10-13-2012, 08:47 PM | #81 | |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
| Re: Clanker's Wreckluse Quote:
Addendum 10/15/12: ITS MONDAY!!! somehow that is not as cool as ITS FRIDAY!!! Did you get to take the mantis out for a walk? All i managed to walk was my pooch. Thanks man! Last edited by Lobonyc; 10-15-2012 at 02:10 PM. | |
10-15-2012, 04:22 PM | #82 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Yes I did...was gald I did as well, really like that rig. Meatwad soaked his servo a bit too much and was watching, so I let him run it for a bit...he even states that it's totally different kind of crawling. It's nice to switch it up a bit. Was wondering if you got to mess with your shocks at all...I know how that "no time" thing works....thought maybe you were doing the Mimi since Friday and fell down... |
10-15-2012, 05:57 PM | #83 | |
Dude, the only thing i managed to do was swap one rear 110mm shock with a 90mm one before the honeydew was served..."honeydew this & honeydew that". To be honest...im not even sure how i managed that one shock swap! I rather do done a "Mimi" and wind up on the floor than get served with any more honeydew! | |
10-15-2012, 06:28 PM | #84 |
Yeah got home and dried it out, worked well for a few mins bench testing my new 3link/panhard setup and it smoked. The board was heavily corroded from the salt water dunk, now I know how to seal this type of servo better. Ah well now I have a powerful new winch! Haven't driven moa's much, it still feels weird |
10-15-2012, 09:16 PM | #85 | |
So, it wasn't the serious dunking you did on Saturday then...residue of a salt water dunk at the Bean ??? That was some time ago though...salt water is the acid bath for RC's and cameras. Left a Nikon F (old school ) out on the beach during a heavy fog/misty day. It got damp, didn't think anything about it, wiped it down...a week or so later it was rusted thru and thru, the lens wouldn't even rotate to focus...about a $900 mistake I'll never make again. Pretty sad. Are you sure you can waterproof against salt water??? Alex my friend...nobody knows "honey do" like I know "honey do", it's made a mess of many a weekend for me...happens about once a month.... | |
10-15-2012, 09:55 PM | #86 |
| Re: Clanker's Wreckluse |
10-16-2012, 05:24 PM | #87 |
Do you think them blue waterproof servos by hitec and traxxas can survive salt water? That salt water can really mess things up. I feel your pain with regards to your camera and lens, and MEATWAD's pain for his servo loss. Brings back lots of memories, lol. Hmmmmmmm, honeydew once a month...not bad...I think it has become a staple of my everyday life. |
10-16-2012, 06:13 PM | #88 |
Ha...I was refering to a cycle....on that once a month thingy... which Hitec's are "waterproof" Alex ??? The salt will corrode any exposed metal I'm sure...including screws, the outer gear, the horn. I'm even weary of dunking the Hitec I have in fresh water...they aren't cheap. The Bluebird Cyrus had in his actually had an aluminum casing...it was killer and was a good price at that...nice and torque-y I will buy one soon. just avoid the salt water with it |
10-17-2012, 05:42 AM | #89 | |
waterproof Hitec servos: TowerHobbies.com | HRC35646W 35646W Hitec HS-5646WP Digital Waterproof HV MG Dual BB Servo TowerHobbies.com | HRC32646S 32646S Hitec HS-646WP Analog Waterproof High Voltage Servo They are not as powerful as one would hope but they should be good for fresh water. At this point MEATWAD's "stay out of saltwater" philosophy would be best for long lasting servos whether waterproof or not. | |
10-20-2012, 06:47 PM | #90 |
Rock Crawler Join Date: Feb 2012 Location: NORTH SYRACUSE N.Y.
Hey Post , what did you use for your gauges? the scale looks good Lobo , how is yours coming? |
10-20-2012, 07:41 PM | #91 | |
Replaced the front MIP drive shaft with a shorter one. Shortened the front links by 5mm for good servo clearance. swapped 2.2 wheels and tires for 1.9s. the front shocks were moved to second hole (towards chassis). Axial universals were installed in front. To do: Change rear shock location. install rear universals. cut and paint new panels. redo willys chair and cockpit and possible redo the lighting...its kind beat up and has missing lenses. thanks for asking paleblue | |
10-20-2012, 10:32 PM | #92 |
10-20-2012, 10:36 PM | #93 |
Hey Alex, you cutting lexan body panels?? I sure would like to find some metal panels and hood...got any ideas? Especially the hood |
10-21-2012, 07:57 AM | #94 | ||
RPP Hobby Scale Dash for 1/10 scale Quote:
Metal panels would be cool except i get nervous about sharp edges. I thought of the diamond plated aluminum sheet for the sides and roof. RC4WD Scale Diamond Plate Aluminum Sheets (2) Hot Racing 1/10 scale aluminum Diamond Plate 9 x 11 Now here is a twist for ya...aluminum styrene. i found some sheets on one my father/daughter walks and snatched them up. never used them though. The have a mirror metal finish however i dont know what they will look like when you start getting scratches. maybe best left for roof panel, instrument/gauge panel, and the rear inside panel. The hood on the other hand is problem. Replacements are impossible unless you purchase another wreckluse chassis. Ive never seen replacement hoods sold at RCP although every wreckluse owner has asked about it and has wanted one. Not sure why they dont make them and that sucks. The always say you can cut the hood from a jeep body as replacement. Im thinking all you need are some styrene and skills... also say that the HPI bronco hood is too wide...lol Here is a funny one for ya greg...balsa wood, hahahahha when i first got the wreckluse my intention was to cut all panels from balsa wood, stain the panels then gloss. i got one done; a pain and a mess. once mounted on, it just looked plain wrong. let me know what you decide. | ||
10-21-2012, 08:32 AM | #95 |
I to wondered why they never offered a replacement hood , side panels are fairly easy but to buy a whole HPI Jeep body for just the hood seems a little pricey but thats what we wreck owners do I guess. I also would like to put one of TSS aluminum Jeep grills in mine , I just got one of the billet radiators .Mine is sitting at the moment I was given 4 vintage cars and I am trying to get them going . 2 - 1/8th scale on roads and 2- 10th scales . Thanks for the info on the gauges, why are they a pain ?
10-21-2012, 09:27 AM | #96 |
Hard to find...but I guess I don't search we'll.... That link Lobo found was the exact part I found I would gladly pay for new panels....metal or lexan, especially if they came with a hood |
10-21-2012, 09:56 AM | #97 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
I've been nagging, pleading and begging for a few years now for a replacement hood/panel set from RCP....you can't tell me that they only make one set per chassis! . I kinda feel like I'm being "dicked around" with their responses.
10-21-2012, 10:06 AM | #98 | |
Clear Hood for Timberwolf Chassis Cant say it will work but i posted a question on the thread so lets see if other have used it successfully. thread: Wreckluse hood where at??? Did you use the original body panels or did you make spares first? | |
10-21-2012, 10:08 AM | #99 | |
I recall RCP having spares once...and to be honest...that might have been a dream | |
10-21-2012, 11:08 AM | #100 |
That RC4WD hood may work and cheaper than a whole body , good find Lobo. and thanks again for the gauge link
Clanker's Wreckluse - Similar Threads | ||||
just got a wreckluse and need help | pontiacfreak | Electronics | 7 | 11-24-2009 10:10 AM |
