01-11-2016, 04:38 AM | #61 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
| Re: Scale EB Build
Beautiful!
01-11-2016, 06:19 AM | #62 |
Pebble Pounder Join Date: Dec 2015 Location: Essex
| Re: Scale EB Build
Thanks guys... I gotta keep up with the high standards already set around here!
01-11-2016, 01:14 PM | #63 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: Scale EB Build
Looks righteous sitting on the frame.
01-12-2016, 11:14 PM | #64 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
| Re: Scale EB Build |
01-13-2016, 06:12 AM | #65 |
| Re: Scale EB Build
Gotta keep this thing movin'... On to fender aprons, kick panels, and front wheel wells. Here is where she sits as of today. Driver side wheel well with all the crazy bends for clearing the power steering. Passenger side mounted to the fender apron and core support. Test fit of front clip. Still needs the support brackets from core to wells and wells to firewall. Good Lord! It's time to clean up the workbench too! |
01-13-2016, 06:30 AM | #66 |
Rock Crawler Join Date: Oct 2009 Location: OUT THERE
| Re: Scale EB Build
This is a jaw dropperAnd I can't believe how fast your bangin it out. Nice work
01-13-2016, 09:04 AM | #67 |
| Re: Scale EB Build
Thanks! The hardest/most time consuming part is taking all the measurements and making the scale templates.
01-13-2016, 11:31 AM | #68 |
Newbie Join Date: Jan 2016 Location: Rancho Cucamonga
| Re: Scale EB Build
This is really cool. I joined so I could follow the build. Keep up the good work!
01-13-2016, 02:17 PM | #69 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Scale EB Build
Man you and Metal Masher are in a class all to yourselves. Very cool stuff here.
01-13-2016, 02:25 PM | #70 | |
| Re: Scale EB Build Quote:
I hope to gain some more knowledge from you all about electronics, motors and esc's because this stuff is all new to me. Won't be so cool if I can't make it run | |
01-13-2016, 05:16 PM | #71 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
| Re: Scale EB Build
Oh my... This is just insane.. Great, great job. Can't be typed enough. |
01-18-2016, 07:15 AM | #72 |
| Re: Scale EB Build
Alrighty, got to make sure nobody thinks i'm slacking off, here are a few more progress shots of the front clip. Core to fender/battery tray supports and body mount. Left side body mount. Floor supports (still needs the braces for under the seats and seat belt tabs). And almost last (but not least) the press plate for the rear bed. I had been trying to figure out a way to get nice crisp bed lines and decided to make a set of dies out of some scrap 6061 1/4 inch plate i had. I've had great results in the past milling it on the table saw with a carbide metal cutting blade. I love how clean it cuts until it doesn't. For those of you that are observant, you can see the obvious oops in the photo. As i was making the last pass on the top horizontal cut, I hear a loud snap and the piece jumps out from under the push block, hits the fence then me and bounces to the floor. As it bounces my first thought is oh crap, I just...... ruined the piece. I'm sure most of you know where this is going. Yeh, I felt something hit my finger but it really didn't hurt so i pick up the aluminum and inspect the damage. Not too bad but it does have a bit of me on it as well. HMMMMM, Blood sacrifice has been made to the project so all should go well from here on out! ;) Then I start leaking. Here is the jist of what happened... Carbide tooth broke off the blade while feeding it, that caused the piece to jump out from under the push block, grabbing more blade, causing it to flex and grab even more and now we have a baseball pitching machine that throws large bits of sharp 6061 aluminum. Cool huh? Walk of shame upstairs to tell the wife we are changing date night to an ER visit :( (she wouldn't let me super glue it back together). Sorry, no pre-op photos but for those of you with stronger fortitude, here is 24 hours post-op. 4 sutures later ( nothing they could do for the missing smiley face section). And yes, I did photoshop out my fingerprint to protect the stupid (me) ;) I also got started on the windshield frame but failed to get pics for obvious reasons. I really don't like leaking. |
01-18-2016, 01:37 PM | #73 |
| Re: Scale EB Build
Pitty party is over... on to the windshield frame. boxed sides were a PIA to bend but they match the 1:1. Just need the drip edges tacked on. Test fit to top cross piece inside detail And of course there needs to be a hinge to fold the windshield down. None of the bronco vendors seem to sell them in 1/10th scale so... Just need to trim it up and tack it to the cowl. |
01-18-2016, 02:16 PM | #74 |
| Re: Scale EB Build
Wow, those hinges! I can't tell from the picture but did you roll the sheet metal for the hinge knuckles or did you attach a small tube to it?
01-18-2016, 02:59 PM | #75 |
| Re: Scale EB Build
Holy smokes. Just gets better and better.
01-18-2016, 04:05 PM | #76 |
01-20-2016, 12:14 PM | #77 |
Quarry Creeper Join Date: Oct 2015 Location: Wisconsin
| Re: Scale EB Build Quote: Sent from my SM-G920R4 using Tapatalk |
01-20-2016, 06:18 PM | #78 |
| Re: Scale EB Build
A small pair of vise grips and then bend down the side wings. I also have a pair of sheetmetal vise grips for bending longer stuff. I'd post a pic but photobucket is being a poop tonight. I did have some updates of how the bed dies worked out but I guess it will have to wait.
01-20-2016, 06:24 PM | #79 |
| Re: Scale EB Build
Simply in awe....just amazing fab skills here. Sorry about the loss of flesh, been there, lost a tip to an old Pontiac Lemans rear axle, stitches brought back memories.
01-20-2016, 07:30 PM | #80 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
| Re: Scale EB Build
Truly inspiring and amazing work!
Scale EB Build - Similar Threads | ||||
~The Scale Shop~ 2008 Scale Nationals Rubicon 2.2 Tuber Build | STANG KILLA SS | 2.2 Scale Rigs | 103 | 12-10-2010 05:49 PM |
