RCCrawler.com Bulletin Board
Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread Tools Display Modes
Old 01-09-2005, 05:31 PM   #1
BENDER
2006 2.2 National Champ
BENDER's Avatar
Arrow RCCRAWLER tips, cheap tricks / parts guide.
This is intended to be a guide to cheap fixes, mods, tricks, and parts. I'm doing this to keep a thread that just contains these tips so they are easy to find. I used title of original thread w/ a little editing on some. I included important tips on setting up chassis's as well.
First off...............nitros can't crawl.
http://rc-car-videos.blogspot.com/20...s_archive.html
Got a cheap trick, that's not on list? Post it here....
http://www.rccrawler.com/forum/showt...t=cheap+tricks
Painting the body (opinions on brands).
http://www.rccrawler.com/forum/showt...=painting+body
Tips on painting bodies (correct way).
http://www.rccrawler.com/forum/showt...ainting+bodies
Stripping paint from lexan.
http://www.rccrawler.com/forum/showt...ng+paint+lexan
Lexan body work.
http://www.rccrawler.com/forum/showt...exan+body+work
Ultimate tire foams.
http://www.rccrawler.com/forum/showt...ate+tire+foams
Removing glued tires.
http://www.rccrawler.com/forum/showt...ng+glued+tires
How to narrow 40 Series wheels
-Narrowing Proline 40 series wheels
-Narrowing Axial 40 series wheels
Cheap plastic rod end slop fix.
http://www.rccrawler.com/forum/showt...highlight=slop
BFT rod end part number and price.
http://www.rccrawler.com/forum/showt...ht=part+number
Traxxas rod end part number.
Cheap metal rod end bible.
How to lock Clod diffs.
http://www.rccrawler.com/clodlocker.htm
Gear ratio equations and chart.
http://www.rccrawler.com/forum/showt...ar+ratio+chart
Balancing weight.
http://www.rccrawler.com/forum/showt...lancing+weight
Adjusting anti-squat?
http://www.rccrawler.com/forum/showt...ght=anti+squat
http://www.rccrawler.com/forum/showt...Aanti-squat%2A
Torque twist (how to fight it).
http://www.rccrawler.com/forum/showt...t=torque+twist
TXT servo mount dimensions.
http://www.rccrawler.com/forum/showt...139#post455139
Revo shafts (how to install).
http://www.rccrawler.com/forum/showthread.php?t=5371
Extending Stampede driveshafts.
http://www.rccrawler.com/forum/showthread.php?t=41181
4 Link 101. (proper set-up tips)
http://www.rccrawler.com/forum/showt...ghlight=4-link
How to figure link length.
http://www.rccrawler.com/forum/showthread.php?t=18015
Making links.
http://www.rccrawler.com/forum/showt...t=making+links
http://www.rccrawler.com/forum/showthread.php?t=59108
Best way to link mount shocks.
http://www.rccrawler.com/forum/showt...k+mount+shocks
How do I stop my link clamps from sliding?
http://www.rccrawler.com/forum/showt...=clamp+sliding
How do I fishmouth brakeline?
http://www.rccrawler.com/forum/showt...outh+brakeline
Harris safety silver-56 (where to buy).
http://www.rccrawler.com/forum/showt...is+safety-silv
Brazing stainless?
http://www.rccrawler.com/forum/showt...zing+stainless
Bending aluminium.
http://www.rccrawler.com/forum/showthread.php?t=1836
Cutting aluminium.
http://www.rccrawler.com/forum/showthread.php?t=6170
GD-600 (how to install).
http://www.rccrawler.com/forum/showt...ighlight=gd600
Servo guide
http://www.fatlion.com/sailplanes/servochart.html
645mg turned into winch.
http://www.rccrawler.com/forum/showthread.php?t=17970
http://www.rccrawler.com/forum/showt...ht=645mg+winch
Correct part # for pinions.
http://www.rccrawler.com/forum/showthread.php?t=1557
Servo saver or not.
http://www.rccrawler.com/forum/showt...ht=servo+saver
Truck problems (fixing glitching).
http://www.rccrawler.com/forum/showt...truck+problems
Tube project idea (getting scale look right).
http://www.rccrawler.com/forum/showt...e+project+idea
Series or parallel?
http://www.rccrawler.com/forum/showt...series+paralle
Motor wiring (forward/reverse rotation Q's).
http://www.rccrawler.com/forum/showt...t=motor+wiring
How to build/tune a 2.2 comp crawler.
http://www.rccrawler.com/forum/showthread.php?t=46775
TLT Rock Buster vs TLT Max Climber (What's the difference?)
http://www.rccrawler.com/forum/showthread.php?t=16800
TLT tranny options.
http://www.rccrawler.com/forum/showthread.php?t=38680
Turning down TLT shocks, for a more scale look.
http://www.rccrawler.com/forum/showthread.php?t=47526
Limiting straps.
http://www.rccrawler.com/forum/showthread.php?t=5823
Fender trim materials.
http://www.rccrawler.com/forum/showt...nder+materials
R/C License plates.
http://www.rccrawler.com/forum/showt...license+plates
Cheapest crawler.
http://www.rccrawler.com/forum/showt...ghlight=zipzap
Need some driving tips for comps? You know you do.
http://www.rccrawler.com/forum/showthread.php?t=70206
Tips for building a backyard rock garden.
http://www.rccrawler.com/forum/showthread.php?t=76691
How to make front dig.
