01-29-2012, 09:20 AM | #141 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: 2012 SORCCA scale rules |
01-29-2012, 10:09 AM | #142 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: 2012 SORCCA scale rules I believe a tuber has no ladder frame. Truggy has half ladder front. Rear starting a the skid is made from tube.
01-29-2012, 10:47 AM | #143 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Thank you for the clarification, we never gave a tuber truggy points, but after the revisions I wasn't sure.
01-30-2012, 03:11 PM | #144 |
Rock Crawler Join Date: Mar 2007 Location: perkasie, pa
is this ecoli campbell buggy legal for class 3? |
01-30-2012, 03:18 PM | #145 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
| Re: 2012 SORCCA scale rules What do you think? Here's the rules for Class 3: Class-3 “Modified” Details: • 146mm / 5.75" max tire size with a 2.2 max rim size (including spare). • A bumper is not required, but to be counted for points it must be mounted to the vehicle's chassis and wider than the the chassis rails (chassis cross rails do not count as bumpers). • Gates will be a minimum of 13" wide. • All bodies (including tubers) must measure a minimum of five inches wide from front to rear of door, measure a minimum of 4.5 inches tall as measured from the skid to the tallest point on the body (including light bars), and must be at least as long as the vehicle's wheelbase. • Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum size rules. |
01-30-2012, 03:19 PM | #146 | |
| Re: 2012 SORCCA scale rules If it fits in these rules it will: Quote:
01-30-2012, 03:47 PM | #147 |
01-30-2012, 04:02 PM | #148 |
01-30-2012, 07:28 PM | #149 |
| Re: 2012 SORCCA scale rules Not really. That rig there is the least scale looking buggy I've ever seen. Nothing like a 4 year old comp rig with a driver glued on it and called a scaler. The ESC is on the hood! This rig is what the rules are here to keep out of scale comps .
01-30-2012, 07:44 PM | #150 |
| Re: 2012 SORCCA scale rules that pic the esc is not covered, and how is it not realistic to the real life campbell buggies that run at off road parks? not every scaler is axial chassis and a yota body..........especially coming from some with awesome builds like yours
01-30-2012, 07:51 PM | #151 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
01-30-2012, 07:52 PM | #152 |
01-30-2012, 07:55 PM | #153 |
01-30-2012, 07:57 PM | #154 |
If you pull the axles back a bit, get them under the chassis, and it meets the other requirements then it's good to go!
01-30-2012, 08:00 PM | #155 |
01-30-2012, 08:02 PM | #156 | |
| Re: 2012 SORCCA scale rules Quote:
If the rules force you to change the scale appearance from what it is being modeled, then the rules are wrong. | |
01-30-2012, 08:02 PM | #157 | ||
The true Campbell looks to be right at it.... So needs to be a scale representation then huh....? Last edited by 666; 01-30-2012 at 08:05 PM. | ||
01-30-2012, 08:12 PM | #158 |
Don't care what the "rules" say. If it resembles the 1:1 used for reference, then it's a "scale" representation. Again, common sense seems to have "left the building". I'm done. You guys have at it. |
01-30-2012, 08:14 PM | #159 |
Like I said, the 1:1 looks to have the axles right at the ends of the chassis. So if it was a scale representation it would be the same? Right? |
01-30-2012, 08:41 PM | #160 |
I think it's a scale looking truck without a class to run in: Class-3 “Modified” • Description - An off-road vehicle that you would build from the ground up and might see in a TTC/KOH type competition. Unfortunately there is no "Class-4 Rock Racer" class for 2012. Instead of arguing if it's scale or not (which I think it is), talk to your reps about getting a rock racer class added for 2013. The rules for 2012 have been decided so abiding by them is the best that can be done. This is the Class-3 Campbell picture that should have been posted: Last edited by C*H*U*D; 01-30-2012 at 08:49 PM. |
SORCCA rules comments, suggestions, and questions - Similar Threads | ||||
Comments, Suggestions and Questions. | Rockpiledriver | RCP Crawlers | 755 | 05-01-2015 04:01 PM |
2012 SORCCA rules in effect! | War Pig | Scale Nationals | 16 | 03-19-2012 10:53 AM |
2012 SORCCA Scale Rules | War Pig | Scale Comp Rules | 2 | 01-01-2012 10:48 PM |
Am I on the right track? Comments and Suggestions needed. | Kingofthehill | Tamiya TLT Crawlers | 4 | 02-22-2007 12:34 AM |
