02-07-2016, 03:02 PM | #61 |
| Re: Maslin's Bomber Not-Ready-To-Run Build
Very nice! Interested to see how it holds up to your driving style.
02-08-2016, 07:18 AM | #62 |
The scale knuckles put the rod ends right in the wrong place. Two easy solutions: Put the tie rod and drag link on top of the knuckles, I would not personally do this. You can countersink the button head screw hole that is hitting the rod end. This is fast, easy and gets the job done. |
02-08-2016, 09:30 AM | #63 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Tie rod on top definitely won't work, I've put the screw head through a Pitbull sidewall as it is now Counter sinking the end screws with some flush allens sounds perfect. Thanks for getting that spacer out so quick, awesome service. Didn't make it to the track yesterday, apparently my wife's capstone accounting classes are 7 days a week |
02-09-2016, 01:39 PM | #64 |
Looking at the pictures from Dlux a little more, my links are in the right spot. The second hex spacer is a support off the left side. I will install the spacer when it arrives, in the mean time, it's time to make some links! 5/32" Music wire. This stuff is marked 3.97mm, 4mm threads work just fine. Only one problem... you can't bend it or thread it Measure between the rod ends, 105mm. Add 10mm per rod end, cut links. Added 2mm on the right to accommodate the bend to clear the servo. I grind a slight taper at the ends to help start the die. Add heat, until the color turns. Hope this doesn't happen... SnapOn guy comes today, I'll trade them out and continue threading later This stuff is miserable to work with, but nearly indestructible links are worth it. One down, two to go. Last edited by maslin; 02-09-2016 at 01:53 PM. |
02-10-2016, 08:10 AM | #65 |
Success. $3 for 3' of rod and 6 revo ends... Under 10 dollars and an hour of frustration |
02-10-2016, 09:26 AM | #66 |
Those look great. I really like the bluing they got from heat treating. Make me a set? |
02-10-2016, 10:13 AM | #67 |
For sure. Measure what you need eye to eye, I have these set for the Dlux u4 truss, steel Revo push rods with 2 Jato ends as bottom links, 90mm Slash front Powerstrokes. The front end is pushed out a bit from stock, much more comfortable for the MIP splines, pinion sits perfectly. The steering link is pretty picky, considering how short it is. I have just enough throw in the servo to get full steering, turning right the link gets close to passing 180*, turning left the rod end just touches the servo body. A longer servo arm would definitely help, I still have an Axial arm with the "long" hole cut off. |
03-07-2016, 10:54 PM | #68 | |
Newbie Join Date: May 2009 Location: CA
| Re: Maslin's Bomber Not-Ready-To-Run Build Quote:
Could you post a picture of what your Bomber looks like at full droop? I am interested in getting the slash front and rear power strokes like you did but am curious how much droop they have and if it's enough. Just a picture of you holding the Bomber by its roof so the suspension is fully extended would be awesome! | |
03-09-2016, 07:01 AM | #69 |
Droop Bump Ride height |
03-21-2016, 03:49 PM | #70 |
Thanks, I'm really enjoying it. The way that the Dlux truss and VP scale knuckles line up killed my steering angle. I'm living with it, it isn't a true crawler any way. Beat on it hard enough last weekend to bend both rear axles, the long side in the middle, the short side at the pin. Front end is all good There's nothing I'm worried about when I take it out. Full throttle up a near vertical hill, barrel roll back down and keep going. |
03-21-2016, 06:22 PM | #71 |
| Re: Maslin's Bomber Not-Ready-To-Run Build |
03-22-2016, 07:18 AM | #72 |
03-22-2016, 07:54 AM | #73 |
It's right at 37*. The end of the steering arm hits right at the end of the G10 and the last bolt. Countersinking flat screws helped a lot, but it still there. It doesn't bother me, The throttle is much more fun to steer with Last edited by maslin; 03-22-2016 at 07:56 AM. |
03-28-2016, 07:36 PM | #74 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
Sent from my SM-N910V using Tapatalk | |
03-28-2016, 08:48 PM | #75 |
I'm running the standard front and rear slash powerstrokes. They are only 10mm longer in the rear, the XTs are an inch longer. I am using dual springs front and rear, a single longer spring will work, but I have had good luck with the dual springs. It sits a little higher that that in the rear, about perfectly level. It works great for trail bashing and u4 style track running. It is too long and low to be a great crawler, brushless power and pit bulls help though. |
03-28-2016, 08:52 PM | #76 | |
04-12-2016, 11:45 AM | #77 |
Tried 90mm shocks all the way around. Rear had about a 1/4" of travel and sat much lower than the front. Went to a 100mm in rear and got it about level now. Now I understand why it looks that way! What weight oil are you running? Figured I'd start with properly filled 30 wt since I had no clue what the stock shocks had in them or how much. Sent from my SM-N910V using Tapatalk |
04-12-2016, 12:04 PM | #78 |
Definitely need a longer shock in the rear to sit level, I'm using the 90mm front, 100mm rears. I put the shock info in your other thread, but I guess it belongs here too. Slash Powerstrokes, fronts in the front, rears in the rear. Blue over Green springs front, Yellow over Green rear. 20wt front, 30wt rear. Front shocks are in the front hole of the rear mount on top, outboarded on the link mounts on bottom. Rear shocks in rear hole of front mount on top, middle hole on the VP trailing arm. Just a little preload on the RR to help with torque twist, along with the Axial Bomber rear sway bar set. Dlux servo mount in the front, all tabs/mounts/plastic cut away until both axles uptravel until the whole housing hits the chassis. As said above, you need to maximize uptravel. Remove anything that touches, including the rear Wraith style sway bar mounts. |
04-12-2016, 12:07 PM | #79 |
I dremeled the servo mount tabs and the rear sway bar mount so that it would fully compress the 100mm shock in rear. Sent from my SM-N910V using Tapatalk |
04-16-2016, 05:24 PM | #80 |
Got the VP motor mount today, looks very nice. One thing stands out though.... "Includes the following: 1pc Vanquish Yeti Motor Cam 2pcs M3x10 SHCS" No screws in the bag. Like I've said before, I don't care for the stainless hardware they usually include, and would not have used it, but it should probably be included if it specifically says it is Also says it MUST be used with the VP motor plate. It's a direct copy of the axial plate, fits on the Hot racing mount just fine. Fit is perfect, as expected. Happy to get the plastic plate out of there. |
Maslin's Bomber Not-Ready-To-Run Build - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
CFM drops a Bomb: Bomber Fab build and upgrades | CarterFab | Axial RR10 Bomber | 132 | 01-24-2018 09:42 PM |
KurseD build: the Brass Bomber Budget Bucket | KurseD | RC4WD Trail Finder 2 | 15 | 05-26-2016 04:40 AM |
Stealth bomber the Class 3 build | RockChuck | 2.2 Scale Rigs | 53 | 05-04-2015 07:15 PM |
Ax-10 Ready to Run ?? | SD333 | Axial AX-10 Scorpion | 6 | 12-13-2007 01:25 AM |
