05-30-2008, 01:02 PM | #881 |
Rock Stacker Join Date: Oct 2007 Location: Salt Lake City, Utah
Ok. I had my hobby shop check all the settings. Nazt says everything is setup right. I guess I will just keep screwin with it.
05-30-2008, 01:09 PM | #882 |
It could be your radio, but the only time I have experienced a lag or issue like that is when the throttle endpoints were not proper. Could be a hardware issue on the MM, you may try reflashing the ESC to the current firmware- but I highly doubt that would cause the issue.
05-30-2008, 01:13 PM | #883 |
I will try and rebind my 3r and see if that helps as well as reload the updated firmware that's installed. I will try and make a video of what its doing to see if that can give more help.
05-30-2008, 06:30 PM | #884 |
Rebound the radio reflashed the MM and reset the throttle endpoints still have the every so often delay.
05-30-2008, 07:11 PM | #885 |
Thats weird. Do you have another radio to give a try? Do you have another ESC to try?
05-30-2008, 07:46 PM | #886 |
I don't I will try and see if I can get one of each. Then I will follow up and let you know. Thanks for all the fast responses.
05-30-2008, 08:31 PM | #887 |
RCC Addict Join Date: Feb 2006 Location: ccxc
any good news on the 7t's ? |
05-31-2008, 07:42 AM | #888 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
JRH, I just ordered a Tekin Fxr from you, Do you not carry a HotWire cable for programming these. I didn't see it on your site. Are there any disadvantages to not having one or do they make it any easier to program. I guess what I'm getting at is do you recommend having It TIA Steve Last edited by TEDROCKZ; 06-04-2008 at 05:52 PM. |
06-03-2008, 09:25 AM | #889 |
RCC Addict Join Date: May 2008 Location: On the rocks
nvmd....
06-03-2008, 03:59 PM | #890 |
Newbie Join Date: May 2008 Location: Clackamas
| Cc Bec
hey john so im new to all the crawler electronics stuff. i Just bought a cc BEC as a recomendation from friends to get more power out of my servo. since my ESCs BEC is weak. so how do i plug everything in. here is what i have: li-po battery inline with a Novak li-po cut off then ESC red and black(battery conn.) then now the Novak cut off is plugged in to ch2 on the reciever and the ESC is plugged in to the Novak cut off. here is the question where does my CC BEC plug in the reciever.??? and how do i disable the BEC from The ESC???? thanks in advance. |
06-03-2008, 06:31 PM | #891 |
Quarry Creeper Join Date: Aug 2006 Location: Monroe NC
I sent you an email John. Thanks for the help! |
06-03-2008, 07:39 PM | #892 |
Rock Stacker Join Date: Apr 2008 Location: Norcal
I am about to order the electronics for my new Berg 2.2. I wonder what do you recommend? I'm trying to decide between your custom wound 55 turn motors, on 4 cells or your 35T on three cells? Do you know when you'll have the 35t back in stock? Could you comment on my thread in the Newbie section? Setting up an Enroute Berg 2.2 Looking forward to giving you my buisness, Charlie Last edited by RCbasher; 06-03-2008 at 08:40 PM. |
06-07-2008, 03:12 PM | #893 |
Just got the 7t hooked to an axial. It seems forward and reverese are swapped? It rotates the opposite of my other motors. Can I just reverse the polarity of the Deans? Help! Thanks (basically it is rotating clockwise, all the other motors go counter clockwise looking at the pinion. I flipped the endbell 180 and it is rotating coutner now. Will this cause any harm? Should i reverse the polarity instead? How do I now if I have 0 timing. It seems to be getting hot but I am running a crappy ESC till Monday.
06-07-2008, 05:06 PM | #894 |
Quarry Creeper Join Date: Sep 2005 Location: on the rocks
Hey JRH can a CC Mamba max handle 2 7t pullers running a 3cell lipo?
06-08-2008, 12:51 AM | #895 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
Hi John i recently purchased a couple of cc bec's from you and just got round to programming the second one but ran into a little problem the bec wasn't being detected by the castle link software, no lights were coming on in the bec so i plugged the battery in and sparks started coming out of the unit i immediately unplugged the battery and the computer now recognised the bec so i programmed it to what i needed unfortunately i don't want to plug the battery in until i know that when i do it won't kill my battery or worse case set fire to my rock crawler or house thanks for your help Glenn ps i also sent you an email |
06-08-2008, 08:08 AM | #896 |
also the battery polarity is right, i've checked that a couple of times
06-08-2008, 02:55 PM | #897 |
Rock Stacker Join Date: Apr 2008 Location: SW FL
I'm in need of your expertise JRH . i know i want the 7t puller motor , and i need a 645 servo . now for the part where i am lost , which esc would you reccomend for it , and which bec ? if you say the sidewinder , your going to have to program it (i'll order everything thru you once i have an answer) cause i am the only rider on the short bus when it comes to comps and any other electronics LOL give me a sweet deal on the package if you can too , i'm almost broke |
06-09-2008, 04:27 AM | #898 |
Jhon you havent posted in here in a week and a half... forget about us?
06-10-2008, 12:26 PM | #899 |
Quarry Creeper Join Date: Apr 2007 Location: Katy, TX
Whats up JRH? Is it safe to run a maxamps 1290mah 4s lipo w/ a mamba max, castle bec and a OG crawlmaster? I know on the side of the esc it says up to 3cell lipo, but since i'm using the bec eliminator, is 4s ok?
06-10-2008, 12:48 PM | #900 | |||||
35t should be in stock within a week. Quote:
The sidewinder and CC BEC would be a great choice. I can program it however you want. I don't have any package deals at this time that are better than the current pricing. The 4s will push the OG motor pretty hard. Give it a shot, but you will need to gear as low as possible and watch the heat on the motor- the ESC won't really sweat at all. | |||||
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
