Thread: RCCRAWLER tips, cheap tricks / parts guide.
Old 01-09-2005, 06:31 PM   #1
2006 2.2 National Champ
BENDER's Avatar
Arrow RCCRAWLER tips, cheap tricks / parts guide.
This is intended to be a guide to cheap fixes, mods, tricks, and parts. I'm doing this to keep a thread that just contains these tips so they are easy to find. I used title of original thread w/ a little editing on some. I included important tips on setting up chassis's as well.
First off...............nitros can't crawl.
KevKaos: April 2006
Got a cheap trick, that's not on list? Post it here....
Cheap tricks, post them here - RCCrawler
How to do the narrow XR10 mod to Axial axles
Wide AXR10 axle mod
Painting the body (opinions on brands).
Painting the body - RCCrawler
Tips on painting bodies (correct way).
I need some tips on painting a proline body... - RCCrawler
Stripping paint from lexan.
stripping paint from lexan - RCCrawler
Lexan body work.
Lexan body work - RCCrawler
Ultimate tire foams.
Ultimate Tire Foams - RCCrawler
Removing glued tires.
Removing Glued Tires - RCCrawler
How to narrow 40 Series wheels
-Narrowing Proline 40 series wheels
-Narrowing Axial 40 series wheels
Cheap plastic rod end slop fix.
Cheap plastic rod end slop fix. - RCCrawler
BFT rod end part number and price.
BFT rod end part number? - RCCrawler
Traxxas rod end part number.
What is the part number of that standard Traxxas Rod End? - RCCrawler
Cheap metal rod end bible.
CHEAP METAL ROD END BIBLE - RCCrawler
How to lock Clod diffs.
RCCrawler.com- Your #1 source for Radio Controlled Rockcrawling!
Gear ratio equations and chart.
Gear Ratio Equation and Chart I Made for us Crawlers... - RCCrawler
Balancing weight.
Balancing Weight - RCCrawler
Adjusting anti-squat?
Adjusting anti-squat? - RCCrawler
Anti Squat and Suspension Tech - RCCrawler
another-4-link-thread
Torque twist (how to fight it).
Torque twist/HELP PLEEEEEEEEEEASE!!!!!!!! - RCCrawler
TXT servo mount dimensions.
Servo mount? - RCCrawler
Revo shafts (how to install).
I've seen lots of posts asking about Revo shafts... - RCCrawler
Extending Stampede driveshafts.
How to Pede sliders..Drive Shafts - RCCrawler
4 Link 101. (proper set-up tips)
4-Link 101? - RCCrawler
How to figure link length.
finding the correct suspension link length - RCCrawler
Making links.
Making Links - RCCrawler
"roller" links... - RCCrawler
Best way to link mount shocks.
What is the best way to link mount shocks? - RCCrawler
How do I stop my link clamps from sliding?
How do I stop my link clamps from sliding? - RCCrawler
How do I fishmouth brakeline?
how do i fish mouth a brakeline - RCCrawler
Harris safety silver-56 (where to buy).
harris safety-silv 56 - RCCrawler
Brazing stainless?
Brazing stainless - RCCrawler
Bending aluminium.
Need help bending aluminum - RCCrawler
Cutting aluminium.
What do you guys cut aluminum with? - RCCrawler
GD-600 (how to install).
Installed a GD-600 gear reduction - RCCrawler
Servo guide
R/C Sailplanes: Servo Chart
645mg turned into winch.
Crawler Tech: How to Build a Winch - RCCrawler
how do i turn a hi-tec 645MG into a working winch??? - RCCrawler
Correct part # for pinions.
Correct part numbers for pinions, etc? - RCCrawler
Servo saver or not.
Servo saver or not - RCCrawler
Truck problems (fixing glitching).
truck problems - RCCrawler
Tube project idea (getting scale look right).
tube project idea - RCCrawler
Series or parallel?
Series or Paralle - RCCrawler
Motor wiring (forward/reverse rotation Q's).
Motor wiring - RCCrawler
How to build/tune a 2.2 comp crawler.
2.2 TLT Competition Crawler Question... - RCCrawler
TLT Rock Buster vs TLT Max Climber (What's the difference?)
TLT Rockbuster, TLT Max Climber - RCCrawler
TLT tranny options.
TLT transmission options for your crawler - RCCrawler
Turning down TLT shocks, for a more scale look.
How to turn down stock tlt shocks. - RCCrawler
Limiting straps.
Limiting straps - RCCrawler
Fender trim materials.
Found a couple good fender materials... - RCCrawler
R/C License plates.
looking for rc sized replica license plates... - RCCrawler
Cheapest crawler.
ZipZap Rockcrawler - RCCrawler
Need some driving tips for comps? You know you do.
