bmo and it comes up with re0 re1 not nor im trying to setup dual esc fxrs |
![]() | #1836 |
What firmware version are you guys using? The templates are good for up to 4.xx. If running 6.0 or whatever the newest one is it's completely different from my understanding Sent from my iPad using Tapatalk |
![]() | #1837 | |
| ![]() Quote:
MOM was in the "buttons" menu...the new UI says the menu in the code. So B for butons and MO for momentary NOR is in the reverse menu. NOR means NO Reverse. The new UI has Re for reverse and 0 for off and 1 for on. So RE0 is NOR and RE1 is REV | |
![]() | #1838 |
Newbie Join Date: Feb 2009 Location: Targu Mures, Romania
An absolute beginer noob question: I'm waiting for the postman to deliver the box with my new Flysky GT3B. I read everywhere that from factory it has a useless Expo. I read that it is possible to add subtrim to it. U would be interested which firmware version I would need if I will use the radio on a SC10 for racing (so really don't need more than 3 channels), I would like to have a functional expo on my radio and I think it would be nice to have subtrim also. Maybe the inactivity alarm would be nice, possibility to set low voltage alarm value, a bigger value for trim settings and for EPA settings. So I would not need 6 or 8 channels or 30 or so modell memory and things like that. Thank you |
![]() | #1839 |
Newbie Join Date: Sep 2011 Location: Fort Smith
does anyone know if it's possible to get a trigger for a gt3b that doesn't have to ship from China? I don't really want to have to wait until the 18th for a new one. PM me if you know where to get one. Thanks! ![]() |
![]() | #1840 |
I can't download the hack program our the manual. The link opens a download box but it never starts Sent from my DROIDX using Tapatalk 2 |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/321742-gt3b-hack-question-answer-thread.html | ||||
RoboSavvy Forum :: View topic - SAM-3 Servo teardown | This thread | Refback | 03-05-2013 01:49 PM |