Miniwheeler's dig
socket to ya dig
Bearing mod to eliminate the slop in worn aluminum axle C's
Mnster's mod
Locking a Pede tranny without epoxy or JBweld
Offroader5 shows you how to lock a pede tranny with no JB or goo
Widths of common crawling axles
Losi Springs to use on crawlers
Time to start wrenching.
BENDER is offline   Reply With Quote
Old 01-18-2005, 11:19 AM   #2
badger
RIP Buster
badger's Avatar
Default Re: RCCRAWLER tips, cheap tricks / parts guide.
This has been restored. testing.
badger is offline   Reply With Quote
Old 01-18-2005, 03:50 PM   #3
tltcrawlerxtrem
how to cut alumium link is wrong sumthing for maximizer beadlocks :?
__________________
tlt-1,rusty,pede,maxium mt pro,tc3, nitro tcs
tltcrawlerxtrem is offline   Reply With Quote
Old 01-18-2005, 05:35 PM   #4
BENDER
BENDER's Avatar
Quote:
Thanks for pointing that out, I removed link. I'll try and find the right thread and post it back up.
Old 01-30-2005, 10:43 PM   #5
hcfr34
Thanks for all the time you put into the stickies, what a truck load of helpful info. ;)
__________________
If it ain't broke your doing it wrong.
hcfr34 is offline   Reply With Quote
Old 01-30-2005, 10:58 PM   #6
BENDER
BENDER's Avatar
Quote:
No problem, glad to see people are finding it useful.
Old 02-26-2005, 01:03 AM   #7
BENDER
BENDER's Avatar
Talking Updated
OK guys, I finally updated these links to the new forum. LMK if anyone finds any problems.
Old 04-02-2005, 11:51 AM   #8
rcbif
i though i saw somewhere someone cutting a dog bone in two then like putting each half in some sort of a metal shaft thing
rcbif is offline   Reply With Quote
Old 04-03-2005, 11:39 AM   #9
BENDER
BENDER's Avatar
Quote:
Here's a link that might answer your questions:
http://www.rccrawler.com/forum/showt...ended+dogbones
Old 12-27-2005, 03:19 PM   #10
Madcratebuilder
Madcratebuilder's Avatar
FASTENERS..........we all use them in the build-up of your rigs. I used to get mine at the local True Value, till I found this place.
www.microfasteners.com
Money back guarantee...can't beat that.
Great price. I just recieved my order of 120 SS sockethead 3mm screws, ranging from 20-40mm in lenght. $31 shipped. Half of what you would pay at the hardware store. That encluded 3 day priorty mail
__________________
Ignorance is curable, stupidity is for life.
Madcratebuilder is offline   Reply With Quote
Old 01-26-2006, 11:21 AM   #11
spookyseven
i think this might belong here for anyone who is looking for a servo
gigantinc servo guide
(yes, i know it is already posted elseware, but i think this might be a more practical place for it)
__________________
If my heaven is something between Glamis and Moab, I'm living in hell.
spookyseven is offline   Reply With Quote
Old 04-05-2006, 10:56 AM   #12
peej410
i noticed some people mentioned they had trouble drilling accurate holes in aluminum so i figured id post this http://www1.mscdirect.com/CGI/NNSRIT...PMT4NO=6387899
they are great for making pilot holes because they are rigid and as long as you use a smaller one, (1/4 shank) they are perfect size for RC stuff.
peej410 is offline   Reply With Quote
Old 09-20-2006, 09:14 PM   #13
Mule
Default gear reduction units?
Can you put up sources to gear reduction units being used on the E/Tmaxx?
I can't find anything.....
__________________
Knowledge not shared is knowledge lost.
Too many toys, not enough time -
Mule is offline   Reply With Quote
Old 09-20-2006, 09:33 PM   #14
BENDER
BENDER's Avatar
I think most Maxx guys that use a reduction have the GD-600. Install will be about the same as a TXT which is posted here.
Not sure if it'll work with a T-Maxx tranny though.
Old 09-21-2006, 08:55 AM   #15
Mule
Default cool!
Thanks, I found everything I needed!
I saw a post w/ dual motors on dual GDs - on a maxx.
Here is the mfg # GPMG0850
Here is a tower link. http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML
For $12.99, I think it's worth trying them on anything!
Greg
__________________
Old 01-12-2007, 04:48 PM   #16
Dsanchez
good info here thanx
Dsanchez is offline   Reply With Quote
Old 05-12-2007, 02:12 AM   #17
balang_479
is anything about how to made a tube chassis or roll cage?
like what material to use and how to weld it together,.
balang_479 is offline   Reply With Quote
Old 05-12-2007, 04:01 AM   #18
BENDER
BENDER's Avatar
Here's a link to an article on the front page on building tubers.
http://www.rccrawler.com/tuber.htm
Old 05-25-2007, 09:06 PM   #19
FASTFLEE
great info I guess I will never have to ask a thing now hahahaha NOT
FASTFLEE is offline   Reply With Quote
Old 07-04-2007, 08:51 PM   #20
Crawlerdude75
I joined the Band!
Hey thanks for puttin my guide up there. I really appreciate that BENDER.
Crawlerdude75 is offline   Reply With Quote
You may not edit your posts
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004-2007 RCCrawler.com
