10-21-2014, 10:43 AM | #241 | |
| Re: HH Servo Quote:
The batch in production right now is full hardened steel. So depending when or if you bust a gear we will send the best that we have to offer in replacement. | |
10-22-2014, 01:39 PM | #242 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: HH Servo
John, my replacement gear set didn't last but 4 minutes, like the original set. Do I need to send you the broken set? I got the servo a few months ago (I think) and the replacement gears shortly after that. It's just sitting so I can get the gears out if needed. Thanks
10-22-2014, 04:23 PM | #243 |
| Re: HH Servo
You could take a pic of which failed and email it for a replacement, although since the gears were from the same batch I can guess which. We have stronger 2nd gears in stock now.
10-22-2014, 09:04 PM | #244 | |
| Re: HH Servo Quote:
Thanks, Dean | |
10-30-2014, 01:08 PM | #245 |
Quarry Creeper Join Date: Mar 2013 Location: Hampton Roads
| Re: HH Servo
Can I cover the board and the Pot in corrosionX to completely waterproof the servo? I've been doing this with my savox 1230's to make them fully submersible under water. I only mention this because the pot is a non-contact unit if I read correctly? I'd like to start buying these as it's a direct investment in future technology and capability for the rock crawling community, which I greatly appreciate |
10-30-2014, 01:23 PM | #246 |
| Re: HH Servo
Full steel gears will probably be 6 weeks, I'm still having some troubles getting succinct information between the vendor and gear cutter. Dang languages! I don't see why not on CorrosionX. The non contact pot used in our servo is a membrane type, so it is already sealed where it matters. |
11-04-2014, 09:16 AM | #247 |
Pebble Pounder Join Date: Oct 2011 Location: SLC
| Re: HH Servo
Just ordered one of these guys that I will be putting in my summit. I wanna try it in my scx10 but considering im killing 7950's so easily, Ill wait. Way excited, I have been wanting to try this servo since it came out. |
11-10-2014, 07:43 AM | #248 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
| Re: HH Servo
So I have the current I believe V3?? Well I'm starting to get dead spots in the servo. If I turn left and let t go back to center it won't let me turn right unless I go through center. Happens both ways. Sometimes it will stay left or right too unless it get a little help or if I'm going forward or back (helps the tires go center. I checked my BEC and my servo wires. The signal stuff looks to be fine. I'm running one of your Y adapters and that seems to look good to. No fray wires or anything. I have the servo only set to 6.0V. Think I am gonna try a different RX... |
11-10-2014, 07:47 AM | #249 |
| Re: HH Servo |
11-10-2014, 08:12 AM | #250 |
| HH Servo
Well I tried it without a BEC....issue still there. I installed a different rx and still have a issue. I even binded a diff tx and still no luck. Should I be sending this in on a warranty claim or am I missing something stupid... |
11-10-2014, 08:18 AM | #251 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: HH Servo
Just to rule out any compatibility issues, do you have another radio to try it with. That would confirm its definitely the servo. I see you tried a diff rx but sometimes the rx can be an issue. If it still is an issue, then definitely contact HH for warranty. |
11-10-2014, 08:34 AM | #252 |
| Re: HH Servo
Yes, contact us and we will take care of it. Looks like either the motor or the motor driver isn't functioning properly.
11-10-2014, 11:02 AM | #253 | |
| Re: HH Servo Quote:
I can, I'm currently running a spektrum dx3s but I can setup a flysky on there pretty easily | |
11-10-2014, 11:03 AM | #254 | |
| HH Servo Quote:
Thanks John for the reply. Just making sure it wasn't something simple before I take the truck down for warranty. It's all good though I got the yeti to play with haha Speaking of yeti, has anyone stuffed one of these in there. I noticed it was larger than my previous hitec.. | |
11-10-2014, 01:38 PM | #255 |
| Re: HH Servo
The stock yeti servo is pretty long. I measured and it looks to be plenty for fit, but didn't actually drop it in.
11-10-2014, 04:50 PM | #256 | |
| Re: HH Servo Quote:
Yeah I notice the horn on your servo was a little more centered than my hitec was. But that shouldn't make a difference how the yeti is setup. Thanks for the info. I'll put it on my least for this winter build up | |
11-28-2014, 01:25 PM | #257 |
Pebble Pounder Join Date: Nov 2012 Location: livonia
| Re: HH Servo
Just ordered one today.how are they holding up for everyone?
12-04-2014, 03:13 PM | #258 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: HH Servo
I just ordered one of the hh servos and the value on paper looks to be amazing! I was hoping that it was waterproof tho. That was one of my main reasons to buy it. I was wondering how the v2 was working out and when v3 comes out? Maybe the v3 will be waterproof . I hope the one in the mail is waterproof.
12-04-2014, 09:11 PM | #259 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| Re: HH Servo
As far as I know all versions have been waterproof,My 2 versions are. You can't even find them on the site now.Maybe he's dumping them ? My 1st batch of replacements came last month but the 1st one i installed is acting up right away,,,studders and shutters,shakes and glitches but seems to work on the bench but I don't trust it at all. Not near as smooth as my 1st versions,sure hope they get it worked out cause i'm really sick of swapping servo's. |
12-04-2014, 09:14 PM | #260 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: HH Servo
V2 is listed as waterproof & seems to be true after water runs mine has been through |
HH Servo - Similar Threads | ||||
C.I. - Servo Guard - Servo Clamp - Servo Mount - Annoucement | Nova's Ark | Crawler Innovations | 10 | 05-07-2015 01:25 PM |
***Crawler Innovations Engraved Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 106 | 10-20-2013 02:16 AM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
