Go Back   RCCrawler Forums > Vendors > Locked Up RC
Thread: Locked Up RC - FI Spool
Old 06-27-2013, 11:51 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default Locked Up RC - FI Spool
I'm thrilled to present our latest creation, our "FI Spool".
A lot of time and effort has gone into bringing you this spool and we think it will be a real no nonsense winner.
Medium weight (1 oz)
Super durable hardened steel
Compatible with Axial and HPI gear sets
We designed this spool to be a super tight fit ... because nobody likes slop.
We also designed them to be f*****g indestructible.
Order here & enjoy:
Locked up RC - FI Spool
Locked Up is offline   Reply With Quote
Old 06-28-2013, 05:45 AM   #2
R2j
SORRCA Committee Member
R2j's Avatar
Default Re: Locked Up RC - FI Spool
Oh man! Those are sweet! Better go count up how many I need now
R2j is offline   Reply With Quote
Old 06-28-2013, 06:01 AM   #3
Very nice and thats a vvery cool deal your offering!
TURBOFEST is offline   Reply With Quote
Old 06-28-2013, 06:08 AM   #4
Come on paypal funds! I see a few HR spools hitting the for sale section... :cool:
Very cool product.
winnerone23 is offline   Reply With Quote
Old 06-28-2013, 06:08 AM   #5
Always great to see new parts out from LOCKED UP I was not planning on tearing my axles apart in the middle of the scale season, but for theses it is totally worth it.
Jslick is offline   Reply With Quote
Old 06-28-2013, 06:23 AM   #6
Order placed for the spools and some other scale goodies.
Patrick I also included a message in my order for you.
Thanks, John
Old 06-28-2013, 03:16 PM   #7
Sick!! That is awesome Patrick! I will let the local guys know
Going Up! is offline   Reply With Quote
Old 06-28-2013, 05:21 PM   #8
Looking good Patrick!
Old 06-28-2013, 07:00 PM   #9
nice looking unit
rcjunky3 is offline   Reply With Quote
Old 06-30-2013, 07:50 AM   #10
Mine are on the way. After the comp on sat I have another reason to tear my rig apart, I broke the 4link in the back again and broke loose the spot weld on the front bumper. First place wins don't come cheap. While those are getting fixed I can pull the axles out and get ready for the new FI Spools.
Old 07-02-2013, 07:11 AM   #11
Locked Up's Avatar
Gonna be sending a set of these to Dan for the Vuckin Double Cab!
Locked Up's "Vuckin Double Cab" - A Chop Shop & Difuser build
Old 07-02-2013, 09:07 AM   #12
Got mine yesterday. Woohoo. Now to decide whether to save these for my other 2.2 build or for my 1.9 jk project!
spankbomb is offline   Reply With Quote
Old 08-20-2013, 08:41 AM   #13
Hello,
I have been looking around RCC to find a new locker/spool (however you prefer to call them). I previously tried to install Hot racing lockers, but upon installation in my SCX10 (with OD and normal gear ratio HD gear), I noticed that the gear mesh between the pinion and the ring gear was just horrible (gritty). To find out if the lockers where the problem, I pulled out my trusty electronic calipers. What I have found is pretty disturbing, from the highest point of the locker to the highest part of the ring gear, without bearings installed (From the tip of where both bearings are supposed to be installed), the stock setup (stock lockers, stock ring gear) measured 24.76mm, so this was now my baseline measure. So I then measured the Hot racing locker with the overdrive gear, 24.48mm!!!! The dimensions were so off that I could move the ring gear left and right in the bearing slot! No wonder my gear mesh was off. To further my testing, I measured Hot racing locker with stock gears, 24.46mm, same problem as before. So in the meantime, I am running the stock lockers with overdrive gears in front and stock ratio HD in the back, those measure 24.81mm which is a very nice fit in the AX10 axles. Could you measure one of your lockers and gear assembly just so I can be sure that I don’t run in the same problem as with the Hot racing lockers?
Thanks in advance
TrailAddict is offline   Reply With Quote
Old 08-20-2013, 11:10 AM   #14
Did you install the seal/spacer washer to shim the ring gear over a little bit???
TowerHobbies.com | Axial Diff Gasket 16x25x0.5mm
bigstu is offline   Reply With Quote
Old 08-20-2013, 04:04 PM   #15
The measurements were taken without gasket on the Hot racing lockers, but they are made to be used without them anyways.
Old 08-21-2013, 06:13 PM   #16
Very cool Patrick! I had been putting off buying spools for my wife's and my wraith. Now I'm glad I waited. Going to order 4 now.
4xFord is offline   Reply With Quote
Old 08-21-2013, 06:37 PM   #17
Locked Up's Avatar
Originally Posted by TrailAddict View Post
Hello,
Thanks in advance
I'm measuring with a 43t gear on there and get 24.99mm.
But that isn't the important measurement because the bearing will cover up the part it rides on.
What you need to measure is from the face the gear touches on to the lip the bearing rides against. On my unit that is 15mm.
Old 09-04-2013, 06:08 PM   #18
Do you have any feedback from people running them in the AX10 axles? Do they fit as well as in the wraith ones?
Thanks
Old 09-04-2013, 06:50 PM   #19
I got my spools and they look great. I hate to be that guy but I have to say I really wish they came with the 2mm bolts that hold the ring gear on. The upgraded axial gears don't come with them and they are always the hardest to find in the screw bin.
Old 09-05-2013, 08:29 AM   #20
Locked Up's Avatar
Added an option for some M2x8 Screws for those that want them.
Locked Up RC - FI Spool - Similar Threads
traxxas slash 4x4 spool or no spool? Oregon crawler Formula Offroad 12 03-17-2012 02:02 PM
Diffs locked or not locked? aorquiz Formula Offroad 8 05-20-2011 09:58 PM
Spool mtwheelin Tamiya TLT Crawlers 9 08-04-2007 12:04 PM
Axial AX10 Locked Axle Set and Locked Transmission Xtant3150c General Crawlers 13 07-22-2007 01:39 PM
You may edit your posts
