10-10-2013, 02:17 PM | #121 |
| Re: TorqueMaster BR Mini Packs the Power!
Sorry if this was answered before.. But I bought one for my 2.2s rig.. And have yet to install it. My question is will I run into the same heat problems as you would with a dual setup? Or will I be fine since there is only one? I run my BEC direct wired to my servo if that helps any. Gracias |
10-10-2013, 03:29 PM | #122 |
It will still be warm, but not a problem.
10-10-2013, 08:39 PM | #123 |
| Re: TorqueMaster BR Mini Packs the Power! |
10-11-2013, 01:56 PM | #124 |
I wanna be Dave Join Date: Dec 2006 Location: here
So I went through my batteries 30ish only 12 will work with the br minis. I know the "bad packs" are good. However they just can't handle the br mini esc. Gen aces 450 25c (12) and CBP elite (all 5) won't work. So my options are larger mah or turn off or lower LVC or maybe jump up to 4s ?lipo? If I turn off LVC and battery can't handle load puff maybe fire? What is LVC set @ stock? |
10-11-2013, 02:04 PM | #125 | |
| Re: TorqueMaster BR Mini Packs the Power! Quote:
10-11-2013, 03:11 PM | #126 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
That's one of the most popular 2.2P packs there is. If the mini doesn't work with those batteries maybe there's something going on with the mini. Check your LVC with CastleLink. Maybe they're set wrong. Or maybe the mini has so much less resistance than previous esc's it's pushing more amps to the motor. |
10-11-2013, 04:02 PM | #127 | |
A few people have experienced cutouts when switching from sidewinder micros. The BRmini does allow for a higher amp flow, which beats packs harder. | |
10-11-2013, 07:22 PM | #128 |
Rock Stacker Join Date: Apr 2011 Location: 303
I got some magnum energy 450 35c 3c an i'm still experiencing cutoff with one of the two esc's it reboots then it works again .
10-11-2013, 09:13 PM | #129 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Any updates to the chip removal guide??
10-14-2013, 12:14 PM | #130 |
Quarry Creeper Join Date: Dec 2009 Location: ...---...---...---...---
I'm expericing the same issues with my cbp 450 25c 3s lipos, mine cut out on the front motor bad almost everytime, this will be an issue for me since my rig spends alot of time on its top. is there an eta on the firmware updates? |
10-15-2013, 08:13 AM | #131 |
Anyone running Max amp batteries with the br mini Experiencing LVC issues? I'm leaning toward buying a few max amp 430mah 100c 3s. |
10-17-2013, 12:48 PM | #132 |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
I received mines today that thing is so smal l!!! can wait for my Pullers thanks |
10-17-2013, 01:12 PM | #133 |
Quarry Creeper Join Date: Apr 2012 Location: france
10-17-2013, 01:42 PM | #134 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
Already got my pullers just waiting for my mini's to show up But getting scared with all this talk of motors cutting out :( Last edited by chevotafun; 10-17-2013 at 01:45 PM. |
10-17-2013, 02:19 PM | #135 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
Wired mine up like RcBro's setup, in my berg at 4lbs.... Red wires pulled going into the receiver. BEC set at 6.3v. Holmes 35t hand wound, 18G wire. 450 30c batteries. Deans micro plugs. 13/14 gearing. Ran fine perfectly for a few days and now my front motor stops. The ESC running the frt motor arms then turns off and then re-arms. When it shuts off, the ESC hits 140 pretty quickly. When it was workin, it was ran between 120-140 temp. I turned the BEC down to 6.1v and turned off the LVC. Hoping it works again. When it works, it's a great ESC. Smooth and good punch. Last edited by saniel68; 10-17-2013 at 02:46 PM. |
10-17-2013, 04:17 PM | #136 |
The BR mini's work awesome in my sporty an the scaler just can't get them to work in the xr to well hope the bugs get worked out. An that's with out the extra bec or the zaner.
10-17-2013, 05:02 PM | #137 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
I've got 2 smashed in my Xr, bec removed on front esc, bec on rear esc powering rx, holmes hold off, direct wired castle bec for servo set at 7.4 volts, brood 35t vapors, no Zener installed, 3s batts, micro deans No problems whatsoever and esc package never gets above 120* Turn off holmes hold everyone!, it won't work till the next castle firmware update |
10-17-2013, 05:52 PM | #138 |
That's the same way I run mine but with the bec on the front still guess ill have to try removing it see if that's the problem thanks for the info...
10-17-2013, 06:40 PM | #139 | |
CC BEC to 6.1v everything seems good so far. I do run just a tick under 140 deg after a 8 min comp senerio practice. | |
10-17-2013, 06:46 PM | #140 | |
Bc's Y-Town SA 4.0 to bodied Double Agent | |
Tags |
bad ass |
TorqueMaster BR Mini Packs the Power! - Similar Threads | ||||
TorqueMaster BR-XL Big Brushed Power! | JohnRobHolmes | Holmes Hobbies | 1351 | 05-13-2020 03:52 PM |
Mini torquemaster ???? | Mrblue | Losi Mini-Rock Crawler | 80 | 05-01-2010 08:59 PM |
