06-05-2017, 11:52 AM | #401 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79
This is starting to be the most hyped servo on RCC. I don't understand why they changed the bottom of the case. It was fine before and possible stronger. Time will tell, but I doubt it will be an issue. I do like that it was made considerably smaller. |
06-05-2017, 11:57 AM | #402 | |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 Quote:
Hang up and Drive Last edited by mikemcE; 06-05-2017 at 02:22 PM. | |
06-05-2017, 11:59 AM | #403 |
The HH BLS 500 is even smaller, also has exposed screw heads on the bottom Hang up and Drive |
06-05-2017, 12:02 PM | #404 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
Heading home now for the unboxing of the most hyped servo on RCC.
06-05-2017, 12:07 PM | #405 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 |
06-05-2017, 12:32 PM | #406 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
What a big beautiful servo. mine should be delivered already, but I won't be off work for a few more hours. Not that I've had an issue so far, but this will replace a smaller HS-645MG Sent from my Nexus 6P using Tapatalk |
06-05-2017, 12:36 PM | #407 |
Had to stop at the LHS and get a low profile horn. Most of the horns I have wont clear the style of the 10.2's cms. I know this is going way overkill for this rig, but its reliability that matters. This too is replacing a still working 645-mg. Its a 25t I hope, right? |
06-05-2017, 12:51 PM | #408 | |
I suspect that it was also 1 less operation on the CNC And it is a difference. Jato, I know this isn't cheap, BUT its better than the "cheapness" , replace every 3 months thought. | |
06-05-2017, 12:56 PM | #409 | |
06-05-2017, 01:10 PM | #410 | |
I understand it's not cheap. But I, as have many others, have been burned by $100 servos that made great claims. This servo seems to have a lot of positive feedback though so I'm not against trying it when I need another. That is IF it is in stock. It wasn't when I needed a servo for my Bomber, nor when I needed a servo for my STM10, nor when I needed servos for my AX-10 monster truck. | |
06-05-2017, 01:38 PM | #411 |
Screws are fine....... now. In a couple of years, might be a totally different idea. John said the machinist said he had a couple of different things he would do. These are also used I suspect in the drones used by Uncle in the sandbox, so availability is determined by how many Uncle wants this time. I'm going to enjoy this and see how it and the HH go Hang up and Drive |
06-05-2017, 01:50 PM | #412 |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 I never even think about my 420, it just is, wheels always turn, never makes a sound. I would continue to purchase these with confidence until something happens to shake my confidence. I'm sure that can be said about other servos. If you need a new servo, I would recommend trying one of these(well the v3, or v4 since I haven't run the new one) if it fits your needs. So far they have been proven to be quite, reliable, strong, with great customer service. I wouldn't say they are a must have, but really is there a must have servo? But all that said, my sons tactic in a mostly stock deadbolt has run just as much and still works. Granted a much lighter truck, but it is fine for that application. Biggest issue with Johns servos.......................No stickers |
06-05-2017, 01:59 PM | #413 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
I got mine in just now very sweet. Can't wait to run it. 149 r/c worx /scalerfab Team Driver |
06-05-2017, 02:34 PM | #414 | |
Well a little bird told me......; wait just a bit | |
06-05-2017, 02:45 PM | #415 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
06-05-2017, 03:03 PM | #416 |
06-05-2017, 03:05 PM | #417 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 You Made me do it..... Last edited by mikemcE; 06-05-2017 at 03:51 PM. |
06-05-2017, 04:22 PM | #418 |
| Re: ProModeler Servo: 420oz, billet case, o-ringed, $79 No I can't my driver won't fit the top screws, I suspect they are sae not metric. I can't find my sae hex keys now. What I did see was a new batch sticker pasted over an older one, hope that means latest run.RPP is usually current. Hang up and Drive |
06-05-2017, 04:52 PM | #419 | |
WOW what progress!!! | |
06-05-2017, 07:21 PM | #420 |
I was going to start a whole new thread due to its considerable changes and that it's technically a v5 now, but I figure I'd leave that to someone else who's been here longer or keep it here at its home to see how it evolves. I Well got home and ripped it out of the packaging which is very good btw per Mr. John. The first thing I did was slab some di-electric grease around the output spline and case seal just to be semi-safe. I still consider myself new to crawling, but definitely not a nOOb to Rc's, I've never paid more than $40 for a new servo to replace one out of a buggy or basher, I wasn't about to tear inside of this $100 one and dab grease around where it would probably be pointless considering its o-ringed up. Installation on the 10ii was a breeze but keep in mind to put your mounting tabs under (not on top) of the ears, there was clearance issues on the first go around with the pan-hard rod end from mounting the tabs on top. Installed the new 25t Racers Edge low profile horn while centering up on the previous setting of 6v, yeilded sluggish performance out of a beast waiting to be unleashed to its full potential. The Locked Up RC aluminum servo mount was only shipped out today, so I'm going to have to reinstall this again in a few days. Finally it was time to test the Mamba X's internal bec. Now I've had issues with turning up the voltage before on another bec, so I was delayed on doing it, but I believe this new Castle controller to be pretty reliable and I had to see the power this servo packs, so off to the dinosaur pc I went. Bumped the voltage up to its max 8.0v. I wasn't able to get outside to do any real crawling due to running out of daylight and its rained all day in the D.C. metro area. The real rocks are a 3 minute ride in the 1:1 anyway. But from an indoor standpoint this thing is super strong and fast. It centers it self on what seems like some thick 70s style shagg rug. It hums with smoothness. I would have put a video up of it pumping, but than its a link and you know the rest. I'm very satisfied thus far not even getting it on the rocks. Last edited by MattySlimz1987; 06-05-2017 at 07:24 PM. |
ProModeler Servo: 420oz, billet case, o-ringed, $79 - Similar Threads | ||||
Billet Motorola Droid Razr Case | JFAB | Vendors Miscellaneous | 2 | 01-14-2013 08:24 PM |
Angry Apple Ipod billet case | motoworx | Vendors Miscellaneous | 31 | 08-15-2012 06:12 PM |
metal gears , billet case , coreless motor servo CHEAP | BL-4x4 | Electronics | 2 | 01-04-2012 09:21 PM |
