03-15-2016, 06:39 PM | #121 |
Rock Stacker Join Date: Mar 2016 Location: OK
| Re: RC4WDs New Micro Crawler
A bit of matte clear. You gotta start somewhere. I always think of something like this when people say they dropped the trans Spun the cover aside because I didn't want to take the yokes off. Those o-rings are tiny. Note the adjustable gear mesh. Last edited by Clingman; 03-16-2016 at 03:35 PM. |
03-16-2016, 01:24 PM | #122 |
Newbie Join Date: Feb 2011 Location: new zealand
I got mine yesterday had to go pick it up because I wasn't home but when I finally got my greasy hands on it I can say that it's a pretty solid little rig, the chassis had no flex or twist at all so it's engineered quite nicely however the turning radius sucks, found out that the steering knuckle is limited by the bolt that holds the shocks on, so I removed it and tested, it seemed to improve until I turned the wheels and the dog bones seem to want to turn out of the yoke at any degree greater than what is stock capable If anyone has investigated it more thoroughly let me know, because I've yet to take the front axle apart and have a look which I'm dreading as this rig is a lot more complicated construction than what I thought it would be but it may be as simple as removing an o-ring from the yoke to allow it to sit better and achieve a sharper turn??? |
03-16-2016, 03:59 PM | #123 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Got mine today and the servo went out at around 3 minutes of run time and it won't go in reverse anymore. Pretty lame.
03-16-2016, 04:49 PM | #124 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
After looking at all these pictures more closely I'm starting to think the motor is the same size as the tiny Losi Micro and not a 130 "big block" Xmod/Mini Z size. that would also explain the lack of power with the heavy metal parts everyone is reporting. has anyone compared the stock RC4WD motor to a Losi or a big block yet?
03-16-2016, 06:21 PM | #125 |
Rock Stacker Join Date: Apr 2006 Location: Asheville
Sounds like theseeing are a great start to a mini rig but need changes like any other crawler. Surprising amount of detail even from rc3wd. Also the aftermarket companies will be hot to get parts released soon.
03-16-2016, 06:31 PM | #126 |
It would be nice,but I wouldn't hold my breath on aftermarket parts for this. I'm not aware of many or any aftermarket parts for RC4WD trucks other than from them. The micro scene itself doesn't really have much for aftermarket support other than some hot racing bits and independent vendors. Still, if enough people start buying these and there is lots of builds on the forums I'm sure that could change.
03-16-2016, 07:14 PM | #127 |
Anyone have an idea on whether my reverse cutting out is either the motor itself or maybe the ESC? I emailed rc4wd about and and they had me send a video showing my shit was messed up. Hopefully tomorrow they'll either mail me new parts or tell me to piss up a rope. |
03-16-2016, 07:29 PM | #128 | |
| Re: RC4WDs New Micro Crawler Quote:
03-17-2016, 03:59 AM | #129 |
Pebble Pounder Join Date: Jun 2012 Location: Derby, UK
... which makes it stock losi size then. I wonder if a predator from Dan would be enough to get this thing moving properly? Sent from my GT-I8190N using Tapatalk |
03-17-2016, 07:13 AM | #130 |
I read a little about these motors last night. They are common in 1/32 slot cars. An 050 is a long can 030. I got an 050 on the way from eBay to try out. Will post results when it shows up.
03-17-2016, 09:09 AM | #131 |
What does the motor mounting surface look like on the transmission? It looks like there is enough room for a big block in the chassis. It may just be a matter of mounting the motor.
03-17-2016, 10:38 AM | #132 |
I don't think a big block will bolt up, because the hole spacing on the 030/050 is closer. But, looking at slot car vendors, there are a TON of motor options. I picked a high torque motor. We'll see how it goes...
03-17-2016, 12:53 PM | #133 |
Slot car motors are rated at 12v, IIRC.
03-17-2016, 01:25 PM | #134 |
I managed to bolt a Losi motor to it using one bolt inside the transmission, it had the smallest Losi gear on it and everything seems to spin, yet to wire it up and test it but it proves you can bolt a Losi motor on
03-17-2016, 01:53 PM | #135 |
Will, I don't have one of those motors to look at. Does it look like the other motor mount screw slot can be elongated to allow the mounting of that motor with both screws?
03-17-2016, 01:53 PM | #136 | |
Thanks rc4wd! | |
03-17-2016, 02:14 PM | #137 |
Strange. My last 2 replies are gone. I figured if the losi bolts up a 130 can big block wouldn't. Just like with the Losi you'd need to adapt something, but it should be doable. Another option of course is to do a divorced setup. From what I see it should be pretty easy. Then you can mount bigger motors up front with a gearhead, Losi Trans, or just a spur and pinion. It would also allow you to easily dial in more or less reduction if you still wanted.
03-17-2016, 02:31 PM | #138 |
Losi motor update: so i wired the losi motor up and the thing pulls like a schoolboy and this is with the battery that came with it, it hasn't been fully charged yet cause i had to order a charger separately. i had driven it a bit with the stock motor on and the battery out of the box and it didn't seem this powerful, but that could have been a one time occurrence, not sure what everyone else's experiences has been with it ?? to answer clingmans questions the way i bolted the losi motor on was with one of the small bolts that actually holds the transmission case cover on, so that long bolt that goes right the way through the case that allows the motor to pivot will not bolt into the losi motor cause 1: its too big of a diameter. and 2: the losi motor's holes are just the tiniest fraction different to the stock motor so the two holes of the losi motor do not align with the holes of the transmission but i think that with the next gear up from the smallest losi one that it will mesh perfectly making there only the need for the one bolt anyway |
03-17-2016, 02:38 PM | #139 |
Very cool, thanks for the update. Out of the box, mine is definitely not big on torque. It's not just yours that was like that. |
03-17-2016, 05:48 PM | #140 | |
Quarry Creeper Join Date: Jan 2015 Location: Alcoa
Might just throw a sumo tranny and motor in mine to try it. | |
RC4WDs New Micro Crawler - Similar Threads | ||||
BWD Micro Wheel Weight System for the new Losi Micro Crawler! | billet works | Vendors Market | 19 | 10-18-2010 05:42 PM |
~Petition for RC4WDs next 1.9, 3.7" tall tire~ | STANG KILLA SS | Tires and Wheels | 105 | 02-03-2008 02:17 AM |
RC4WDs Aluminum 2.2 Hilux wheels | SuperSancho | Tires and Wheels | 5 | 04-29-2006 12:42 PM |
