10-29-2013, 06:18 AM | #161 |
| Re: TorqueMaster BR Mini Packs the Power!
Stackers worked out very well, they are in production. I expect to have double ESCs ready in about two weeks. We have purchased a Reflow oven and hot air soldering station to help construct them faster and more consistent.
10-29-2013, 06:42 AM | #162 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
Cool! Thanks for the quick reply.
10-29-2013, 08:39 AM | #163 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
John, When will you have the mini's back in stock? |
10-29-2013, 08:42 AM | #164 |
Pebble Pounder Join Date: Jan 2012 Location: Chino Hills
Great news John. Now I'm just waiting for them to be in stock so I can grab some.
10-29-2013, 08:50 AM | #165 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Great news on the stackers!!!
10-29-2013, 10:39 AM | #166 |
| Re: TorqueMaster BR Mini Packs the Power! |
10-29-2013, 01:41 PM | #167 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Those stacked ones look awesome... What are we looking at for a price for them?
10-29-2013, 03:06 PM | #168 |
Haven't settled price yet, I have to do a first run to see how much labor it involves. The reflow oven will really speed it up. The additional wire, conformal coating, and labor of assembly will make it more than just two bare units. But ballpark, im guessing $150 for a dual ESC unit without plugs. |
10-29-2013, 08:35 PM | #169 |
Git er dun!
10-30-2013, 10:29 AM | #170 |
10-30-2013, 05:58 PM | #171 | |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
| Re: TorqueMaster BR Mini Packs the Power! Quote:
10-30-2013, 07:51 PM | #172 |
Yep, the stackers will be available separately.
11-06-2013, 08:22 PM | #173 |
Any timeline on these stacker boards John? I wanna buy a pair.
11-07-2013, 01:06 AM | #174 |
Quarry Creeper Join Date: Dec 2009 Location: ...---...---...---...---
Is there a fix yet for the motor cut out issue? If so please lemme know. |
11-07-2013, 01:20 AM | #175 | |
Yes, use a better/ larger battery or increase your battery side wire size. Or reduce/ remove the cutoff voltage. The mini is allowing for higher performance, your battery side is the choke point. | |
11-07-2013, 08:51 AM | #176 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
I turned off my LVC on now mine works flawlessly. I just use my timer on my radio to keep track of run times. Usually two 7 min comp practice scenarios with no worries. |
11-07-2013, 08:54 AM | #177 | |
What battery would you recommend for a Bully MOA? | |
11-07-2013, 09:43 AM | #178 |
[QUOTE=JohnRobHolmes; Yes, use a better/ larger battery or increase your battery side wire size. Or reduce/ remove the cutoff voltage. The mini is allowing for higher performance, your battery side is the choke point.[/QUOTE] Would I remove the cut off voltage on the bec, or the escs? |
11-07-2013, 10:02 AM | #179 | |
600mah 35c is a good size to start. If that is what you have and they are new (and known to be a stout brand), try increasing the negative battery wire to 14g or 13g between your plug and ESC. ESC has the cutoff voltage. | |
11-07-2013, 10:35 AM | #180 |
I'm using max amps 430mAh 100c, and still have the issue using 16ga wires, I'll try reducing the cut off voltage or turning it off and see if that works.
Tags |
bad ass |
TorqueMaster BR Mini Packs the Power! - Similar Threads | ||||
TorqueMaster BR-XL Big Brushed Power! | JohnRobHolmes | Holmes Hobbies | 1351 | 05-13-2020 03:52 PM |
Mini torquemaster ???? | Mrblue | Losi Mini-Rock Crawler | 80 | 05-01-2010 08:59 PM |
