01-19-2012, 06:21 PM | #121 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: 2012 SORCCA scale rules |
01-19-2012, 06:25 PM | #122 | |
| Re: 2012 SORCCA scale rules Quote:
01-19-2012, 10:10 PM | #123 | |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
I made up a 6" go/no go stickfor NB TJ's... so there's no questions... if it stays between the tires w/o assistance ur good I could imagine event coordinators could make these for the more popular bodies to have on hand so no need to acually sit there and measure.. Bajaclaws on motoworx wheels Pits on mayhem trialshooters Last edited by kaneohecrawler; 01-19-2012 at 10:16 PM. Reason: add photo | |
01-19-2012, 11:02 PM | #124 |
That's a great idea! To tell you the truth, I'm just going to look down the truck from the front and if the tires look close....you're through. We're not trying to be Hitler here. When I'm teching trucks...if I can tell that the tires stick way out, then I'm going to get out a tape measure, but if it's close then I'm going to move on to the next rig. Remember...fun! |
01-20-2012, 08:13 AM | #125 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Tim, another idea would be to use some cheap azz plastic calipers for the close ones. Might be quicker and more accurate than a tape measure and could double as a go/no-go gauge for any body.
01-22-2012, 08:23 PM | #126 |
RCC Addict Join Date: Mar 2009 Location: hawaii
So in class 2 rules it says the inside Of the front tires can't be wider than the width of the doors? So does that mean the rear can be wider than that? |
01-22-2012, 08:46 PM | #127 |
| Re: 2012 SORCCA scale rules I guess, but I can tell you right now that you are going to rail some gates if your rear track width is much wider than your front.
01-22-2012, 08:59 PM | #128 | |
My truggy rear half with out axles to use for mock up (I was rushing, I got scammed on some axles and another set of axles I bought took about 3 weeks to get here) so basically I need to use longer beef tubes in the back with narrow hexs to clear the cage. In front I'll be using an xr10 converted axle and some wide hexs. I think total width difference will be about a half inch or less | |
01-22-2012, 09:19 PM | #129 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Tim I have a question I have had in my head for several years. On a winching or tow. Can another truck assist in pulling you up if say you have a winch failure that is permanent? or assist you by winch you up a hill? I have seen on several 1:1 programs a truck being assisted in pulling a driver up a hill in the case of winch or driveshaft failure. examples H3 pulling a Toyota crawler, with broke driveshafts, uphill - YouTube frontier pulling jeep up obstacle on pritchett canyon trail in Moab - YouTube |
01-22-2012, 09:33 PM | #130 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Yes Norm, It is a 10 point assisted recovey just like you and I did last year in Montana. Points: Progress: -2 points Reverse: +1 point Gate Marker: +10 points Rollover: +5 points Boundary Marker: +10 points Vehicle touch (repair & repositions): +10 points Course direction: +10 points Winch: +2 points Assisted recovery: +10 points Dig/rear steer: +5 points Did not finish (or point out): high score on course +20 points Did not start: high score on course +50 points Last edited by hotwheels000; 01-22-2012 at 09:37 PM. |
01-22-2012, 09:35 PM | #131 | |
01-23-2012, 02:20 PM | #132 | |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
01-23-2012, 04:29 PM | #133 |
| Re: 2012 SORCCA scale rules I can't do it.....lol everyone hates my jeep so much I gotta keep it just for spite! Haha I am picking up one of pardonmynoob's hilux's tho for a C1 build. Will be collecting parts during the deployment I'm goin on next month. |
01-23-2012, 11:17 PM | #134 |
You also have an advantage over the hilux bodies rigs cause the jeep body is waaaay smaller and Lighter and lower profile. So you want to have the same Track width but less body, I think that's why this rule was made. |
01-26-2012, 09:09 PM | #135 |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: 2012 SORCCA scale rules exactly... if it wasn't the way it is the class would end up having a bunch of mini sized bodies like comp trucks..
01-27-2012, 12:11 PM | #136 | |
I'm over the issue already was only asking tim about options/reason and he gave it. I wasn looking to start a debate. Last edited by kaneohecrawler; 01-27-2012 at 01:10 PM. | |
01-27-2012, 01:17 PM | #137 |
| Re: 2012 SORCCA scale rules Bingo. Our goal was to help all kinds of rigs have similar performance potential, regardless of how that may relate (or not) to their 1:1 counterparts. In other words, my daily driver TJ has more than half the tires stick out past the fender flares. But in 1:10 scale, it should be in Class 2 and I understand why: so we don't have everyone building only Jeeps. |
01-27-2012, 01:42 PM | #138 |
I wanna be Dave Join Date: Dec 2008 Location: ?
01-27-2012, 01:56 PM | #139 | |
But yeah, we're just trying to help everyone be somewhat competitive regardless of their chosen vehicle. It's NOT an easy job, but I think we did pretty well if I may say so myself. I know some aspects of rules may raise eyebrows, but after some thought and/or explanation I think it becomes more clear why we made the decisions we made. | |
01-29-2012, 07:42 AM | #140 | |
Rock Crawler Join Date: Sep 2006 Location: Lititz
| Re: 2012 SORCCA scale rules After reading this section: Quote:
A tuber would also get points for a truggy/back halved truck if it met the criteria? On all the other categories it states "not available to tubers". | |
SORCCA rules comments, suggestions, and questions - Similar Threads | ||||
Comments, Suggestions and Questions. | Rockpiledriver | RCP Crawlers | 755 | 05-01-2015 04:01 PM |
2012 SORCCA rules in effect! | War Pig | Scale Nationals | 16 | 03-19-2012 10:53 AM |
2012 SORCCA Scale Rules | War Pig | Scale Comp Rules | 2 | 01-01-2012 10:48 PM |
Am I on the right track? Comments and Suggestions needed. | Kingofthehill | Tamiya TLT Crawlers | 4 | 02-22-2007 12:34 AM |
