02-09-2019, 10:26 AM | #1061 |
| Have tech questions? Will answer.
Smartsense will work perfect This setup video might help. https://youtu.be/6wvH4A_VqTs Hang up and Drive |
02-09-2019, 03:08 PM | #1062 |
| Re: Have tech questions? Will answer.
Smart sense, all the way
02-24-2019, 09:55 PM | #1063 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
This is not entirely an RC question but strongly related. My son has a Chinese power wheels car with two 550 motors. I know it is easy to replace the stock no-name motors with a decent brushed motor for more power but I want more efficiency and controllable power with full proportional speed. I'm thinking of using two brushless ESCs running from an Arduino with a foot pedal operated potentiometer and the whole thing running on a pair of large 2S LIPOs in series. The only thing I can't figure is how to get a working reverse mode with this sort of setup. Any ideas on how to set this up without making it an oversized RC car would be appreciated. John, would you think two of your revolvers would be okay for this kind of use or would you upsize to the Puller Pro XL or even the 4274? I know that one Revolver works great in my TRX-4 but we are looking at getting a lot more weight moving. Last edited by bbrigg; 02-24-2019 at 10:48 PM. |
02-24-2019, 10:23 PM | #1064 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Have tech questions? Will answer. Quote:
I think Revolvers would work great, but I would use something a little more potent than 2s, 3s would be the lowest I would use, and pair the Revolvers with SW4s or something like that. Sent from my SM-G960W using Tapatalk | |
02-24-2019, 11:23 PM | #1065 | |
If I was a code geek I could probably work out some way to output forward on one pedal and then brakes/reverse on another, I've seen that on Proportional Throttle/Braking/Reverse with RC speed control - ModifiedPowerWheels.com but the code wasn't provided. I was thinking that just using a properly adjusted drag brake would work fine for a toy. The Revolver has excellent drag braking. | |
02-25-2019, 09:17 AM | #1066 | |
I converted my sons power wheels to 24v brushed Ebike controllers with 45t 550 motors. He gets reverse through the normal "gear" selector. Don't know if I would trust brushless, it will either break the gears with power or overheat unless you used a phase amp limiting controller. Also very expensive. But, I would personally choose a puller pro 540 or trailmaster 540 in 2200kv for 4s use. Electric skateboard controllers would work well, the VESC has amp limiting and sensored operation. If you want to run an RC controller, you will need to have your arduino have two modes. Normal operation ,1.5ms to 2ms output signal based on the throttle input. Reverse operation, 1.5ms to 1ms output based on the throttle input. You can toggle between the two modes with a switch or button, and write your code to scale the output based on the state of the button. | |
02-25-2019, 09:24 PM | #1067 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
When can we expect 12t Trailmaster Sport 550s to be widely available? Checked out amain, still only the older higher turn ones. There's a 2WD SCT I want to go 3s brushed with and the new 12t seems perfect! |
02-25-2019, 10:25 PM | #1068 |
| Re: Have tech questions? Will answer. |
02-26-2019, 12:58 AM | #1069 | |
| Re: Have tech questions? Will answer. Quote: Yeeeeeah... no. | |
02-26-2019, 06:23 AM | #1070 |
Pretty sure we have some going to them last week or this week.
03-04-2019, 06:43 PM | #1071 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Hey john, ive been searchin for a BL motor n cant find quite wat im lookin for. Could u please help me out. Im lookin for a low kv, non sensored, 40mm dia max, 55mm long max, 6mm bullets. Shaft doesnt matter, either 3 or 5mm will work. 4s if possible. The trans im running is the scx10 3 gear. Im buildin a solid axle monster truck from a scx10 chassis and ar60 axles. I have metal axles comin for the build. Thank u for any n all help, very much appreciated! Heres pics of wat im workin on if it helps Sent from my SM-J327VPP using Tapatalk Last edited by indybama; 03-04-2019 at 06:48 PM. |
03-05-2019, 01:39 AM | #1072 |
Rock Stacker Join Date: Sep 2018 Location: boise
Hi John, I just bought a HH Puller Pro 540 stubby 2700 from you. Heard nothing but good here about your motors and have been wanting to try one. It’s in a VS4-10, mamba x, 8.5lbs RTR. I basically set up esc to your recommendations on your video. It not nearly as smooth as my 1900, 2280, and 2850 Castle motors. It cogs when climbing and will struggle at a flat face then jerk forward. Not sure what’s going on. Castle motors smooth as ever. I have a email in to you and a call. Hoping to figure this out ASAP. Please email me I can give you my #. Thank you.
03-05-2019, 10:23 AM | #1073 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Have you tried swapping the cable with one that's known to work? | |
03-05-2019, 11:17 AM | #1074 |
I’ve got that in my VS4, and it’s smooooooth and slooooooow ! Sounds like a bum cable Hang up and Drive |
03-05-2019, 04:02 PM | #1075 |
| Re: Have tech questions? Will answer. Thank you for the suggestion, I did get a call back from Justin @HH and checked sensor wire while talking with him. Didn’t help. But, they are sending out a new motor to try. Just was bad timing for me we’ll be on the road, so they are accommodating that and sending it to one of our stops.
03-05-2019, 09:47 PM | #1076 | |
REVOLVER 540 SENSORLESS ROCK CRAWLER MOTOR | |
03-06-2019, 07:23 AM | #1077 | ||
03-06-2019, 08:10 AM | #1078 | |
Sent from my SM-J327VPP using Tapatalk | |
03-06-2019, 10:13 PM | #1079 |
Newbie Join Date: Mar 2019 Location: Frisco
I’m new but addicted to the Rc game and had my eyes set on a Gmade R1. I’d like to rock race & crawl in the same run without changing electronics. Would a Castle Mamba X SCT Sensored 25.2V WP ESC & 1415-2400Kv Combo work? Anything else I need buy or need to know? Thanks a million
03-06-2019, 10:26 PM | #1080 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
