03-25-2019, 04:35 PM | #1121 |
Quarry Creeper Join Date: May 2009 Location: Scotland, UK
| Re: Have tech questions? Will answer.
If you have a brushed 540 electric motor that's 35 turns and you have another motor, of the same design but it's 45t with advanced timing to give it similar wheel speed to the 35t (say 12 degrees?) what will the pros / cons of each be in terms of Battery life Torque Start up Heat generated Total power Brush life Comm life Also, is 12 degrees advanced timing on the above situation likely to give enough extra rpm to get to a similar kv to the 35t? |
03-26-2019, 06:56 PM | #1122 |
RCC Addict Join Date: Sep 2017 Location: The OC
I got these two motors instead of a Trailmaster sportl 550 21T for a trx4 sport I was going to return these but wondered if either would be worth keeping, and why, and what you would put them in. I have 3 ascenders, a scx10ii and the new trx4 sport. One already has a torquemaster expert and one has a trailmaster so I'm familiar with them and they're all more similar than different. What about the 5-pole crawlmaster? I did end up getting the trailmaster sport too, so I have all three to choose from. I might keep 2. I run everything 3s with hw1080 speed controllers, gear to suit crawling. |
03-26-2019, 09:14 PM | #1123 | |
forgive me for cherrypicking the last two posts to address. Quote:
Quote: | |
03-27-2019, 09:46 AM | #1124 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Have tech questions? Will answer. Quote:
Hey John, you missed my question, so thought I would bounce it forward. Hope you're getting better evert day! Ernie | |
03-31-2019, 05:04 PM | #1125 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
Not exactly a crawler, but I'm not satisfied with the amount of cogging I get with my Pro-MT 4x4 using the motor from a rock rey (2800kv 6pole on 3s) I'm thinking about getting a motor from Holmes hobbies, just not sure which one, the new 1/8 seems like overkill to me. Sent from my SM-G960W using Tapatalk |
03-31-2019, 05:30 PM | #1126 |
I don't think it would be overkill - this line in the description sounds perfect: "4274S “Smooth” Application: Short, technical, or low traction track U4 and Truggy/ Buggy; Rock Crawlers desiring precise and smooth startup" |
03-31-2019, 06:10 PM | #1127 | |
Sent from my SM-G960W using Tapatalk | |
03-31-2019, 07:52 PM | #1128 |
Pp xl dosent have as smooth of a start as the others. It's in the description.
03-31-2019, 10:09 PM | #1129 |
| Re: Have tech questions? Will answer. |
04-01-2019, 06:53 AM | #1130 | |
Does advancing the timing, say 12 degrees on a typical 540 motor have any impact on the start up speed vs 0 degrees? | |
04-01-2019, 10:57 AM | #1131 | |||
Yes, startup gets a little jumpier at 12 degrees. It's not really noticeable on 35t and slower, but 27 and faster it becomes noticeable. | |||
04-01-2019, 11:06 AM | #1132 |
Newbie Join Date: Jan 2019 Location: Ontario
Will a Castle B-Link work to interface with a Trailmaster BLE Pro on the Castle app, or will I need a Castle Link and Windows computer?
04-01-2019, 11:07 AM | #1133 |
Quarry Creeper Join Date: Apr 2018 Location: US
04-01-2019, 04:39 PM | #1134 | ||
Quarry Creeper Join Date: Jan 2017 Location: Olathe
It should work, but we can't guarantee 100% compatibility. We didn't lock out any 3rd party products from working with the B-Link when we set it up, but we have done no testing of it to know if it works. Since it is mostly the same as a Mamba Max Pro, it should mostly work. JRH tested it and will have better results than us about how complete it is. | ||
04-01-2019, 05:44 PM | #1135 | |
Is that maybe the field card I'm thinking of? Sent from my Pixel 2 using Tapatalk | |
04-01-2019, 06:46 PM | #1136 |
Field card doesn’t work in field mode. B link works fine, although we have had a few occasions of wonky throttle curve.
04-02-2019, 01:59 PM | #1137 | ||
Thanks. Sounds like I shouldn't have too much of a problem and will give it a try. | ||
04-02-2019, 04:09 PM | #1138 |
04-04-2019, 05:32 AM | #1139 |
Upgrading the gen 8 scout to brushless, are the 540 size puller pro motors a good choice for replacing the 550 brushed motors?
04-04-2019, 05:47 AM | #1140 | |
RCC Addict Join Date: Jun 2017 Location: Canada
My guess is the puller pro will be way better. Holmes Hobbies has a motor chart on their website where you can compare them all Sent from my Pixel 2 XL using Tapatalk | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
