06-10-2008, 06:52 PM | #901 |
Rock Crawler Join Date: May 2007 Location: Glendora
| 27 turn stock motor
I want more wheel speed without going brushless. I was wondering if a stock 27 turn motor with stiffer springs would work for wheel speed and torque for comp crawling? I plan on running it with a 2c 2000 max amp Lipo bolted to an axial tranny....by the way, what pinion size to start with? THANKS!!! |
06-10-2008, 07:05 PM | #902 |
Newbie Join Date: Jun 2005 Location: Pittsburgh
John, I sent you an email with a few questions about a possible outrunner setup for a truck of mine.. just wondering if you got it since my email account seems to be acting up lately. My email addy is moaschkenas(at)earthlink.net. LMK if it ever showed up. |
06-10-2008, 07:10 PM | #903 | ||
Bolting your battery to the tranny sounds silly Quote:
Didn't get anything today that I didn't already respond to. | ||
06-10-2008, 09:46 PM | #904 |
I think i accidently sent it to your hotmail addy. I re sent it to your customer service addy posted on here if that helps. |
06-10-2008, 11:34 PM | #905 | |
06-11-2008, 09:26 AM | #906 |
Quarry Creeper Join Date: Dec 2007 Location: #
just got my cobalt 7t and it just seems slow ive got 7cell nimh saddle pack. stock axial gearing just need to know do i need to go to lipo to feel the full power.
06-11-2008, 09:43 AM | #907 | |
More voltage. You don't need lipo, just more voltage. The 7t isn't any faster than a 27t motor timed to zero, so only marginally faster than a 35t motor. | |
06-11-2008, 09:51 AM | #908 | |
06-11-2008, 01:44 PM | #909 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
So, I have a question. What can the sidewinder take at the max from your experience? Can it take a 7T or 10T at 14.4V? I need something and kinda quick. I have a scale "Mudbowl" event and I can't take the WK 7T/MM/14V due to too much articulation and the Crushers being too tall. So, now I need to build something else or mod an existing truck.
06-11-2008, 02:29 PM | #910 |
I have never used the 7t on 14.4, but with nimh you should be able to swing it. It really depends on how high you gear it.
06-11-2008, 04:02 PM | #911 |
Rock Crawler Join Date: May 2007 Location: Arnold
| In serch of.
Im looking for a 540 size 27x1 wind motor that will stay together with 21.6 volts-18 cells , Can you help. Its for a 4x4 sand racer.
06-11-2008, 04:37 PM | #912 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
John, I sent a bad 0606i charger to empire and I contacted garry and he said that they got my charger. Just wondering if you have sent me a replacment yet.
06-11-2008, 06:09 PM | #913 |
Quarry Creeper Join Date: Oct 2007 Location: Guam
| battery status
sir, interested in purchasing a pair of Elite 1500 10 cell (12.0v) Saddle pack #193. website shows out of stock. when will it be available. thanks |
06-11-2008, 10:02 PM | #914 |
Rock Stacker Join Date: Mar 2008 Location: inmyhead
Hey John - I've bought some products from you in the past and I know your the electronics "guru". I have a question for ya (I'm new to rc and just had my truck built up for me). I'm having an issue where I fully charge my battery (electrifly 11.1v 910mah), install it in the truck and it works great for about 5 minutes plenty of wheel speed and torque and then in gradually starts loosing wheelspeed to the point that it will barely move forward - the front tires will turn side to side in a stationary position but the rig won't move forward or backwards. I tried a brand new battery and fully charged it with a Quattro plus pro-peak charger - and got the same results. Any idea what might be causing this? I finally got everything together after almost 3 months and now I can't use it!! Thanks! -Tim |
06-11-2008, 11:14 PM | #915 | ||||
06-11-2008, 11:17 PM | #916 |
55t integy, mamba max - ccbec, r2d tranny w/disco, 5595 servo, 645 for the dig Lipo is not hot, esc isn't hot either. Both batteries I tried are the electrifly ones. Thnx. |
06-11-2008, 11:18 PM | #917 |
Sounds like they can't cut the mustard. Try something else, try a friends pack or any other pack.
06-11-2008, 11:21 PM | #918 |
Cool, thnx John. I'm going to take it back in to CKRC tomorrow and let them look at it. By the way what pack would you recommend - thunder power, maxamps? -T |
06-11-2008, 11:26 PM | #919 |
Anything you can get your hands on. Stick with 2000mah or more, 15C or above.
06-11-2008, 11:30 PM | #920 |
Cool, thnx.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
