12-07-2008, 06:26 AM | #1221 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
Hey John, I was looking around and never really found what I was looking for but will the stock losi mrc esc handle the mini torquemaster? I saw on the website that it recommends another esc but was trying to keep from buying one but if i needed to then i was going to do it all in one order. thanks |
12-08-2008, 04:38 PM | #1222 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
John, I have a 1000kv revolver outrunner with a MM on 3s2p 1100mah A123 cells - I've a split pack currently 1 next to servo and one on rear 4 link. Do you think I should drop the rear pack and run 3s1p? Thx |
12-10-2008, 12:03 AM | #1223 |
Quarry Creeper Join Date: Jul 2008 Location: Saskatoon in summer, Las Vegas in winter.
Hi John, I just ordered one of your Torque Master 55t motors. I am installing this motor on my Axial Kit Scorpion with a Mamba Max ESC. Also going to be running one of your 8 cell saddle packs and a 12T pinion. My question is regarding the Mamba Max ESC. I am running a Mac computer and have no way to program the ESC. Can I just plug it all together and go, or should I hunt down a PC running XP (32 bit) so I can program? Any suggestions would be appreciated. |
12-10-2008, 12:05 AM | #1224 |
Newbie Join Date: Dec 2008 Location: USA
| First RC - TXT1 to be modded into a robot
-This comes from another post on this forum by referral- Hello! I'm building my first RC vehicle and needed your help with the part selection. I've been through a lot of stuff on this on the forums and this is what I've gathered. I would appreciate your suggestions (I prefer keeping things simple and straightforward the first time around, so I hope to do with most of the stock setup!) First off, the purpose - I want to build this RC truck using the TXT-1 to be later used as a mobile robotics platform (that means, I'll be adding a small laptop and a few light-weight sensors) Here are my current design choices - 1. Tamiya TXT-1 2. Novak Super Duty XR ESC 3. HiTec 5645 x 2 for the steering 4. Futaba 2DR 2-channel AM/2 S3003 Servos 5. EMS servo reverser Futaba J 6. Tower Hobbies 7-cell 8.4volts NiCd 7. DuraTrax Piranha charger Does this look right? I'm especially concerned about the ESC, the steering servos and the batteries (no speed concerns). Could you suggest good NiMh packs as alternative to the NiCads, I expect some serious discharge current requirement considering the two servos, plus the additional weight of the laptop. Also, am I missing anything? I appreciate any suggestions! Thanks! |
12-10-2008, 02:12 AM | #1225 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
I received my motors pretty quickly. Good job and thanks! I have a question though. When i ordered my motors, i chose for it to have the comm cut for smoother low speed control. I figured this would be better but what exactly did you do to the comm? Do i still have to break in the brushes (in cup of water?) ? Thanks! |
12-10-2008, 07:42 AM | #1226 | ||||||||
You will need to at least change the MM to brushed mode. Otherwise the addition of drag brake and full reverse is nice to have. It would certainly be easiest if you could hunt down an XP machine. Quote:
12-10-2008, 07:47 AM | #1227 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
John, Would the Mamba Micro Pro be able to handle one of your 45t 540 handwounds with 3S in a 2.2 single motor? Oh and I thought I heard someone mention a cobalt puller 400 the other day. Did my ears lie or are you working on something like that. Last edited by Locked Up; 12-10-2008 at 07:49 AM. |
12-10-2008, 07:51 AM | #1228 |
The micro can't handle 540 motors, except maybe a 55t on 6 cell 2/3a pack. The Cobalt 454 is what you are thinking of, it is a 400 frame motor. |
12-10-2008, 07:30 PM | #1229 | |
Chris | |
12-11-2008, 09:00 AM | #1230 |
Rock Stacker Join Date: Mar 2007 Location: on a lake
hey john, what would you recommend for you coblat puller 10T motor. will a rooster crawler work or should i get a MM or FXR |
12-11-2008, 09:26 AM | #1231 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Pre made plug adaptor
Can I get a premade plug adaptor to go from the stock Tamia plug on the Duratrax Onyx 220 charger to go to a deans male plug? my batts. are female Deans plugs.
12-12-2008, 10:47 AM | #1232 |
Hi John, Thanks for the reply to the previous post. I had a quick query, I'm using the Super Duty XR ESC. And I'll be having my circuit onboard for interfacing with the sensors and also the steering servos (won't be using the R/C receivers). Now I was wondering how stable the BEC output (rated 6volts, 3A) of the ESC is? Is it stable enough for me to directly use as input power for my circuit? Does it fluctuate or give glitches causing potential circuit resets? If it's going to cause problem, what do you suggest? Thanks! |
12-12-2008, 04:48 PM | #1233 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
| Torque master mini
Hey John, You recently sent me a new pair of brushes for the tmm. I took off the top cap of the motor when installing them and now i'm not sure how to zero the timing of the motor for flipped tranny. Could you help me? Do you have any pics? I have searched all over hear and can't find any? Last edited by Pdog7; 12-12-2008 at 05:08 PM. |
12-12-2008, 10:08 PM | #1234 | ||||
12-13-2008, 06:42 PM | #1235 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
| $6 5pole brushed motors
Wow, that's a great price on that motor! When you say it's slow on 6cells...........like 75T motor slow, or slower? Running in an indoor only, 1.9 x-trail on 6cells , 49:1 overall ratio, (with 5 and 7 year olds - so slow is good). thx |
12-13-2008, 09:06 PM | #1236 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Hey John,do you have any 35 turn handwounds yet?Also do you have any mrc motors left?.Also do you have any torquemaster esc's?(i'd love to have one).I need 2 35 turn torquemaster handwounds,1 torque master esc,and one mini torquemaster motor..Let me know if you have any and I will come meet up with you again and get them from you,so hold them back for me if you do have them and I will come up monday or tuesday to get them.Just let me know John.Thanks.
12-14-2008, 02:25 PM | #1237 |
Quarry Creeper Join Date: Aug 2006 Location: Baumholder
hey do you ship to an apo address
12-14-2008, 08:12 PM | #1238 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
ok, Specs: running a 7t puller, mamba max esc, castle BEC, rig weighs 7lbs, front wheels are 1.2lbs each, rears are 0.8lbs each approximately 13/87 gearing on axial trans wanting to run 3s lipo, current pack is 1500mAh, 15C, 20C burst. I feel this is underpowered and will stress the battery I have been testing the rig with. do you agree? something this size but maybe 35c more acurate? how much continuous amperage should I look for? |
12-15-2008, 07:52 AM | #1239 | |
The link you gave for timing on brushed motors is for tamaya products on your site, not setting timing on torque master mini. Could you try again please? | |
12-15-2008, 12:12 PM | #1240 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Any idea when these will be in stock? http://holmeshobbies.com/product.php...&cat=22&page=1 Eagerly awaiting its status so I can order a few |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