How to: Drive Better "TIPS" - RCCrawler
Tips for building a backyard rock garden.
How to build a crawling course: step-by-step - RCCrawler
How to make front dig.
Miniwheeler's dig
socket to ya dig
Bearing mod to eliminate the slop in worn aluminum axle C's
Mnster's mod
Locking a Pede tranny without epoxy or JBweld
Offroader5 shows you how to lock a pede tranny with no JB or goo
Widths of common crawling axles
Losi Springs to use on crawlers
Time to start wrenching.
BENDER is offline   Reply With Quote
Old 01-18-2005, 12:19 PM   #2
Diggin' the new SCX10 II!
badger's Avatar
Default Re: RCCRAWLER tips, cheap tricks / parts guide.
This has been restored. testing.
badger is offline   Reply With Quote
Old 01-18-2005, 04:50 PM   #3
how to cut alumium link is wrong sumthing for maximizer beadlocks :?
tltcrawlerxtrem is offline   Reply With Quote
Old 01-18-2005, 06:35 PM   #4
BENDER's Avatar
Thanks for pointing that out, I removed link. I'll try and find the right thread and post it back up.
Old 01-30-2005, 11:43 PM   #5
Thanks for all the time you put into the stickies, what a truck load of helpful info. ;)
hcfr34 is offline   Reply With Quote
Old 01-30-2005, 11:58 PM   #6
BENDER's Avatar
No problem, glad to see people are finding it useful.
Old 02-26-2005, 02:03 AM   #7
BENDER's Avatar
Talking Updated
OK guys, I finally updated these links to the new forum. LMK if anyone finds any problems.
Old 04-02-2005, 12:51 PM   #8
i though i saw somewhere someone cutting a dog bone in two then like putting each half in some sort of a metal shaft thing
rcbif is offline   Reply With Quote
Old 04-03-2005, 12:39 PM   #9
BENDER's Avatar
Here's a link that might answer your questions:
Stretching Wheelbase ????
Old 12-27-2005, 04:19 PM   #10
Madcratebuilder's Avatar
FASTENERS..........we all use them in the build-up of your rigs. I used to get mine at the local True Value, till I found this place.
www.microfasteners.com
Money back guarantee...can't beat that.
Great price. I just recieved my order of 120 SS sockethead 3mm screws, ranging from 20-40mm in lenght. $31 shipped. Half of what you would pay at the hardware store. That encluded 3 day priorty mail
Madcratebuilder is offline   Reply With Quote
Old 01-26-2006, 12:21 PM   #11
i think this might belong here for anyone who is looking for a servo
gigantinc servo guide
http://www.fatlion.com/sailplanes/servochart.html
(yes, i know it is already posted elseware, but i think this might be a more practical place for it)
spookyseven is offline   Reply With Quote
Old 04-05-2006, 11:56 AM   #12
i noticed some people mentioned they had trouble drilling accurate holes in aluminum so i figured id post this http://www1.mscdirect.com/CGI/NNSRIT...PMT4NO=6387899
they are great for making pilot holes because they are rigid and as long as you use a smaller one, (1/4 shank) they are perfect size for RC stuff.
peej410 is offline   Reply With Quote
Old 09-20-2006, 10:14 PM   #13
Default gear reduction units?
Can you put up sources to gear reduction units being used on the E/Tmaxx?
I can't find anything.....
Mule is offline   Reply With Quote
Old 09-20-2006, 10:33 PM   #14
BENDER's Avatar
I think most Maxx guys that use a reduction have the GD-600. Install will be about the same as a TXT which is posted here.
Not sure if it'll work with a T-Maxx tranny though.
Old 09-21-2006, 09:55 AM   #15
Default cool!
Thanks, I found everything I needed!
I saw a post w/ dual motors on dual GDs - on a maxx.
Here is the mfg # GPMG0850
Here is a tower link. http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML
For $12.99, I think it's worth trying them on anything!
Greg
Old 01-12-2007, 05:48 PM   #16
good info here thanx
Dsanchez is offline   Reply With Quote
Old 05-12-2007, 03:12 AM   #17
is anything about how to made a tube chassis or roll cage?
like what material to use and how to weld it together,.
balang_479 is offline   Reply With Quote
Old 05-12-2007, 05:01 AM   #18
BENDER's Avatar
Here's a link to an article on the front page on building tubers.
http://www.rccrawler.com/tuber.htm
Old 05-25-2007, 10:06 PM   #19
great info I guess I will never have to ask a thing now hahahaha NOT
FASTFLEE is offline   Reply With Quote
Old 07-04-2007, 09:51 PM   #20
I joined the Band!
Hey thanks for puttin my guide up there. I really appreciate that BENDER.
Crawlerdude75 is offline   Reply With Quote
